Old 11-08-2016, 01:32 PM   #1
nammie81
Drives: 2016 frs
TRD lowering Springs
will I need a front and rear chamber kit?
nammie81 is offline   Reply With Quote
Old 11-08-2016, 01:49 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
No, but its nice if you are looking for performance, however if your going for springs performance isn't your first concern haha.
TL;DR Nope
Old 11-08-2016, 02:29 PM   #3
stevesnj
stevesnj's Avatar
Nope, install and go
My 2016 Build thread
Old 11-08-2016, 02:34 PM   #4
gramicci101
Off Topic
It isn't necessary, but it is helpful. A set of camber bolts for the front is $25, so it's not a huge sum of money to dial in some negative camber. For the rear, you'll get some camber naturally just from lowering. If that ends up where you want, then great. Nothing more is needed. If it ends up way out of whack or you want the ability to adjust, an LCA is the easiest to install and adjust. SPC works for not a terrible amount of money, it just isn't flashy. There are plenty of others that are billet aluminum and super fancy, but much more expensive.
The Following User Says Thank You to gramicci101 For This Useful Post:
Cole (12-01-2016)
Old 11-08-2016, 09:29 PM   #5
Norinradd
Drives: 2013 frs
I just did mine op. Imo camber went more negative. By atleast -.5 in the rear and front may have went a few points on the + side. But im sure every car is different and i never had an alignment previously so im throwing numbers out there.
Gramicci101 is bang on
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
The Following User Says Thank You to Norinradd For This Useful Post:
cat94 (04-18-2020)
Old 11-09-2016, 09:29 AM   #6
I am running RSR Superlows with a 1 1/2" drop. I have no camber adjustment kits and at almost 100K miles have no handling issues or unusual tire wear.
If installing yourself just be sure to follow the directions exactly to the letter. There are very specific requirements for coil placement and leveling and if you don't do those things right you can end up with some wonky camber or height issues.
stevesnj (11-09-2016)
Old 11-30-2016, 07:36 PM   #7
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
How did you perform the VSC Sensor Neutral Memorization?
MJones_RB is offline   Reply With Quote
Old 11-30-2016, 07:56 PM   #8
I didn't. It came with them from the showroom.
If you need to know how though it doesn't sound hard.
http://www.ft86club.com/forums/showt...23#post1815023
MJones_RB (11-30-2016)
Old 11-30-2016, 08:10 PM   #9
MJones_RB
MJones_RB's Avatar
Thanks! I wonder how many people who lower their cars bother with this?
Old 11-30-2016, 08:14 PM   #10
Probably just the ones that get a throw a code. Probably even less bother to re aim their headlights though.
stevesnj (12-01-2016)
Old 11-30-2016, 09:23 PM   #11
Tokay444
Does the attitude of the car change?
Why would the headlights need to be re-aimed?
Old 11-30-2016, 09:31 PM   #12
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I have not noticed any change with my headlights since I put the TRD springs on.
Twinz is offline   Reply With Quote
Old 12-01-2016, 10:20 AM   #13
stevesnj
stevesnj's Avatar
I did mine through Techstream after reading about it on here.
Old 12-01-2016, 10:22 AM   #14
stevesnj
stevesnj's Avatar
Even with the modest drop with my TRD drop I still needed to re aim my headlights. I just guessed. I don't know the aiming procedure
The Following User Says Thank You to stevesnj For This Useful Post:
MJones_RB (12-01-2016)
BRZ with TRD Lowering Springs rbatyko Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-16-2020 02:53 PM
help with lowering springs in NC tazz786 Southeast 2 03-08-2015 01:02 AM
Who has STi Lowering Springs? Raven 6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-29-2014 07:06 PM
Lowering car with springs... What else do I need? SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-25-2013 11:39 PM
which lowering springs should I get? abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-22-2013 03:27 PM
