#71 |
Drives: g37 - 370z
how do you guys store your car for winter?
#72 |
Little Member
Drives: Bloo - The 13' BRZ
If you read the rest of this thread, people tell you that exact thing
#73 |
I just have it crushed and buy a new one each spring. They are starting to take up a lot of space in the back yard though.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | i heart ricers (11-04-2016), yelsew (11-04-2016) |
#74 |
Drives: g37 - 370z
#75 |
Get a hermetically sealed garage.
Be careful to not accidently get a hermaphroditly sealed one though since THEY ARE NOT THE SAME THING (believe me).
| The Following User Says Thank You to Tcoat For This Useful Post: | BWilky (11-04-2016) |
#76 |
I park it with a full tank of gas, drain the summer washer fluid (garage isn't heated), make sure the tires are properly inflated and park it on these http://www.princessauto.com/en/detai...le/A-p8588402e . Other than that, nothing else that I can think of.
#77 |
Drives: GT86 raven
Hey guys, i've read through the thread and have some questions.
First off, my car will be in a underground garage under the house so it's somewhat moderately temperatured although not heated per se. According to what i saw most people say here i won't start it at all during the winter period. Now, since i don't have an outlet anywhere near the car i can't charge the battery in any way, so i'm assuming it's best to take out the battery and charge it a couple of times during the winter and then put it back in when summer comes? Are there any things to consider when taking out the battery? for example in my last car you couldn't access the radio at all if you ever disconnected the battery unless you input some code, does the GT86 have anything like that? I bought mine used so if yes i'd have to check the documents first to see if I got it. I'm going to fill up the tank and have a question about those additives, i've never heard of them before so i have no clue which to get and how to use them, how bad is it to skip them all together and are there any easy guides as to which one to use and how much to put in? Someone wrote that you should put steel wool into the exhaust pipes or wrap them up somehow, can someone explain why? How important is the car cover? The oil got changed 2000km (~1200miles) ago, how bad is it to not change it again now? I'll be pumping up the wheels a bit more than they are atm and will be pushing, pulling the car a bit forward/backward every week to avoid the flat spots. Am I missing anything? Sorry for the long post but this is the first time i'm going to store a car during winter and i don't want to make any mistakes |
#78 | |
Se bold.
| The Following User Says Thank You to Tcoat For This Useful Post: | inferno56kb (11-10-2016) |
#79 |
Drives: g37 - 370z
how do you guys store your car in winter?
#80 |
Mr.Fujitsubo
Drives: 2018 STI
We don't. It's all in your imagination.
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#81 |
Drives: g37 - 370z
#82 |
Little Member
Right, It literally cannot be done. You can say goodbye to your warranty, that is, if the car isn't totaled.
#83 |
In Canada they void the warranty if you don't drive it in the winter. Says so right in the documents.
#84 |
Drives: GT86 raven
Thank you for the answers TCoat
i will be finishing up the prepping today found some additive as well and i'm going to skip the steel wool then.You're right and it probably won't affect the car as much as i imagine, but i'm a bit OCD when it comes to my car ^^ Update: Here she is, prepped and stored, thanks for all the info guys ![]()
| The Following User Says Thank You to inferno56kb For This Useful Post: | Tcoat (11-10-2016) |
| Winter Storage Questions | Newtothegrounds | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 08-26-2015 12:41 PM |
| Winter Storage | xia | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 10-06-2013 10:04 PM |
| Winter Storage | Luke.Cariveau | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 11-18-2012 06:15 PM |
| Change oil before or after winter storage... or both? | switchlanez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 11-07-2012 04:30 PM |
| Winter storage | Skye | BRZ First-Gen (2012+) — General Topics | 7 | 10-03-2012 09:02 PM |
