Old 11-05-2016, 07:08 PM   #15
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I would get a second opinion on the install itself, as well as the alignment.
If all else fails here are some adjustable rear lcas for a decent price.....http://www.ft86club.com/forums/showthread.php?t=112652
Old 11-05-2016, 07:23 PM   #16
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Stance LCA will lower his rear more.
Old 11-05-2016, 07:25 PM   #17
Summerwolf
Panda Trueno
Summerwolf's Avatar
True, but would make his camber adjustable and he seems to be on a budget.
Whiteline or spl would be cheaper anyways, lol.
Old 11-05-2016, 07:30 PM   #18
Norinradd
Drives: 2013 frs
I did overlook this step last night.
Does the pic work? Ill have to get under there when its dry out and see wich ends are pointing which way
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-05-2016, 07:37 PM   #19
Summerwolf
Panda Trueno
Summerwolf's Avatar
That is probably your issue. One spring isn't situated correctly.
3:06 or so...
Old 11-05-2016, 07:50 PM   #20
Norinradd
Drives: 2013 frs
We shall see. I guess that will be my issue if so!!
Old 11-05-2016, 07:55 PM   #21
Norinradd
Drives: 2013 frs
3:06 or so...
Yeah watched every video on youtube before i did the install.
Did you see my photo. Says one end needs to point to rear other to front. Which he doesnt mention. Nor does any other installer. The springs are seated properly in their perches. I just will have to see if the ends are pointing in the correct direction
Old 11-05-2016, 08:55 PM   #22
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Originally Posted by Norinradd View Post
Installed trd lowering springs and dropped car off to be aligned. Got call back saying rear camber is at -2.5 and -.9. Tech saying he cant adjust rear in the green. Saying something about "slotting" something as an adjustable arm isnt possible. I apologize. I know solid axles in 4x4s. Not to familiar with these independent setups. I have no idea what to do. Whats my cheapest option?
When I installed TRD springs, the post-alignment rear camber wasn't even. The important part is to get your toe zeroed out. A degree of camber is sub-optimal, but it won't destabilize the car or burn through tires.
IIRC, we ended up with 2.1 & 1.0 degrees. It has felt great for daily driving and autocross this season.
If you need it even, SPC is the cheapest lower control arm option. It's hard to justify other LCA's unless you're dropping much lower (or you just like car jewelry).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 11-05-2016, 09:21 PM   #23
Norinradd
Drives: 2013 frs
Rear camber crazy from .75" drop
Yah toe is great. Its just rear right camber thats in the red. I dunno man it looks really weird. One tire is tucked into sidewall and the other pokes out quite a bit. Im assuming the direction the coil end is pointing is off. If its not the coils and its installed correctly.
What about lca bushings? Dont they allow for +\- .5 degree? Would let me get one side to -1.5 and -2.0. Much closer.
Old 11-05-2016, 11:58 PM   #24
Norinradd
Drives: 2013 frs
I also think theres a little clunk on rear corner that is -2.5. Im going to re install the rears making sure ends are pointed in proper direction. Then pay for another alignment
Old 11-06-2016, 08:53 AM   #25
cjd
cjd's Avatar
Drives: 2017 BRZ
You'll pay with the bushings in labor...
Did you have similar difference in the tires before the springs? If not, something seems to have changed somehow with the install. I am unsure what it might be since there really is very little wiggle room on the rear install. I suspect the camber has always been off.
Old 11-06-2016, 11:05 AM   #26
Norinradd
Drives: 2013 frs
Not that i noticed. Looked fine before!! And how will i payvwith bushings jn labour? I dont want new lca as i dont want to be any lower in rear!!
Old 11-06-2016, 11:13 AM   #27
Summerwolf
Panda Trueno
Summerwolf's Avatar
Bushings have to be burned or pressed out for replacement. So there is labor costs.
Only certain rear lcas lower you.
Old 11-06-2016, 11:20 AM   #28
cjd
cjd's Avatar
Drives: 2017 BRZ
Assuming you refer to the whiteline bushings that allow camber adjustment in the rear... They're a pain to work with. That eats time, which costs (either good will if its a fixed rate alignment or in hourly rate).
Rear LCA won't make you lower unless you go with a lowering LCA like the Stance. Whiteline won't, and is among the lower cost options.
There really is no room for geometry change in the back beyond bushing compliance. That's a possibility, you mention noise IIRC. Verify full range of motion without binding without the shock, and be sure it installs easily as a place to start checking.
FS: New H&R TC112 Rear Camber Bolts, PAC 2.5" Helper Springs customfab87 Brakes, Suspension, Chassis 0 02-08-2016 10:41 PM
Fitment with -2 Camber and 1" Drop 18x9.5? ajcarson11 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-26-2015 01:29 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
