Old 09-30-2016, 06:12 PM   #4201
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
You know my vote Weds!
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 10-04-2016, 01:38 PM   #4202
ModBargains.com
ModBargains.com's Avatar
300+ pages later and he is still responding... incredible - well done!
ModBargains.com is offline   Reply With Quote
The Following 2 Users Say Thank You to ModBargains.com For This Useful Post:
funwheeldrive (10-05-2016), hpde_addict (10-13-2016)
Old 10-05-2016, 11:50 AM   #4203
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
@CSGMike
Thanks guys for the fast shipping for my XP10s made it in time for my MSR-H. Still learning the pad, came from Cobalt XR2 compound before hand on stock calipers
#TrackDayBro
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
CSG Mike (10-05-2016)
Old 10-05-2016, 12:16 PM   #4204
CSG Mike
CSG Mike's Avatar
Originally Posted by Kuri View Post
@CSGMike
any thoughts on the compound differences? Feel, bite, modulation, etc.
CSG Mike is online now   Reply With Quote
Old 10-05-2016, 01:13 PM   #4205
kch
Senior Misanthrope
kch's Avatar
I'm in the exact situation as above -- stock w/ XR2 changed to AP + XP10. Still running XR2s in the rear. Initial bite seems softer with the XP10s, and requires more pedal pressure to get the same sort of stopping power. I'm not sure if that's the pads or the AP kit. Modulation I feel is about even between the two pads.
I was spoiled by the XR2s not really needing to be bedded in. Sure, they were better when bedded, but I could go out in the morning for a warmup session and they'd be fine. The XP10s are near useless for the first few applications. That's a minor issue, though.
I'm not experienced enough to give more specific feedback. Overall, though, they're working out great. I kind of like having a more aggressive pad in the rear. It feels like I can brake late, trail brake some, and get some good rotation by really throwing it into a corner. That could be my imagination, though.
The Following User Says Thank You to kch For This Useful Post:
Old 10-05-2016, 02:03 PM   #4206
CSG Mike
CSG Mike's Avatar
Dead on. That's the pad, not your AP kit. The Carbotechs are more compressible, but that's why I like to recommend them to beginners; it's a much easier transition from street pad to Carbotech, than from Street pad to sintered metal race pad.
kch (10-05-2016)
Old 10-05-2016, 03:06 PM   #4207
kch
Senior Misanthrope
kch's Avatar
Quick question. Do I need to be concerned about the slight lip that my inner front pads are developing? I swap them inside/outside between events. But last time, when I removed the inner pad, the lip was a good chunk of pad material and just fell off.
Old 10-05-2016, 03:53 PM   #4208
CSG Mike
CSG Mike's Avatar
Not particularly, but you can take a file and add a chamfer to prevent it from happening.
dp1 (10-05-2016), kch (10-05-2016)
Old 10-05-2016, 07:28 PM   #4209
dp1
driving smoother faster
Drives: Sold
Got a track related question? I'll try to answer.
AP Sprint and G-Loc R12 - I keep using pads in the same locations. Swapping caused a bit of uneven rotor wear though no impact on performance. Filing off the inside radius edge on the inner pads helps a little with brake squeal though it's temporary and not necessary. Most of the lip will crumble away as pad gets used up.
dp1 is offline   Reply With Quote
Old 10-19-2016, 03:25 AM   #4210
brzest
Drives: '15 BRZ
Yes another tire question, but one I have not been able to get an answer to..
Looking for a track tire for next season, since prices/availability seems to be very different in Europe (vs. the US), I'd like some feedback with those options.
I usually do about 10-15 minute sessions, ideally looking for a tire with the most possible grip, but also don't want them going off, with half the tread left.
Basically I've come up with 3 options:
1. Toyo R888R (costs about 230 euros in stock size), alot of my friends are using them with good results, they claim grip lasts even when thread is basically gone.
2. Yokohama A048 (roughly 270 euros in stock size), hear conflicting stories about them loosing grip suddenly, when they still have plenty of tread.
3. Michelin Pilot Sport Cup 2 (roughly 160 euros in stock size). Probably less grip / more of a street tire than the first two? Also hear different stories about how they grip when not new anymore.
I just checked tirerack and was amazed at the prices in the US, the cup2's are more than double, what they are here, and R888R's are basically half of what they are here...
brzest is offline   Reply With Quote
Old 10-19-2016, 03:33 AM   #4211
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
The cup 2 is the best tire. Much faster than the a048.
R888R is new and lack feedback so far. Toyo are generally not as good as others. So you need to pay much less for them.
A048 is much too old now. Even if it works fine. You can get 10 track days out of it. But the last 3 will be much lower grip.
You can use cup 2 now then try a052 next year when available.
I plan to try a005 soon , then try a052.
I'm on ado8r now to set base lap times. They last forever and work in the rain.
They are obviously much slower than semi slicks.
This is me on very old a048. It needs a lot of steering wheel work.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
The Following User Says Thank You to MaximeT For This Useful Post:
brzest (10-20-2016)
Old 10-19-2016, 09:49 AM   #4212
Icecreamtruk
Drives: Track preped NA FRS
At the price the sport cup 2 are available there I think there isnt even a discussion here. They are supposed to grip more than the other two options to begin with (dont know about tire life).
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
brzest (10-20-2016)
Old 10-19-2016, 10:01 AM   #4213
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Cup 2's for sure, out of that bunch, especially for that price. FWIW, I don't find the Cup 2's to be extremely grippy, they are "only" 180TW after all, but they'll hold up well and they're much nicer to drive than the old R888, IMO. I've not driven the R888R though, so I have no idea how it compares.
The Following User Says Thank You to DocWalt For This Useful Post:
brzest (10-20-2016)
Old 10-19-2016, 02:22 PM   #4214
Uplink
Uplink's Avatar
Drives: anything you let me
Wow, 17" sizes are horribly limited. 215 or 255 only... and $350/ea at that! Pass.
Have you guys looked at the Rival S's? Half the price and can pull triple duty (track/ax/street). I'd say Kumho XS for 180tw but it looks like those have gone the way of the buffalo.
For shorter sessions, the RE71-R's have been making a good name for themselves. No real data on 30+minute sessions though.
Uplink is offline   Reply With Quote
The Following User Says Thank You to Uplink For This Useful Post:
brzest (10-20-2016)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
