Old 11-13-2016, 01:53 AM   #1
zackegle
Drives: 2013 brz limited
Clutch winning and idle issue with clutch
So recently about a day ago my 2013 brz at 52k miles started making this really loud noise when I clutch in, it's not the common squeak I see around the forum and I don't seem to be able to find anyone else with my issue, what could be wrong?
Here's a video of it:
Update-
Today the clutch is a lot worse now when I clutch in it squeals kinda of like the sound of a belt squeal but I don't think it is, and when I press the clutch in around 1000rpms or less the idles drop and the car dies out stalled at multiple red lights today...
zackegle is offline   Reply With Quote
Old 11-13-2016, 02:15 AM   #2
Your throw out bearing needs to be thrown out. It is done.
aagun (11-19-2016), humfrz (11-13-2016), jcw99 (11-13-2016), nextcar (11-13-2016)
Old 11-13-2016, 01:54 PM   #3
Originally Posted by zackegle View Post
So recently about a day ago my 2013 brz at 52k miles started making this really loud noise when I clutch in,.............
Hello zackegle and welcome to ...... The Forum ........
Yep, I do believe ol @Tcoat got your car's problem diagnosed properly.
In addition, I would suggest that you have the TOB (release bearing) replaced soon ....... before it freezes up and grinds through the fingers on the pressure plate.
You might as well replace the clutch disk and pressure plate as well as the TOB, while you have it opened up.
aagun (11-19-2016)
Old 11-13-2016, 04:05 PM   #4
zackegle
Darn I was hoping it was something else but I figured I'd run into the tob issue eventually, luckily I still have a warranty that I'm pretty sure should cover the replacement thanks for the help guys!
The Following User Says Thank You to zackegle For This Useful Post:
humfrz (11-13-2016)
Old 11-18-2016, 12:10 AM   #5
neo95
Hey guys seems like I'm having the same issue. As the op showed in the video I've began to notice that on cold starts in the morning same sound. Just these last two nights I began to hear a new loud screeching sound coming from the back the engine and you push the clutch in it goes away. I will post the video and would like to get your feedback if you think it's the TOB gking bad. My car is a 2013 frs with 43k
Sent from my LG-H811 using Tapatalk
neo95 is offline   Reply With Quote
Old 11-18-2016, 12:21 AM   #6
Replace the TOB before it leaves you stranded.
Old 11-18-2016, 10:39 AM   #7
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
TOB for sure.
When mine went, it damaged the pressure plate and "fingers" so those needed to be replaced as well. All because I ignored the sound for too long hoping it would go away on it's own.
Get it in ASAP. You might be lucky and have it covered by warranty like I did.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 11-19-2016, 04:46 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
someone had to point this out
guybo is offline   Reply With Quote
The Following 3 Users Say Thank You to guybo For This Useful Post:
Norville Rogers (12-03-2016), SLVRSRFR (11-19-2016), Ultramaroon (11-19-2016)
Old 11-19-2016, 05:32 PM   #9
aagun
Drives: 86
agreed replacing both .
i did the tob . then after 1k . i did clutch disk . ... i keep pressure plate on the car until now with 163k km
aagun is offline   Reply With Quote
Old 11-19-2016, 08:26 PM   #10
root
Drives: Raven FR-S
Originally Posted by SLVRSRFR View Post
TOB for sure.
Mine just went out a couple weeks ago. Exact same symptoms, almost exact same miles. Toyota told me it was not covered under warranty, I was a bit disappointed. Ended up taking it to private shop as if I wanted Toyota to proceed, they wouldn't even be able to diagnose it for two weeks.
Throwout bearing was completely toast, when they got it out, metal shards of the race, loose balls rolling around, burnt blue metal. Replaced bearing and clutch.
root is offline   Reply With Quote
Old 11-21-2016, 11:51 AM   #11
SLVRSRFR
I posted this in another thread, but I should disclaim the fact that I am known at the Subaru dealer that I go to. There's a mechanic there that I used to work with, the service advisor always remembers me by name, and the service manager knows me well and has helped me before in getting something covered under warranty that probably should not have been.
Even this time, he said he'd probably have to fight with Subaru a bit to get the claim processed, but he said "that's my problem, not yours". This is how you earn a customer for life.
Luckily my clutch itself was not affected, so I had a new TOB, new clutch fingers, and pressure plate all installed under warranty.
You owe it to yourself to at least ask. I was fully expecting it to not be covered at all, even with these guys who have treated me well in the past. So imagine my surprise and delight when he called me to tell me I didn't have to pay a cent. I was expecting to be staring down the barrel of a $1000+ repair bill.
@bpennerz
The Following 2 Users Say Thank You to SLVRSRFR For This Useful Post:
roddy (12-05-2016), Tcoat (12-05-2016)
Old 11-21-2016, 12:08 PM   #12
neo95
I've taken my car to the dealer on Saturday. They can't reproduce the noise. I show them the multiple videos I have and sent it to their email. The tech looked at the video and knows its coming from the transmission but they need to replicate it. Since I still have power train warranty and they replaced the slave cylinder and master cylinder a few months back I hoping they cover it under warranty. Also I have extended warranty and they are replace the driver door lock actuator and ac blower (clicking). So I left my vehicle there for a few days and hope they can reproduce the sound.
Old 12-03-2016, 03:47 PM   #13
root
Drives: Raven FR-S
You have a nice service advisor, lucky. I have things that should have been covered under warranty that has not been because they couldn't reproduce the problem. I've since said F it and lived with it. The service advisor told me the throwout was not a warranty item. I didn't want to deal with fighting them on any of these issues and took it to independent shop for clutch job. I'm out $2000, but I have the car running. Toyota just emailed me and told me to bring it in a couple days ago for the appointment, nearly a month after its been fixed already. LOL.
The Following User Says Thank You to root For This Useful Post:
SLVRSRFR (12-05-2016)
Old 12-05-2016, 10:38 AM   #14
SLVRSRFR
Originally Posted by Norville Rogers View Post
What on earth was this about...?
This is me commenting on the fact that the dealership I go to was more willing to pull some strings to get my repairs covered under warranty because they know me and I'm not just some random customer walking in the door demanding that a wear item be covered under warranty.
Someone walking into a dealership they've never been to before might not be so lucky and might be denied on the spot.
To preface this, the service manager helped me get an all new radio head-unit for my car under warranty a couple of years ago, when it should not have been covered by warranty at all. Long story short I disconnected my battery to do some work to the car, and when I reconnected everything, the head-unit was asking for my security password. I did not receive the password when I bought the car (as it was slightly pre-owned when I got it), and it had been changed from the factory default. Therefore my head-unit was now useless. He said normally I would have to send the unit to Pioneer to reset everything, and it would cost me $150 or so, but he got creative and claimed to them that my CD player was skipping (when it was not), and got me a new head-unit entirely covered by warranty with no out-of-pocket expense for me. So he has helped me in the past when he didn't have to, and did it again with my throw-out bearing repair. Again, probably shouldn't have been covered under warranty, but he got it done.
What was so difficult to understand about that?
@bpennerz
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 08:03 PM
HELP!!!! CLUTCH ISSUE mattaubel Engine, Exhaust, Transmission 3 07-27-2016 03:03 AM
Idle dipping when the clutch is depressed tylerdone86 Issues | Warranty | Recalls / TSB 8 06-03-2016 09:13 PM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
clutch issue yurgirlishot Issues | Warranty | Recalls / TSB 14 11-15-2013 04:20 PM
