Old 03-30-2014, 12:17 AM   #43
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I wasn't planning on lowering, but I was looking at these originally as a "if I do decide to lower" option. I abandoned them for coils when I was looking at a 17x9 +45 wheel. I have since dropped back to a 17x8 +45 as my wishlist wheel to save some trouble. So now I'm back to not wanting to lower, but if I decide to, these are the go to for it. I'm just wondering if a 17x8 +45 with a 245/40 tire will fit fine. I always have the same problem in all of these threads. Some close setups, but never the one I want. More pictures!
Nevermore is offline   Reply With Quote
Old 03-30-2014, 12:46 AM   #44
was385
Drives: MT WRB BRZ Limited, 2007 911s
I run a 17x8 +45 with 245/40 ZIIs and maxed out oem camber bolts on RCE yellows. Fits fine.
was385 is offline   Reply With Quote
Old 03-30-2014, 10:49 AM   #45
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
But the maxed out camber. Still different. I'm not looking for any extra camber because I don't know anything about it, so stock camber is where I'd like to stay.
Old 03-30-2014, 12:07 PM   #46
was385
The maxed out camber makes the fit tighter so there would be even more clearance without it (tilts the top of the wheel toward the strut). I would suggest picking up a set of Subaru camber bolts though. They're less than 10 bucks, very easy for an alignment shop to adjust, and they'll make a significant difference in handling. Sort of a no downside modification.
Old 03-30-2014, 04:00 PM   #47
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
Check out @stockysnail 's build page. He is running the RCE Yellows with Konis and so far has the best overall handling vs comfort of any of my friends 86s that I have ridden in or driven (i have gotten to drive his car on oregon's hwy 101). Hes done 95% of the work to his car himself, so I would shoot him a PM and ask him any questions you may have.
ilpad is offline   Reply With Quote
Old 03-30-2014, 04:03 PM   #48
Kostamojen
18x8 +35 fronts, 18x9 +35 rears, 245/35/18 all around on RCE Yellows.
Old 04-07-2014, 12:12 AM   #49
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Bump
want to see more RCE yellow/tarmac car pics
fooddude is offline   Reply With Quote
Old 04-07-2014, 10:06 AM   #50
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Anyone have an 16" wheels on RCE Yellows? Installing my RCE Yellow/Bilstein Sports with Raceseng camber plates and Eibach sway bars this weekend, and then will testfit my 16X7 TE37s...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 05-19-2014, 12:47 PM   #51
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Bump
husker741 is offline   Reply With Quote
Old 05-20-2014, 04:46 PM   #52
stockysnail
Just the tip
stockysnail's Avatar
Neuspeed 18x8 et35 17.8lbs hubcentric originally grey but I painted gold w/ red. Bridgestone RE-11 225/40R18. Koni Yellow insert shocks with RCE Yellow springs. About 1.1 camber in front and 1.5 in rear if I remember correctly.
Wheels are for sale by the way. I'm willing to plastidip black for not extra cost is desired. I'll ship as well with an added fee of course.
Old 07-07-2014, 10:34 PM   #53
husker741
Bump.
Old 07-08-2014, 09:34 AM   #54
frslee
Just drive it
Drives: 13' FR-S
Advan RS 17x8 ET45. Tires are 225/45/17 Michelin Pilot Sport A/S 3. Wheel was originally gold, but had some damages from previous owner. Plastidipped to copper metallizer.
frslee is offline   Reply With Quote
Old 07-08-2014, 09:38 AM   #55
Zenith/Nadir
Drives: 2013 GBS BRZ Limited
Prodrive PFF7 18x8 +32. -1.5* front, -2* rear. Michelin Pilot Sport A/S3 245/35 square. No rubbing anywhere. Still working on some OEM looking center caps.
http://i.imgur.com/DiZYDOE.jpg
http://i.imgur.com/FOVpm41.jpg
Zenith/Nadir is offline   Reply With Quote
Old 11-15-2016, 10:04 AM   #56
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
the drop on RCE yellows looks great (20 mm) and the front to rear neutral rate is appealing but the +50% spring rate over stock springs on OEM shocks is concerning for ride quality and durability of the shocks...is this just a "on paper" concern, how is the "real" world experience with ride and durability on oem dampers ?
neilvosko is offline   Reply With Quote
FS: RCE Yellows + Koni Yellows ***SOLD*** raul Brakes, Suspension, Chassis 0 10-22-2013 01:14 PM
Feeler: RCE Yellows + Koni Yellows *PRE-ASSEMBLED* raul Brakes, Suspension, Chassis 0 08-09-2013 03:22 PM
WTB: RCE Yellows GTHachiRoku Want-To-Buy Requests 0 07-23-2013 08:18 AM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 08:33 AM
Pic of RCE yellows on stock wheels? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-23-2013 10:10 AM
