Old 11-06-2016, 07:35 PM   #15
I had the opposite happen. It warmed up 10 degrees and my tires blew up from over inflation. Sucks!
If it went up 30 you may have been killed!
If it went up 50 then...
dvasqu01 (11-07-2016), korhun (09-02-2019), meWant (11-07-2016), Sapphireho (11-06-2016)
Old 11-06-2016, 07:48 PM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
That's why I always stop at the border and deflate my tires when I visit my brother in Phoenix. Don't want to start WWIII.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
dvasqu01 (11-07-2016), korhun (09-02-2019), Tcoat (11-06-2016)
Old 11-06-2016, 08:23 PM   #17
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Another rule of thumb is that most tires lose about 1psi a month, so that also contributes.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
jcw99 (11-08-2016)
Old 11-06-2016, 08:41 PM   #18
Originally Posted by MurderousPandas View Post
Truly. I live in south Florida and it doesn't matter how warm it can still be, a temperature drop is a temperature drop. Just a few days ago my tires dipped to 20psi from 30psi
Sent from my HTC6535LVW using Tapatalk
DANG ........ there, @MurderousPandas ......... I reckon ya'll down there in south Florida, don't subscribe to this:
PV = nRT
I'm figuring you either meant the tire pressure dropped 2-3 psi
OR
your air pressure gauge is stuck
OR
your spectacles are playing tricks on ya .....
Old 11-06-2016, 08:53 PM   #19
Yal
#subaruambassador
Yal's Avatar
Drives: Wheezy
I rotate my air every two weeks. Front air goes to rear, rear air goes to front, top off as necessary. Tires aren't moved though, that would be silly.
Yal is offline   Reply With Quote
The Following 6 Users Say Thank You to Yal For This Useful Post:
korhun (09-02-2019), meWant (11-07-2016), radroach (11-06-2016), Tcoat (11-07-2016), Ultramaroon (11-07-2016), wparsons (11-07-2016)
Old 11-06-2016, 09:17 PM   #20
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
PV = nRT
OR
OR
It was legit, on all 4 corners. I saw the light and was like "oh, just a couple pounds i'm sure", but no. Luckily an almost local gas station gives free air.
MurderousPandas is offline   Reply With Quote
Old 11-06-2016, 09:40 PM   #21
So, you're getting your air from a gas station that gives it away FREE .....
Like they say "you get what you pay for" .......
korhun (09-02-2019)
Old 11-07-2016, 07:46 PM   #22
MurderousPandas
Yup, free air. Don't know how they have the budget, that stuff is hard to find.
Old 11-07-2016, 07:58 PM   #23
It's FREE because they only use the by-product of an air compression process, where they separate out and usually discard the smaller molecules.
The smaller molecules can escape from the tire through diffusion, much more easily, thus the air pressure in the tire can decrease more quickly.
Where is that "SCIENCE BITCH" meme .....??
Old 11-07-2016, 08:06 PM   #24
MurderousPandas
Interesting, didn't think there would be any leaks with the rubber sealed along the rim, but i'm sure the seal will never be 100% perfect on the molecular level.
They use the same pump others charge for, they just hand out coins instead. Maybe they got tired of people getting $2 cashback or something lol. Maybe those airless tires will fix it, but then you can't change your pressure.
Old 11-07-2016, 08:12 PM   #25
wparsons
wparsons's Avatar
You have bad sensors if they are going off with 2psi loss. I believe they are programmed to go off if the tire is under 17 psi.
Not even close. They go off under 28-30psi. My light was on with my tires at 29psi cold on a long acre gauge, which I'd trust more than whatever the sensors are calibrated to. I end up with the light on after almost every track day when I set the tires to ~34psi hot. By the time they cool down for the drive home they're down in the 28-29psi range.
IIRC they can also go off if any one tire is off by more than 5psi from the rest, but I haven't tested that.
flickr
Old 11-07-2016, 08:26 PM   #26
Well, the air molecules "diffuse" through the rubber that the tire is made of, just not along the bead.
Now, if those smaller molecules, who have an inferiority complex, get heated up, they move faster around the rubber molecules, thus escape quicker.
Yep, solid tires would sure solve that deflation problem.
Back in my grandfathers day, they NEVER had tires with too low a pressure, nor did they have any flat tires.
Looking at some of these "low profile" tires on the wagon wheel sized rims, these kids put on cars today, it appears they are heading back that direction.....
Old 11-07-2016, 08:43 PM   #27
In YOUR grandfather's day I am pretty sure they didn't even have wheels yet!
humfrz (11-07-2016), korhun (09-02-2019), Ultramaroon (11-07-2016)
Tire Pressure and Temperature Gauges recommended for track use Toyarzee Tracking / Autocross / HPDE / Drifting 16 01-26-2016 08:23 PM
Innovate MTX-D Oil Pressure/Temperature, full set-up malave7567 Interior Parts (Incl. Lighting) 4 12-17-2015 06:10 PM
Oil Pressure and Temperature Guide Video Dezoris Engine, Exhaust, Transmission 25 05-19-2015 02:51 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 06:09 PM
