| Engine Swaps Discussion of engine swaps. |
#29 |
Drives: Nissan GT-R
subbed.
#30 |
Drives: Hydra EMS Powered FRS Raven Black
Hydra EMS is plug and play with full CAN support to run FA20, EJ, and 2 JZ. Everything works but cruise control and traction control is handled by the Hydra EMS so it's programmable. We just supply you with a plug in harness and then give you a few extra flying leads to wire in the extra cylinders.
I don't have 2JZ maps but they have been around for years so I'm sure I can get someone close on the ignition timing map but the fuel map will need some work for sure. All oem dash functions, traction/stability controls, ABS, climate control, and power steering. It's also direct plug and play with AIM CAN dashes or AIM Solo DL which I use for racing. If you have any questions just let me know. Phil |
#31 | |
Drives: 2015 frs
#32 | |
Drives: 4-Runner Sport - 13' BRZ SportTech
Just to confirm, this will plug and play into the car, retain all canbus functions, and will run a different motor (obviously with re-pinning/wiring) http://elementtuning.com/store/#!/El...ategory=439245
Top Tier Imports - Check out my build journal HERE
#33 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
It's confirmed that Emtron works. I just got back from driving the car. EPS, tach, fuel level, coolant temp, speedometer are all working. @Ross will be using the Emtron to control traction control.
![]() ![]() ![]() [ame="https://www.youtube.com/watch?v=B8Bne1XCBLg"]2JZ FRS Idle - YouTube[/ame] [ame="https://www.youtube.com/watch?v=T3lDx5ptZYw&nohtml5=False"]2JZ FRS low speed drive-ability - YouTube[/ame]
| The Following 2 Users Say Thank You to slicktop For This Useful Post: | Jeff Lange (06-06-2016), tirespin782 (04-08-2016) |
#34 |
Drives: Scion FRS
Im currently doing a 1jz swap into my FRS and am also looking for wiring options.
I would be very interested to find a plug and play system that will work! |
#35 |
There are exactly zero plug and play systems on the market. Good luck with your swap!
#36 |
Drives: Scion FRS
LOL I know there are no plug and play options.. This guy was saying he was making one?
Im planning on running a Motec M130. |
#37 |
Drives: 2JZ FRS
We are working on it still. Taking longer than we wanted but we are testing everything before it goes anywhere near a car that's not our own 2j and ls test cars
| Tags |
| 2jz, ecu, swap, wiring |
| Wiring in IAT for SD | mrk1 | Software Tuning | 13 | 04-14-2023 08:15 AM |
| Need some help with some wiring | timmydatooth | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 08-14-2015 09:10 PM |
| Wiring for DRL | Yap | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 01-19-2015 01:13 AM |
| LF VA Wiring Help | OURO3OROS | Mid-Atlantic | 0 | 02-23-2014 08:24 AM |
| Sirius(ly) Irritated | poudre | BRZ First-Gen (2012+) — General Topics | 12 | 07-15-2012 11:06 PM |
