Old 11-11-2016, 03:49 PM   #15
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Superman drives an AT!
Madness!!!
turtlefeeder is offline   Reply With Quote
Old 11-11-2016, 03:52 PM   #16
mazeroni
Drives: 2013 Scion FR-S Series 10
Originally Posted by gramicci101 View Post
Wait, is this really a thing you can do?
Dunno. I have read on other forums that this can wear out the clutch spring. I'll add to that at times I have done this (not counting high rpms where it is inevitable) you wind up with some amount of driveline lash, which I assume can't be great for the drivetrain, right? When the entire engine and trans pulls at their mounts, against bushings and the like, something has to be happening... Thoughts? Maybe it just feels that way. I'll never claim to know anything about the mechanical / engineering aspects of automobiles.
mazeroni is offline   Reply With Quote
Old 11-11-2016, 03:56 PM   #17
Teseo
Drives: frs
I thought i was a completly imbecile when misshift sometimes. Atelophobia kick in.
The Following 2 Users Say Thank You to Teseo For This Useful Post:
Tcoat (11-11-2016), Ultramaroon (11-11-2016)
Old 11-11-2016, 04:03 PM   #18
The whole idea of shifting fast is to get the clutch in and back out as quickly as possible. It doesn't matter how fast you push it in since you are disengaging the plates. There should be no major lash ever from pushing in the clutch and minimal if you are rev matching properly when letting it back out. Even when it does happen all is fine since that is exactly why the system is on bushings instead of bolted directly to the car. Not hurting a thing. The spring is not going to wear out any faster from a quick push than from a slow one. Unless of course as previously mentioned you happen to be Superman.
mazeroni (11-11-2016), turtlefeeder (11-11-2016)
Old 11-11-2016, 04:23 PM   #19
Been driving manuals for about 5 years. I still don't know how to shift correctly. ............... Stop overthinking things!
Good luck!
I'm sorry, there @mazeroni ....... I just thought that was funny.....
Old 11-11-2016, 04:28 PM   #20
I thought superman flew .....??.
Old 11-11-2016, 04:30 PM   #21
mazeroni
I am often caught saying contradictory things.
IS it contradictory? I need so much help!
Old 11-11-2016, 04:34 PM   #22
He is 78 years old. His back can't take it anymore. I hear he has a Buick like all guys over 70.
Old 11-11-2016, 05:55 PM   #23
Well, I'm over 70 and don't have a Buick ......
Although, I am finding mrs humfrz's Saturn, Aura, more and more comfortable.
Yep, them 6 way powered, heated seats, automatic headlights, automatic transmission and V-6 engine are feeling gooooood .......
Tcoat (11-11-2016)
Old 11-11-2016, 05:59 PM   #24
Not to worry, I'll cut you some slack, since you're from Tennessee ......
(since, with your gravel roads, all full of turns, going up and down mountains, you most likely don't get out of first gear all that often)
Old 11-15-2016, 05:07 PM   #25
cat94
Drives: '17 86
The whole idea of shifting fast is to get the clutch in and back out as quickly as possible...
I noticed that sometimes when I shift, I have the car in neutral before the clutch is fully pressed in -- and then it is fully pressed in by the time I'm putting it into the next gear.
i.e., I push the clutch in simultaneously while putting the car into neutral, then by the time I'm putting it into gear, the clutch is fully depressed.
Is this damaging to the car and should I be more careful about having the clutch fully depressed before moving the shift knob at all?
cat94 is offline   Reply With Quote
Old 11-15-2016, 06:30 PM   #26
gramicci101
Off Topic
Shifting into neutral isn't a big deal. You can shift to neutral without ever touching the clutch. Shifting from neutral into another gear is where the clutch becomes desirable. It's actually possible to downshift without using the clutch at all, as long as all the various RPMs line up at just the right moment. I wouldn't try it, personally. That's more of a dedicated auto racing thing.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
cat94 (11-15-2016), Tcoat (11-15-2016)
Old 11-15-2016, 08:19 PM   #27
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You will hear and smell if you are abusing your transmission, don't worry about it.
smelling like burning brakes- you're damaging your clutch. Stop what you;'re doing knucklehead
Hearing a bad grind- oops, get it right the next time, you're chewing up your gears to some extent. (everyone else around you who heard it too)
guybo is offline   Reply With Quote
Old 11-15-2016, 09:03 PM   #28
Gram and Guy nailed it really. The clutch and transmission are not made of glass and take a pile of light misuse. They are designed to take hundreds of thousands of shifts from people that are not professional drivers and they do that very well.
There are three big don't does though:
Slip or ride the clutch. This is when you only have the clutch partly engaged and the face is just touching the flywheel. This will heat things up and can glaze the clutch disc pads or even blow things apart. You can do this for a couple of seconds (like starting on a hill) but anything prolonged or if it is just barely touching it can go bad fast. You will know you did it because you will create a smell that is like the very winds of hell have entered your car.
Grind gears. I am not talking about a brief "oops I let the clutch out too soon" buzz but a full on force the gears in there whether they like it or not grind. Clutch in until gear in or risk stripping gears and synchros. You will know you did it if your hair stands on end because it sounds like you have just started up a gravel crusher.
Downshift to too low a gear for the RPMs. Don't ever, ever, ever, downshift from one gear to another if you have high revs on the cars. This can over rev the engine and start busting up all kinds of very important parts. Stick to downshifting one gear at a time until you are comfortable and be very careful that you do not miss shift into the wrong gear. If you start to let the clutch out and your car screams at you get it back in fast! You may get away with this once or twice but if you keep doing it you will blow something up.
Those are the only three really bad things you can do and everything else will come with practice. The scariest part of learning to drive MT is the act of learning to drive MT. Don't overthink it and let things happen naturally and eventually you will realize you just drove someplace and never even thought about when to shift.
cat94 (11-15-2016)
Taking off bumper without damaging side markers Ericfrs DIY (Do-It-Yourself) Guides 7 06-17-2017 10:05 PM
Final Drive damaging transmission azynneo Engine, Exhaust, Transmission 15 07-21-2016 04:50 PM
Best way of removing Bugs without damaging paint? tacoss23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 10-01-2013 01:13 AM
Frozen windows damaging window tint i_4got Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 02-17-2013 09:37 PM
Drivers mat wearing out nzer AUSTRALIA 91 01-17-2013 07:04 PM
