Old 10-07-2016, 10:48 PM   #757
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
Neither really bounce around. At idle usually ltft will be 3.90 and stft will be like .78. At 2500 ltft will be a constant number, one that I listed before, but stft will bounce around a bit, usually the same numbers though. Under acceleration stft will go down to 0 and ltft will be some constant number. I should note I've been trying to diagnose a p219a code and misfires. I'll post up a log in a little bit, it's kind of hard to explain what's going on.
*** Here is my log
http://datazap.me/u/trurace/log-1475...-7-10-11-12-13
I'm looking at my older logs and they don't seem much different from this one... Not really sure how to proceed at this point about this P219a code. Checked for intake and exhaust leaks. Tried cleaning the MAF. I was kind of hoping it would be a bad sensor at this point, but based on my previous logs the ltft and stft behavior seem normal I suppose. I'm stumped, maybe a bad batch of fuel? Can't say that I've noticed any change in drive ability.
TruRace is offline   Reply With Quote
Old 10-09-2016, 12:55 PM   #758
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I gutted my cats and flashed a stage 2 tune the Tuesday before last. I noticed the increase in power right away, of course. But what surprises me is that for the past few days the power has really come on even more. It's weird because usually you get used to the power and the tune seems to lose power on the butt dyno. It has to be the ECU making adjustments and getting the fuel trims right? I guess?
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
OrangeGuitar (10-09-2016)
Old 10-11-2016, 09:20 PM   #759
ThisGuyRett
This Guy
ThisGuyRett's Avatar
Drives: 2015 Halo FR-S M/T
Can anyone shine light on why I am getting my lean alert when going WOT in 3rd gear? Here is the log.
http://datazap.me/u/thisguyrett/10-1...t?log=0&data=1
Also, I dont know what I am doing. I am on the stage 1 91 tune and set alerts mentioned in first post. Almost anytime I am using the real time data logging, i can some kind of alert.
Below are the alerts.
Alert A (over temperature)
Coolant Temp > 207 F
Oil Temp > 250 F
Select OR at bottom of screen
Alert B ( knock alert & Fuel Trim alert)
For E85 suggest -1 for Petrol may -2
FLKC < -1
Knock Correction < -1
IAM < 0.9
LTFT > +10
LTFT < -10
I set the fuel trim alert as Im on E85 and it will alert me to excessive fuel trims due ethanol content changes or someone accidentally filling up with petrol, it will also alert you of exhaust or intake leaks.
Alert C running lean alert
you might have to tweak AFR for petrol/E85 try 13 for E85 12.5 Petrol
RPM > 5000
Engine Load > 1
AFR > 13
Select AND at bottom of screen"
Thanks in advance guys.
ThisGuyRett is offline   Reply With Quote
Old 10-11-2016, 09:31 PM   #760
steve99
Drives: FT86
Oil Temp > 250 F
FLKC < -1
IAM < 0.9
LTFT > +10
LTFT < -10
RPM > 5000
Engine Load > 1
AFR > 13
in that log your right on the threshold of the lean alert at 5000 rpm load 1 afr 13
just move up the parameters slightly like 5100, load 1.05 afr 13.1 and you should be good
Old 10-11-2016, 10:12 PM   #761
ThisGuyRett
This Guy
Change the parameters on the alerts in oft or change the parameters via romraider? Thanks bud!
Also, I get Knock correction alert in high gear, low rpms when speeding up, is that normal?
Old 10-11-2016, 10:24 PM   #762
steve99
Drives: FT86
parameters in oft alters :-)
yep you will often get a bit of knock low rpm high gear with big throttle input
Old 10-13-2016, 08:05 PM   #763
ThisGuyRett
This Guy
Hey steve, I logged a 3rd gear pull today and had a the FLKC alert go off. Could you look at this graph and explain to me what it means and how I am supposed to read it? Im sorry for the noob questions. Should i change the parameters again?
http://datazap.me/u/thisguyrett/flkc-alert?log=0&data=1
Old 10-13-2016, 10:10 PM   #764
steve99
Drives: FT86
Yes the alert is going off as you have FLKC knock over -1 correction and your IAM is only 0.79
91 fuel does tend to get some knock
it looks a little on the lean side as well for OFT tune
is you intake stock ?
exhaust headers ?
which tune are you running assume 91 oft tune
next time log Ignition Advance and Commanded AFR instead of lateral G and wideband AFR
its not super bad but probably needs some tweaking
Old 10-13-2016, 10:12 PM   #765
ThisGuyRett
This Guy
exhaust headers ?
I have a BMC drop in filter and a topspeed vs axleback. Should I use the 93 tune instead? I pump 93 but I thought the 91 tune would be safer.
Sent from my SM-N920V using Tapatalk
Old 10-13-2016, 10:16 PM   #766
steve99
Drives: FT86
I have a BMC drop in filter and a topspeed vs axleback. Should I use the 93 tune instead? I have 93 readily available but I thought the 91 tune would be safer.
Hmmm ok, that should not effect afr, just seems a little lean to me, 12.2 on petrol usually ts arround 11.8 high rpm/load
the only difference between 93 and 91 tune is 91 oft tune has about 1.5 degrees less advance over 5000.
running 93 fuel is always going to be better if you can get it.
unless you mod the tune your always going to get some knock on 91 even with 91 tune. Its less than stock tune but still going to be there.
Old 10-13-2016, 10:20 PM   #767
ThisGuyRett
This Guy
Thanks for the input and advice Steve! I will flash it with the 93 tune and monitor it then. I wonder why it is running lean? I'm just tired of the OFT screaming at me with alerts when I go WOT
Old 10-13-2016, 10:22 PM   #768
steve99
Drives: FT86
make sure you get 93 fuel in tank first else knock will be way worse :-)
Old 10-13-2016, 10:26 PM   #769
ThisGuyRett
This Guy
I only run 93oct. I only use the 91 tune because I thought it was safer
Old 10-13-2016, 10:52 PM   #770
steve99
Drives: FT86
yep that safer that way.
here is current log
oft tune should be running arround 11.8 higher rpm
http://datazap.me/u/thisguyrett/flkc...8-9-10&solo=10
Teseo (10-15-2016)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
