Old 04-12-2013, 03:05 PM   #1
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Bolt Pattern Adapters
I tried searching but couldn't find any real answers.
How do you guys feel about running bolt adapters on a track for HPDE events. I have access to some 5x114.3 wheels and would like to run those for events but would need adapters.
I'm thinking as long as I go with a reputable brand they shouldn't fall apart or anything. Is it more reliable to go with slimmer ones as opposed to larger ones? Any input would be appreciated.
Flat Black VW is offline   Reply With Quote
Old 04-12-2013, 03:51 PM   #2
grodenglaive
Drives: asphalt FR-S
problem is they change the wheel offset and add weight and are not cheap. Better just to pick up some used rims that fit and sell the 114.3's.
grodenglaive is offline   Reply With Quote
Old 04-12-2013, 04:55 PM   #3
kvnchu
Drives: 2005 S2000
Also remember that when you need to torque your wheels every couple session so if you run an adapter I would strongly recommend you remove the wheel and torque the adapter as well as the wheel.
I agree with groden 100%
Scion FR-S '13 - Track Toy
BMW M Roadster '06 - Track Toy
Suzuki GSX-R750 '07 - Track Toy
Lexus IS350 '07 - Sold
kvnchu is offline   Reply With Quote
Old 04-12-2013, 04:59 PM   #4
Flat Black VW
I dont own any sets of 114.3, but have more than a few friends with multiple sets, being able to run those wheels gives me access to many different wheels.
Old 04-12-2013, 05:07 PM   #5
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
http://www.ft86club.com/forums/showthread.php?t=32335
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
Old 04-12-2013, 05:33 PM   #6
We have a set. Depending on the wheels, you may or may not need to cut your stock studs so that the wheel can sit flush on the adapter.
Old 04-12-2013, 08:41 PM   #7
renfield90
The Stig's German cousin
KISS applies here. Will it work? Yeah, but you're adding complexity and another failure point to the system and then placing the system in a high risk environment. Does it still sound like a good idea?
Old 04-13-2013, 01:06 PM   #8
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Just get proper wheels. Buy the time you spend the money to make your friends wheels fit you could have bought half of a set of wheels that work.
What other vehicles use a 5x100mm bolt pattern? EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 09-13-2014 04:42 AM
Front Caliper Bolt Pattern kmbkk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-08-2012 11:21 AM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-29-2012 11:30 PM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 02:58 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
