Old 08-24-2016, 02:25 PM   #1
benlaz88
Drives: 2013 Asphalt FRS
Gear problem....
I have replaced my clutch with South Bend Stage 2 Endurance. I have be breaking in for for 1000 miles now. While the breaking in process, i notices when i in a complete stop evertime, it won't let me get into gears, it seem like something is blocking me. Not only just 1st gear, it happen in in all gear include reverse. It will take me a while to get it into gear in a complete stop. Any ideas what cause it? I am thinking is the slave cylinder.
Thanks in advance!
Ben
benlaz88 is offline   Reply With Quote
Old 08-24-2016, 02:40 PM   #2
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
It is quite likely the clutch fork is bending and not fully disengaging the clutch. This is becoming quite common.
http://www.ft86club.com/forums/showthread.php?t=104963
VerusEric is offline   Reply With Quote
Old 08-24-2016, 02:43 PM   #3
benlaz88
I forgot to mention, if hold the clutch in for about 5sec, it will go in gear very smooth. So would the fork still cause the problem in this case?
Old 08-24-2016, 02:52 PM   #4
No issues when shifting while moving? All is smooth then?
Old 08-24-2016, 02:55 PM   #5
benlaz88
That is correct, shift like a butter when moving. Only happen when in complete stop.
Old 08-24-2016, 03:39 PM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Clutch is dragging. You're still in the friction zone when your foot is on the clutch.
Did you ever adjust the pedal closer to the floor?
Did a previous owner ever adjust the pedal?
99% of the time, that's the problem. By removing travel from the pedal, you reduce the travel of the slave cylinder.
If both answers are no, you may be experiencing enough flex in the clutch fork to experience dragging. In that case, you may want to buy a stronger one.
Either way, I would bleed the system and check the pedal height first. If you have air in the line, the slave cylinder travel will be reduced.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 08-24-2016, 03:49 PM   #7
benlaz88
Yes, i have adjusted my pedal before with the same height as the break pedal. I will try to adjust my pedal back higher to see if it will solve. I also has try bleeding the cylinder. I will report back if that will fix my problem.
Thanks!!
Old 08-24-2016, 04:19 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Not probable but another possibility is that the clutch hub was not properly lubricated during installation, making the clutch drag.
Old 08-24-2016, 05:09 PM   #9
VerusEric
VerusEric's Avatar
I know this isn't what you want to hear @benlaz88 but this sounds exactly like the clutch fork issues we've seen/heard, and ultimately fixed with our machined unit.
Here are some testimonies from that thread:
http://www.ft86club.com/forums/showp...4&postcount=64
http://www.ft86club.com/forums/showp...0&postcount=95
http://www.ft86club.com/forums/showp...&postcount=105
Here's a guy with a South Bend Stage 2 without issues with our clutch fork, perhaps contact him? http://www.ft86club.com/forums/showp...&postcount=106
I hope you can get around it with adjusting the clutch pedal but I have a feeling that is a band-aid for what is truly happening. This is a real issue with these cars when installing upgraded pressure plates.
By the way, I am local so we can meet up sometime and visually show you the Velox unit vs. OEM.
Thanks,
Eric
Old 08-24-2016, 08:11 PM   #10
humfrz
Clutch is dragging. ...............................Either way, I would bleed the system and check the pedal height first. If you have air in the line, the slave cylinder travel will be reduced.
@benlaz88 .......this would be my first course of action.......you might get lucky.....
humfrz
Old 08-24-2016, 09:27 PM   #11
benlaz88
Thank you everyone for all the help. I will check back in and let you all know if it the pedal adjustment problem.
Sent from my SM-G935V using Tapatalk
Old 08-24-2016, 09:52 PM   #12
VerusEric
VerusEric's Avatar
If you need an extra pair of hands, or a foot , feel free to stop by someday to bleed the system.
Old 08-25-2016, 09:38 AM   #13
Spartarus
...Just add nauseum
Spartarus's Avatar
I do find it interesting, though, that we're talking about 2 virtually identical full-face organic discs, the only difference is one has a much heavier pressure plate, and suddenly the pedal travel is insufficient.
If it turns out to need adjustment, it all but proves your point about fork flex... Unless they screwed with the fulcrum rings, and messed up motion ratio to keep the pedal "feeling light"
That said, I never liked the "clutch adjustment" DIY. The OEM spec'd a certain pedal travel, because full-face organic discs drag for a fair distance after they disengage. the friction zone makes up a healthy portion of the clutch travel. They didn't build in "extra pedal travel" just to irritate people. The slave cylinder self adjusts to take up the slack.
Now, If one was swapping out for pucks, could they get away with going closer to the floor? absolutely.
-Spartarus
Old 08-25-2016, 03:15 PM   #14
benlaz88
Ok, so i went to re-adjust the pedal above the break, its still have the same problem.. Also i have noticed when clutch is press and gear block from going in, i hear some hissing sound as well.
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Anyone experiencing 2nd gear problem? seominjung BRZ First-Gen (2012+) — General Topics 37 08-15-2015 12:32 AM
2nd Gear Syncro Problem nashsnazzy Issues | Warranty | Recalls / TSB 22 07-14-2014 09:20 AM
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
