View Poll Results: Which staggered tire combo? Parenth's show % larger diameter, respectively, vs stock.
235/40-18 & 255/35-18 (3.2% & 1.7%) 5 22.73%
235/40-18 & 265/35-18 (3.2% & 2.8%) 6 27.27%
245/35-18 & 255/35-18 (0.5% & 1.7%) 6 27.27%
245/35-18 & 265/35-18 (0.5% & 2.8%) 5 22.73%
Voters: 22. You may not vote on this poll
Old 10-05-2016, 12:50 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Staggered tire sizes for 18x8.5 / 18x9.5
Thinking of going staggered 18x8.5 +42 / 18x9.5 +45 wheels. What tire size combo would you recommend and why?
Update: I'm leaning toward the wider rears because I want no stretch:
Now why would I want to go with 245 vs 235 in front?
Old 10-05-2016, 01:00 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I'm running 255/40/18 on my 18x9.5 wheels, handles and looks great.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 10-05-2016, 01:06 PM   #3
switchlanez
Same here, 18x9.5 255/40R18 square but my front tires very faintly rub the inner wheel well under full lock due to the +45 offset. What's your offset?
Old 10-05-2016, 01:14 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Ah, I see.
Also +45 but those are on my rears. Fronts are 225/40/18 +45 and obviously no rubbing.
Current DD: M235i
Old 10-05-2016, 02:39 PM   #5
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
I run a square 265/35/18 setup. Obviously you're not looking for that, but I have to say, throwing 265's in the rear not only looks good, but also drastically changes the way the car handles.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 10-05-2016, 03:05 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I'm running 245/35/18 square MPSS on staggered wheels.
215/45/17 stock = 20lbs Out side diameter = 24.62
245/35/18 MPSS = 22lbs Out side diameter = 24.75
255/35/18 MPSS = 25lbs Out side diameter = 25.03
265/35/18 MPSS = 26lbs Out side diameter = 25.30
A 22lbs tire is 10% heavier than stock. A 25lbs tire is 25% heavier.
edit, stock primacy is 20 not 21... fixed
Old 10-08-2016, 12:38 AM   #7
switchlanez
Bump. Almost set on 245/40-18 & 265/35-18 or 235/40-18 & 265/35-18 which no one has voted for. Those are the best fit sizes to the rim widths with no sidewall stretch.
Old 10-08-2016, 01:19 AM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The 235/40 & 265/35 have the closest Outside diameter.
So, I guess it comes down to which tire you are getting. sizes vary quite a bit between tires.. just as an example, two popular tires.
Mpss 235/40/18 tread width =8.5
Mpss 265/35/18 tread width = 9.8
AD08 R 235/40/18 tread width =9.1
AD08 R 265/35/18 tread width 10.3
Specs from tirerack.
Old 10-08-2016, 01:24 AM   #9
switchlanez
I'm leaning towards Hankook Ventus V12 evo2 which are much narrower than those. I don't want the rear 265 tires to rub the rear bumper tab and trying to avoid shaving it.
Old 10-08-2016, 01:30 AM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
8.5 and 9.1 tread width for the evo12 in those sizes. Should give great performance and a nice look! Can't confirm it won't rub, though I think it would be really minimal, if at all.
Old 10-08-2016, 04:33 PM   #11
Karl07
Drives: 2012 86 GTS - Storm Black
I've got 245/35/18 and 255/35/18.
I personally have no problem with the feel of it though while I'm still na it is definitely well overtyred. I imagine this would be even more so with even wider rears.
Unless you are incredibly talented you really won't notice the extra 2.5lb per side (yes I understand it's rotational so let's please not argue about this here).
Get some rims that are 2.5lb lighter and problem solved.
Karl07 is offline   Reply With Quote
Old 10-08-2016, 04:36 PM   #12
switchlanez
Yes my 18x9.5 +45 wheels are about 16 lbs plus I'm supercharged. I want 265 Hankook V12 in rear just not sure if it will rub
The Following User Says Thank You to switchlanez For This Useful Post:
Karl07 (10-08-2016)
Old 10-12-2016, 03:55 PM   #13
switchlanez
Someone confirmed 265/35 doesn't rub in rear for my particular offset so I'm leaning toward these two choices:
Now why would I want to go 245 vs 235 in front?
Old 10-12-2016, 03:58 PM   #14
gramicci101
Off Topic
Step the rear tire up three sizes to maintain a similar diameter. So, 215f/245r, 225f/255r, 235f/265r. That kind of thing. Most popular on an 8.5/9.5 setup is either 225f/255r (very slight stretch, close to OEM diameter) or 235f/265r (no stretch, taller than OEM).
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Leonardo (10-12-2016), switchlanez (10-12-2016)
SOLD FS:New 18x8.5,18x9.5 Staggered Rota DPT'S $1250 gffrs Wheels and Tires 1 09-15-2014 06:57 PM
Enkei NT03+M - staggered 18x8 +35, 18x9.5+40 dnizzle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-28-2014 09:33 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
Staggered 18x8.5 and 18x9.5 WORK XSAs dminner Wheels and Tires 16 10-02-2012 11:13 PM
