Old 10-29-2016, 11:17 PM   #43
cf6mech
Drives: FRS Silver LS1 swapped.
Was under the impression Vorschlag exhaust (long tubes back) will be part of a stage in a kit, I could be wrong though, I do have issues with it if you want to PM me. Personally I would do your own exhaust solution, you almost have to go with shorties or stock manifold on this car unless you want to introduce all sorts of other issues, trust me I'm living with them and as soon as I can these long tubes are going bye bye. What ever gains I lose can easily be made up elsewhere.....just saying, others may have the patience or make them work. Originally it is not what I wanted anyway, but I took one for the team... LOL!....stupid me.
cf6mech is offline   Reply With Quote
Old 10-30-2016, 10:15 PM   #44
ILLSMOQ
Drives: 2017 WR BLUE BRZ
I hear what you're saying about about exhaust clearance and tight fitment issues...I've had to bang and dent some headers and exhaust in the past to make them fit right. I ran across this video today and it's worth watching.
ILLSMOQ is offline   Reply With Quote
Old 10-31-2016, 08:18 AM   #45
M1K3
M1K3's Avatar
Drives: vrooom...
You should take a look at the new video that came out today:
[ame="https://www.youtube.com/watch?v=Y7_lSU3D0jw"]Power Test: Cast Manifolds vs. Headers - Engine Masters Ep. 15 - YouTube[/ame]
Sorry for Thread Jacking
M1K3 is offline   Reply With Quote
Old 10-31-2016, 09:47 AM   #46
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
How about some $150 Up/Forward or Down/Forward Turbo Headers. Then you just have to route a downpipe or two AND make crazy power.
eBay LS Turbo Header
Old 10-31-2016, 10:31 AM   #47
ILLSMOQ
In that second video...Are those cast iron hooker manifolds the ones you were talking about @cf6mech?
Headers are almost always a pain to install...but I love what long tubes do for the sound of the exhaust, for me the power gain is secondary. With heat and clearance being such an issue on this car, I'll definitely be having them ceramic coated inside and out.
Old 10-31-2016, 01:20 PM   #48
cf6mech
Heat issues cooking rear brake lines and having oem placement of front sway bar, among other issue....
Old 10-31-2016, 01:40 PM   #49
cf6mech
Great video and the reason why I'm opting for the cast iron Hooker manifold, my engine is stock and makes more than enough horsepower for my purpose, having them explain on a stock engine long tubes make little to no difference was helpful .
Old 11-01-2016, 09:14 AM   #50
HTA_EVO8
Drives: Blue lotus exige
Disclaimer, I did not watch the video so don't know what the result is
But you Need a tune to get the gain from the long tube and you will need a tune for the swap
HTA_EVO8 is offline   Reply With Quote
Old 11-01-2016, 09:40 AM   #51
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
That is common knowledge.
Old 11-01-2016, 09:41 AM   #52
DustinS
DustinS's Avatar
Clutch, Fuel Fittings, and exhaust should be here today. Though my Summit Racing order says it is out for deliver in a town about 30 minutes outside the city I live it. So we will see if it actually arrives. Going to give them a call and double check.
I think I am going to try and make a video documenting the swap so other have something to go off of.
Old 11-01-2016, 10:07 AM   #53
M1K3
M1K3's Avatar
Drives: vrooom...
Please do, and it doesn't have to be too long, just even a run down of all your parts would be awesome.
Old 11-01-2016, 01:55 PM   #54
DustinS
DustinS's Avatar
Summit Order Came in. I went ahead and opened it (mostly because I am not patient enough to wait) because my Grandpa is almost as excited for the project and wanted to see what came in. (Though he said buying a '57 Chevy would have been easier).
I'll get a video of the Summit Packages/whats inside, as well as the exhaust.
Old 11-01-2016, 07:15 PM   #55
HTA_EVO8
So everybody know you need a tune
But if you gonna go through the hassle of swapping then it's worth Going the xtra mile to include the long tube.
400whp maybe a lot of power at lower speed in lower gear but doing highway pull in 3rd and taller gear you gonna find out you need another 100hp or so to take the car into the 10s
With the twin 400whp will only take it to about a high 11s , Im guessing based on my FM built LS3 NB Miata which currently weigh in at 2667lbs and pull 400whp on a dyno jet
Old 11-01-2016, 10:19 PM   #56
ILLSMOQ
What's in the box dude!
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
