Old 11-22-2016, 02:15 PM   #1
Veeoh
Veeoh's Avatar
Can I fit rims with 5x114 bolt pattern?
So from looking around...our cars run 5x100 bolt pattern. Would I run into any problems if I run a set of sparco 18x8 with a bolt pattern of 5x114?
Veeoh is offline   Reply With Quote
Old 11-22-2016, 02:17 PM   #2
gramicci101
Off Topic
Yes, you can. Sort of.
You need conversion spacers. They bolt on to a hub with 5x100 pattern and have studs in 5x114 so you can bolt the spacers to the hubs and the wheels to the spacers. They usually run about 15mm thick, so keep that in mind when wheel shopping.
On the other hand, Sparco makes plenty of 5x100 wheels, so why would you?
edit: FIRST!
Old 11-22-2016, 02:17 PM   #3
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
To bolt the wheels up, you would need a set of conversion spacers. They will bolt to your hubs, and present a set of 5x114.5 lugs for your wheels to bolt on to.
For example:
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 11-22-2016, 02:19 PM   #4
yelsew
Little Member
yelsew's Avatar
got it in a second before me!
<--- My Journal
The Following User Says Thank You to yelsew For This Useful Post:
gramicci101 (11-22-2016)
Old 11-22-2016, 02:23 PM   #5
Veeoh
Veeoh's Avatar
edit: FIRST!
Ok gotcha. was browsing around on "let go" the app..and someone had a set with tires for a really good price so I thought I'd take a look.
Old 11-22-2016, 02:30 PM   #6
gramicci101
Off Topic
Check out Tirerack's selection. Sparco wheels aren't terribly expensive brand new, so look at the cost of conversion spacers and see if you're really saving any money with the used wheels.
Also look up wheels for a 2006 VW Jetta GLS on Tirerack. Tirerack tries to be excessively helpful, so if you look up a 2013 FR-S, you'll only get results for offsets similar to OEM (+48). The 2006 Jetta is also 5x100, but the offsets are much nicer (+35). That's my only problem with Tirerack's site.
Old 11-22-2016, 05:34 PM   #7
adjusts
adjusts's Avatar
Drives: 86
I used to run 5x114.3 wheels on my FRS. Had no problems at all. Only thing that makes it a hassle is if your wheels do not have enough backspacing, you will need to shave your OEM studs to fit the wheels with the spacer.
Feel free to PM me if you have any questions. I'd be happy to help.
adjusts is offline   Reply With Quote
Old 03-14-2017, 07:06 PM   #8
Scourge
Agent 86
Drives: 2017 Toyota 86
There's also this option... Just change the whole wheel bearing and hub assembly...
http://www.frsport.com/-5x100-to-5x1..._p_142325.html
http://www.meganracing.com/product_d...sp?prodid=1580
Scourge is offline   Reply With Quote
Frs bolt pattern OgCruzing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-06-2017 10:35 AM
Bolt Pattern Adapters Flat Black VW Tracking / Autocross / HPDE / Drifting 7 04-13-2013 02:06 PM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-30-2012 12:30 AM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 03:58 AM
