Old 10-29-2016, 01:18 PM   #3249
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Hyperblu View Post
So they dont have the wheels I want, but they have similar size but with a +45 offset, im not too good with offsets so Im not really sure if they fit?. Im reading up on it but if theres any threads out there with info I could use I'd really appreciate a link. Thanks!
Sent from my SAMSUNG-SM-G930A using Tapatalk
17x9 +45 with a 245/40 will need a 3mm or larger spacer in the front to fit with springs.
Read the Rpf1 thread. 17x9+35 and 17x9 +45 are some of the most popular sizes. Lots of good info on how to make them fit.
http://www.ft86club.com/forums/showthread.php?t=58908p,
Old 10-29-2016, 01:29 PM   #3250
swarb
+45 won't fit without rubbing the strut. And probably rub the sway bar under full lock. You must run a spacer and get the offset into the mid to high 30's to avoid rubbing on a 9x wheel.
Like I mentioned for the +35, you will have around 10mm of clearance, +45 is 10mm difference aka 0 clearance.
The Following User Says Thank You to swarb For This Useful Post:
Leonardo (10-29-2016)
Old 11-04-2016, 11:22 AM   #3251
nammie81
Drives: 2016 frs
18x9 +30 offset
I want to not stretch tires install TRD springs with stock shocks.
will this fir without rubbing?
18x8.5 +30 offset?
I don't want the rims poking out and no stretched tires? would this fit better?
nammie81 is offline   Reply With Quote
Old 11-04-2016, 12:18 PM   #3252
bored@work84
bored@work84's Avatar
Drives: H8R 86
Just purchased a set of SSR's gtv02's 18x9.5 +40.
will this set up be ok on stock height if not what will i need to make them fit with no problems.
also what size tires would be recommended for this set up. thanks in advance
bored@work84 is offline   Reply With Quote
Old 11-05-2016, 03:09 PM   #3253
bored@work84
Drives: H8R 86
went through the wheel tire directory and i think i should be ok on stock height with 18x9.5 with a 40 off set with out needing a space. i was thinking of running a 235/40 or 245/40 all around and i should still be ok. any sugestions would be great also
Old 11-07-2016, 03:42 PM   #3254
CatalystPLUR
That Auto Guy
CatalystPLUR's Avatar
Drives: Ultramarine FRS
Will stock 215/45 Fit on 17x8 Wheels with out any problem?
CatalystPLUR is offline   Reply With Quote
Old 11-07-2016, 07:03 PM   #3255
nima314
Drives: Subaru BRZ 2017 (almost)
Why not 245/35? Almost identical to stock diameter
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 11-07-2016, 07:04 PM   #3256
nima314
Yes you can fit up to 245 wide tyre on stock suspension with the right camber. Refer to meaty tire thread for exact specs
Old 11-08-2016, 04:52 PM   #3257
boateye
Drives: Blue 2017 Subaru BRZ
Hi all
I'm looking to pick up some new wheels and tires for my new 2017 brz. Im new to modding cars, but I've been reading up on different mods, tunes and upgrades. sorry if my question is noobie.
I am planning on lowering the car by 1" at a later date(dunno exact parts yet) and upgrading to a bigger brake kit. I've been looking through the wheel fitment guide to answer my question but I can't seem to parse it.
Can a squared set of Forgestar F14 18x9 wheels on 235/40 Michelin pilot super sport fit on a stock brz without the need of rolling fenders or changing camber or the wheels hitting the strut or tires rubbing? If so, at which offset (these are a custom order so I can get any offset between +20 to +55). As long as the wheels are nearly flush(+/- 10mm), I am ok.
I am looking to be able to just pop these onto my brz and go with no issues. If that's not possible with the above set of wheels, would 8.5" wide squared wheels work?
Thanks in advance!
boateye is offline   Reply With Quote
Old 11-11-2016, 10:33 PM   #3258
nima314
Originally Posted by boateye View Post
Hi all
Thanks in advance!
Up to 245 with a 9" will fit on stock with 40ish offset. I would suggest 245/35 it's the closest diameter to stock. Refer to meaty tire thread
Old 11-11-2016, 10:36 PM   #3259
boateye
Originally Posted by nima314 View Post
Up to 245 with a 9" will fit on stock. I would suggest 245/35 it's the closest diameter to stock. Refer to meaty tire thread
Thanks! I peeked at that thread but the op considered 255+ to be meaty so I stopped reading. I'll take another look, though!
I wanted to do 235/40 because when I saw it in pictures, the tire seems to be perfectly flush with the wheel and I like how it looked:
However, is that OD too far from manufacturer spec sheet it would set some sensor off or cause other issues?
EDIT: my mistake, this is actually an 18"x8.5 wheel in the front with 235/40 tires.
Old 11-13-2016, 08:55 PM   #3260
bored@work84
Drives: H8R 86
will i have any rubbing issues. planing on buying coils and lowering the car but not slammed
Old 11-13-2016, 11:10 PM   #3261
nima314
Nah they fit on stock suspension. Are you getting coils before or later on?
Old 11-13-2016, 11:30 PM   #3262
bored@work84
Drives: H8R 86
later on. right now im just looking into getting tires and getting them on. Thanks for the info
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
