Old 10-31-2016, 11:45 AM   #29
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
The upcoming CSG exhaust may be your answer.
It passes the 90dB Laguna Seca test, as well as the "Irvine" test, with boost, without cats, and E85.
oh when does it come out and how much does it cost? im from PA, and have no idea what the laguna seca test, or "irvine" test are.
morswestford is offline   Reply With Quote
Old 10-31-2016, 01:39 PM   #30
CSG Mike
CSG Mike's Avatar
Laguna Seca is a track with strict noise restrictions, stricter than what is Legal in california.
Irvine has draconian noise enforcement. If your car can drive in Irvine without getting pulled over, it means you won't be pissing your neighbors off.
whataboutbob (11-02-2016)
Old 10-31-2016, 04:06 PM   #31
morswestford
oh, and when will it come out and how much does it cost
Old 10-31-2016, 04:24 PM   #32
Icecreamtruk
Drives: Track preped NA FRS
That is the question that has been going on around the forums for close to a year now? I have no idea of how long it will take, but based on the amount of research I can tell you it wont be a cheap alternative thats for sure. Im waiting on it as well, since my longterms plans include a JRSC and it seems thats what this system is being tested on. We'll see when it comes out I guess.
Icecreamtruk is offline   Reply With Quote
Old 11-02-2016, 03:00 PM   #33
morswestford
Originally Posted by toeout View Post
That's exactly right. It seems expensive upfront, but it's where you'll arrive after going through different frontpipes, midpipes, resonators etc. Only Borla's muffler is big enough to make a meaningful difference and they are the only ones who make something that big for that spot under the driveshaft.
I'm not sure how old your Perrin system is, but my Invidia Q300(itself touted as one of the quietest systems for our car) got louder after 2 years. I went through various Magnaflow resonators ( didn't last over 6 months ), Flowmaster Hushpower muffler (didn't quiet it down enough) and combination of the two. In the end only Borla made a significant difference, as it should since it's big enough to be a main muffler.
I only wish I'd bought Borla earlier before spending money on all the other stuff. Also you can get it for less than $900, I bought mine from FRSport.
is your car supercharged as well? is there any loss of power going with the dual muffler setup? will i lose any power going this route? i think im set on replacing my front pipe with the catted quite pipe from JDL, as well as doing this dual muffler setup, but i was wondering if theres any loss of power from that? would i also need to get my car retuned?
Old 11-02-2016, 04:18 PM   #34
toeout
My car is not supercharged. I felt no loss in power, Borla's muffler is a straight through design. I didn't get a retune, because that muffler in that spot is no different than a stock or aftermarket resonator, only difference is more canister volume.
I would buy the muffler first and then see if you still need to change out the front pipe. IMO the resonators on all the aftermarket front pipes are so small, the they make very little difference sound wise.
toeout is offline   Reply With Quote
The Following User Says Thank You to toeout For This Useful Post:
calic (11-05-2016)
Old 11-02-2016, 04:26 PM   #35
morswestford
sounds good thx for the advice. think ill go with this setup. i asked my tuning shop about needing it retuned but they are away at SEMA. i guess it probably doesn't need it anyways.
The Following User Says Thank You to morswestford For This Useful Post:
calic (11-05-2016)
Old 11-02-2016, 06:07 PM   #36
calic
calic's Avatar
Drives: Subaru Brz
I'm running into a similar problem as op. Does the borla muffler bolt up to the perrin?
2015 WRB Limited Sti
Instagram: limitedbreeze
calic is offline   Reply With Quote
Old 11-02-2016, 06:19 PM   #37
toeout
It does not. It bolts up to the front pipe, but the connection to the axle back has to be welded together. Good spot for it is the straight section after the Borla muffler, you can see it on my picture.
calic (11-02-2016)
Old 11-05-2016, 04:32 PM   #38
calic
calic's Avatar
Drives: Subaru Brz
So this is for anyone running into this problem and is cheap like me.
I kind of followed your advice. I'm running the unresonated perrin 2.5, so I took our stock mid pipe resonator and cut it. And had my shop weld it to the perrin midpipe. Basically it's the same thing as the perrin mid pipe except they want 300 bucks for it. The car has no more rasp and sounds like it should of been loud, but not to loud.
I feel like I can change the front pipe out without killing my ears now. Thanks again for the inspiration and a easy mod to do. As long as you didn't sell your stock parts.
borla, cold engine start, invidia, jackson racing, perrin
Extremely Hot Weather - Engine Oil Viscosity Guru86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 11-22-2017 10:07 AM
Halp! Supercharger extremely loud autograph Forced Induction 15 09-24-2015 04:32 PM
Loud engine noise? Rifle Engine, Exhaust, Transmission 9 08-16-2015 12:26 PM
FR-S Loud Engine Noise White0utFrs Issues | Warranty | Recalls / TSB 15 09-20-2013 08:28 PM
Engine is quite noisy Rob_g Issues | Warranty | Recalls / TSB 9 10-14-2012 08:41 AM
