#15 |
Drives: UltraMFrS
#16 |
Drives: 2013 Scion FR-S Series 10
Dunno. I have read on other forums that this can wear out the clutch spring. I'll add to that at times I have done this (not counting high rpms where it is inevitable) you wind up with some amount of driveline lash, which I assume can't be great for the drivetrain, right? When the entire engine and trans pulls at their mounts, against bushings and the like, something has to be happening... Thoughts? Maybe it just feels that way. I'll never claim to know anything about the mechanical / engineering aspects of automobiles.
#17 |
Drives: frs
I thought i was a completly imbecile when misshift sometimes. Atelophobia kick in.
| The Following 2 Users Say Thank You to Teseo For This Useful Post: | Tcoat (11-11-2016), Ultramaroon (11-11-2016) |
#18 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | mazeroni (11-11-2016), turtlefeeder (11-11-2016) |
#19 | |
![]() I'm sorry, there @mazeroni ....... I just thought that was funny..... ![]() humfrz |
#20 |
#21 | |
IS it contradictory? I need so much help! |
#22 |
He is 78 years old. His back can't take it anymore. I hear he has a Buick like all guys over 70.
#23 | |
![]() Although, I am finding mrs humfrz's Saturn, Aura, more and more comfortable. Yep, them 6 way powered, heated seats, automatic headlights, automatic transmission and V-6 engine are feeling gooooood ....... humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (11-11-2016) |
#24 | |
![]() (since, with your gravel roads, all full of turns, going up and down mountains, you most likely don't get out of first gear all that often) humfrz
| The Following User Says Thank You to humfrz For This Useful Post: | mazeroni (11-11-2016) |
#25 | |
Drives: '17 86
i.e., I push the clutch in simultaneously while putting the car into neutral, then by the time I'm putting it into gear, the clutch is fully depressed. Is this damaging to the car and should I be more careful about having the clutch fully depressed before moving the shift knob at all? |
#26 |
Off Topic
Shifting into neutral isn't a big deal. You can shift to neutral without ever touching the clutch. Shifting from neutral into another gear is where the clutch becomes desirable. It's actually possible to downshift without using the clutch at all, as long as all the various RPMs line up at just the right moment. I wouldn't try it, personally. That's more of a dedicated auto racing thing.
#27 |
Huge E85 fan!
Drives: 2016 Scion FRS
You will hear and smell if you are abusing your transmission, don't worry about it.
smelling like burning brakes- you're damaging your clutch. Stop what you;'re doing knucklehead ![]() Hearing a bad grind- oops, get it right the next time, you're chewing up your gears to some extent. (everyone else around you who heard it too)
#28 | |
There are three big don't does though: Slip or ride the clutch. This is when you only have the clutch partly engaged and the face is just touching the flywheel. This will heat things up and can glaze the clutch disc pads or even blow things apart. You can do this for a couple of seconds (like starting on a hill) but anything prolonged or if it is just barely touching it can go bad fast. You will know you did it because you will create a smell that is like the very winds of hell have entered your car. Grind gears. I am not talking about a brief "oops I let the clutch out too soon" buzz but a full on force the gears in there whether they like it or not grind. Clutch in until gear in or risk stripping gears and synchros. You will know you did it if your hair stands on end because it sounds like you have just started up a gravel crusher. Downshift to too low a gear for the RPMs. Don't ever, ever, ever, downshift from one gear to another if you have high revs on the cars. This can over rev the engine and start busting up all kinds of very important parts. Stick to downshifting one gear at a time until you are comfortable and be very careful that you do not miss shift into the wrong gear. If you start to let the clutch out and your car screams at you get it back in fast! You may get away with this once or twice but if you keep doing it you will blow something up. Those are the only three really bad things you can do and everything else will come with practice. The scariest part of learning to drive MT is the act of learning to drive MT. Don't overthink it and let things happen naturally and eventually you will realize you just drove someplace and never even thought about when to shift.
| The Following User Says Thank You to Tcoat For This Useful Post: | cat94 (11-15-2016) |
| Taking off bumper without damaging side markers | Ericfrs | DIY (Do-It-Yourself) Guides | 7 | 06-17-2017 09:05 PM |
| Final Drive damaging transmission | azynneo | Engine, Exhaust, Transmission | 15 | 07-21-2016 03:50 PM |
| Best way of removing Bugs without damaging paint? | tacoss23 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 10-01-2013 12:13 AM |
| Frozen windows damaging window tint | i_4got | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 02-17-2013 08:37 PM |
| Drivers mat wearing out | nzer | AUSTRALIA | 91 | 01-17-2013 06:04 PM |
