Old 11-01-2016, 12:46 AM   #43
benlaz88
Drives: 2013 Asphalt FRS
Originally Posted by VeloxEric View Post
I think the bolded statement is a good test to prove the theory.
I want to clarify OP's statements as they're a bit confusing currently. Benlaz88, could you please clarify if the below statements are all true?
1) The noise exists with the car out of gear, clutch depressed?
2) What happens with car out of gear, clutch not depressed?
3) The noise goes away when the car goes into gear, clutch depressed?
That is not a good sound and something I can honestly say I have not heard before.
Thanks,
Eric
1) Noise does not exists when car out of gear. No hissing sound when clutch depress until trying putting into gear. When gear is block, i put back into neutral the hissing sound stop.
2) No hissing sound when car out of gear and clutch not depress.
3) This is the weird part, When i able to get into 5th, the sound still exists but than i put it back to neutral and clutch still depressed, the hissing sound is gone. Gear goes it smoothly after that.
Here a scenario i have noticed. When i able to get into reverse, i have a time hard time to put back in neutral. Again it felt like something is blocking me. After work my way out of the gear, it wont let me put back into 1st gear right away. I have released my clutch and depress back and try to get into 5th gear. When i able get into 5th gear, i put it back into neutral, hissing stop than 1st gear goes in smoothly.
When also noticed that the longer i drive the easier the gear goes in. Until the car cool down, the situation happen again. There is no shifting problem when car is moving.
I am still thinking it the clutch causes all this issues.
Again, i am really appreciated everyone who trying to help me figure this out.
benlaz88 is offline   Reply With Quote
Old 11-01-2016, 01:38 AM   #44
Everything you said points to clutch dragging.
Drakiv (11-01-2016)
Old 11-01-2016, 01:39 PM   #45
benlaz88
I just depress the clutch, hissing sound occur when in neutral. I prob have to take to a diff shop and see what going on.
When I start the car in fist car did not move at all however when the gear block me from getting into gear, the car did move little bit
Sent from my SM-G935V using Tapatalk
Old 11-01-2016, 05:26 PM   #46
Did you get the hissing sound when you started the car in gear?
Old 11-01-2016, 05:31 PM   #47
benlaz88
Nope
Old 11-01-2016, 08:51 PM   #48
Nope
Wow, ok. Your clutch is dragging but I'm out of guesses for that sound.
Let us know how it turns out.
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Anyone experiencing 2nd gear problem? seominjung BRZ First-Gen (2012+) — General Topics 37 08-15-2015 12:32 AM
2nd Gear Syncro Problem nashsnazzy Issues | Warranty | Recalls / TSB 22 07-14-2014 09:20 AM
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
