| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
| View Poll Results: Which staggered tire combo? Parenth's show % larger diameter, respectively, vs stock. | |||
| 235/40-18 & 255/35-18 (3.2% & 1.7%) |
5 | 22.73% |
| 235/40-18 & 265/35-18 (3.2% & 2.8%) |
6 | 27.27% |
| 245/35-18 & 255/35-18 (0.5% & 1.7%) |
6 | 27.27% |
| 245/35-18 & 265/35-18 (0.5% & 2.8%) |
5 | 22.73% |
| Voters: 22. You may not vote on this poll | |||
Glorious BRZ Master Race
Drives: Subaru Libird
Staggered tire sizes for 18x8.5 / 18x9.5
Thinking of going staggered 18x8.5 +42 / 18x9.5 +45 wheels. What tire size combo would you recommend and why?
Update: I'm leaning toward the wider rears because I want no stretch: 235/40-18 & 265/35-18 (3.2% & 2.8%) 245/35-18 & 265/35-18 (0.5% & 2.8%) Now why would I want to go with 245 vs 235 in front?
#3 |
Same here, 18x9.5 255/40R18 square but my front tires very faintly rub the inner wheel well under full lock due to the +45 offset. What's your offset?
#4 | |
The Gunshine State
Drives: '14 BRZ Limited
Also +45 but those are on my rears. Fronts are 225/40/18 +45 and obviously no rubbing.
![]() Current DD: M235i |
#5 |
Powered by Crickets
Drives: 14' SWP MT Limited BRZ
I run a square 265/35/18 setup. Obviously you're not looking for that, but I have to say, throwing 265's in the rear not only looks good, but also drastically changes the way the car handles.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
#6 |
Country Boy 4 Life
I'm running 245/35/18 square MPSS on staggered wheels.
215/45/17 stock = 20lbs Out side diameter = 24.62 245/35/18 MPSS = 22lbs Out side diameter = 24.75 255/35/18 MPSS = 25lbs Out side diameter = 25.03 265/35/18 MPSS = 26lbs Out side diameter = 25.30 A 22lbs tire is 10% heavier than stock. A 25lbs tire is 25% heavier. edit, stock primacy is 20 not 21... fixed Last edited by Leonardo; 10-05-2016 at 05:03 PM. |
#7 |
Bump. Almost set on 245/40-18 & 265/35-18 or 235/40-18 & 265/35-18 which no one has voted for. Those are the best fit sizes to the rim widths with no sidewall stretch.
#8 | |
Country Boy 4 Life
So, I guess it comes down to which tire you are getting. sizes vary quite a bit between tires.. just as an example, two popular tires. Mpss 235/40/18 tread width =8.5 Mpss 265/35/18 tread width = 9.8 AD08 R 235/40/18 tread width =9.1 AD08 R 265/35/18 tread width 10.3 Specs from tirerack.
#9 | |
#10 |
Country Boy 4 Life
8.5 and 9.1 tread width for the evo12 in those sizes. Should give great performance and a nice look! Can't confirm it won't rub, though I think it would be really minimal, if at all.
#11 |
Drives: 2012 86 GTS - Storm Black
I've got 245/35/18 and 255/35/18.
I personally have no problem with the feel of it though while I'm still na it is definitely well overtyred. I imagine this would be even more so with even wider rears. Unless you are incredibly talented you really won't notice the extra 2.5lb per side (yes I understand it's rotational so let's please not argue about this here). Get some rims that are 2.5lb lighter and problem solved. |
#12 | |
| The Following User Says Thank You to switchlanez For This Useful Post: | Karl07 (10-08-2016) |
#13 |
Someone confirmed 265/35 doesn't rub in rear for my particular offset so I'm leaning toward these two choices:
235/40-18 & 265/35-18 (3.2% & 2.8%) 245/35-18 & 265/35-18 (0.5% & 2.8%) Now why would I want to go 245 vs 235 in front?
#14 |
Off Topic
Step the rear tire up three sizes to maintain a similar diameter. So, 215f/245r, 225f/255r, 235f/265r. That kind of thing. Most popular on an 8.5/9.5 setup is either 225f/255r (very slight stretch, close to OEM diameter) or 235f/265r (no stretch, taller than OEM).
| The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | Leonardo (10-12-2016), switchlanez (10-12-2016) |
| SOLD FS:New 18x8.5,18x9.5 Staggered Rota DPT'S $1250 | gffrs | Wheels and Tires | 1 | 09-15-2014 06:57 PM |
| Enkei NT03+M - staggered 18x8 +35, 18x9.5+40 | dnizzle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-28-2014 09:33 PM |
| 18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) | Funky Fresh | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 05-07-2013 09:52 AM |
| Staggered 18x8.5 and 18x9.5 WORK XSAs | dminner | Wheels and Tires | 16 | 10-02-2012 11:13 PM |
