Old 11-11-2016, 12:25 PM   #1
cat94
Drives: '17 86
What am I damaging/wearing out when I don't properly shift.
I've been curious about what I'm wearing out/potentially damaging in these cases:
(1) Upshift: rpm too high and drops when clutch is re-engaged
(2) Upshift: rpm too low and rises when clutch is re-engaged
(3) Downshift: rev match too much, rpm high
(4) Downshift: rev match not enough, rpm low
Is this mainly wearing out my clutch? This is my first MT so I'm prepared to (and would rather) wear out my clutch a little faster rather than the transmission.
Also, between cases 1 & 2 and 3 & 4, which one is less damaging to do while learning?
In any case, the car will jerk/shudder unless I slow down for a 1/2 a second at the biting point when releasing the clutch.
cat94 is offline   Reply With Quote
Old 11-11-2016, 12:35 PM   #2
strat61caster
strat61caster's Avatar
1. Clutch friction plate
2. Clutch friction plate
3. Clutch friction plate
4. Clutch friction plate
A shock may take a toll on the gears, but cars are built stout enough to survive minor mistakes, go ahead and 'slip the clutch' a bit, that's what it's there for and it will take quite a bit of abuse before needing a replacement. Practice will make it better.
I don't think I felt smooth until I had nearly 30k miles under my belt, and I still jerk the car around on occasion by not being perfect with my timing. I also give the car a nice hard launch with fat sticky tires about a dozen times a month and everything seems perfectly happy to keep doing it.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
cat94 (11-11-2016), Tcoat (11-11-2016), Teseo (11-11-2016)
Old 11-11-2016, 12:42 PM   #3
I would not worry about any of those things. From what you say I would describe the actions as driving a MT. Like Strat said it will come with practice and unless you are actually burning the clutch (and you will have no doubt if you are) then the wear you are inflicting may mean the clutch lasts 99,999 miles instead of 100,000. Contrary to popular opinion clutches are not fragile. Just don't let your RPMs down so low that you start lugging the engine all the time or then you do risk some serious damage.
cat94 (11-11-2016), daiheadjai (11-11-2016), lowlevel (11-15-2016), Teseo (11-11-2016)
Old 11-11-2016, 12:57 PM   #4
MJones_RB
MJones_RB's Avatar
Today's modern transmissions are pretty bulletproof. In the days before syncros, you could really do some damage by mis-shifting. If you're on the freeway and try to go from 5th to 4th instead of 6th, you'll get some rude noises for sure.
MJones_RB is offline   Reply With Quote
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
FR-Sky (11-11-2016), Tcoat (11-11-2016)
Old 11-11-2016, 01:16 PM   #5
Ya but most of the time there were only 3 or 4 gears anyway so it was harder to screw up.
MJones_RB (11-11-2016)
Old 11-11-2016, 01:20 PM   #6
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Stick to basic and if you occasionally spirit drive than YouTube some tricks lol should be enough room for error without completely destroying you clutch or transmission. I let my bro and dad practice quiet a few time and 32k miles later I still have stock clutch 😊 will be replaced asap since I went FI and the clutch is starting to slip
turtlefeeder is offline   Reply With Quote
Old 11-11-2016, 01:22 PM   #7
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
As long as your clutch is OEM, and you dont abuse it everyday, every stop light, and red line all the time.
I think it would last you for a long time.
Source : ft86club.com
FR-Sky is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-Sky For This Useful Post:
Old 11-11-2016, 01:35 PM   #8
mazeroni
Drives: 2013 Scion FR-S Series 10
Been driving manuals for about 5 years. I still don't know how to shift correctly. Given all the threads about shifting on ft86, the endless arguments, I am clearly in the majority.
*shrug* I am not often smooth. I slip the clutch a lot to try and be smooth. I get impatient and slam shift gears occasionally. I do a poor job rev matching causing the car to buck a lot. I probably shift too fast when the trans is cold. The synchros are most certainly "worn in" with obvious signs of excess wear. I probably push in the clutch too fast which is the cause of that horrible driveline lash. I like to skip gears. I love engine breaking. So on and so forth.
What is this wearing out? EVERYTHING!
But nothing has gone kaput or feels "off" (at 40K miles now), I'll just plead ignorance if the day comes that I request warranty work on anything transmission related.
The only thing I won't do is a high rpm clutch dump.
tl;dr Every moving part is a wear item. Stop overthinking things!
Good luck!
mazeroni is offline   Reply With Quote
The Following 2 Users Say Thank You to mazeroni For This Useful Post:
cat94 (11-11-2016), lowlevel (11-15-2016)
Old 11-11-2016, 01:37 PM   #9
cat94
Drives: '17 86
I see, I won't worry too much about that then.
That's definitely good to know. I guess I'm just thinking a bit too much about it.
Old 11-11-2016, 01:50 PM   #10
Good luck!
Been driving them for 45 and still screw up every now and then. Anybody that says they don't is either a liar or has a selective memory.
shu5892001 (11-12-2016), turtlefeeder (11-11-2016), Yardjass (11-15-2016)
Old 11-11-2016, 02:10 PM   #11
gramicci101
Off Topic
I probably push in the clutch too fast...
Wait, is this really a thing you can do?
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 11-11-2016, 02:25 PM   #12
I was gonna let that slide...
Old 11-11-2016, 02:45 PM   #13
turtlefeeder
Drives: UltraMFrS
Uh superman could destroy the clutch by stepping on it vigorously lol
Old 11-11-2016, 02:48 PM   #14
Superman drives an AT!
Taking off bumper without damaging side markers Ericfrs DIY (Do-It-Yourself) Guides 7 06-17-2017 09:05 PM
Final Drive damaging transmission azynneo Engine, Exhaust, Transmission 15 07-21-2016 03:50 PM
Best way of removing Bugs without damaging paint? tacoss23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 10-01-2013 12:13 AM
Frozen windows damaging window tint i_4got Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 02-17-2013 08:37 PM
Drivers mat wearing out nzer AUSTRALIA 91 01-17-2013 06:04 PM
