Drives: brz 2017
i'v installed a wireless reverse camera and want to get power in the trunk instead of go through the car body
now i get energy on the licence plate light(in red circle), all the module and cable won't go out of the trunk cover, but the camera will only work when the light is on, it's inconvenience that i need to turn on the light on daytime when i need to use the camera i've tried in other cable(green circle), they were not acc and always on, i think that's not safe Last edited by javascripet; 11-20-2016 at 10:44 PM. |
#2 |
Drives: 2023 WRB BRZ (MT)
closest wire would be on the amp by ur spare tire honestly
| The Following User Says Thank You to lbroskee For This Useful Post: | kevaughan (04-11-2022) |
#3 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
I cant think of anything else in the trunk that would be on at all times, only during ignition. The stuff you circled in green: its for the key fob sensor so you can open the trunk with just the button, so yea that would always be on. Not sure how the wireless camera works, but can you wire it to the reverse lights? |
#4 |
Drives: Firestorm red FRS 2015
Well for the reverse camera, I used the reverse light, which is only powered when you shift into reverse. You only want to power the camera when backing up right? If so you have to run the power line down into the truck down by the spare as PandaSPUR said. Search for an exact location and if you cant find it, I can take a pic.
| Gauge install, dash cluster light cable, Tach RPM cable help... | Sportsguy83 | Electronics | Audio | NAV | Infotainment | 99 | 08-07-2016 10:36 PM |
| Recommended OC/LA shop to paint trunk spoiler and fill in trunk holes? | tracerit | Southern California | 13 | 04-20-2016 12:39 PM |
| Trading Carbon Fiber VIS Racing Trunk for Asphalt Grey Trunk + Cash | asphaltkyle | Exterior Parts (Aero, Lighting, Etc.) | 19 | 10-13-2015 06:51 AM |
| WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk | R0ME0 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 01-07-2014 09:36 PM |
| Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) | Iamthebatman | Exterior Parts (Aero, Lighting, Etc.) | 2 | 07-18-2013 02:12 PM |
