Old 10-11-2016, 12:30 PM   #15
gskv
Drives: 2017 BRZ
Originally Posted by PetrolioBenzina View Post
AT or MT?
6MT.
Must've been a good scare knowing your car didn't work after a flash aha
I guess I'll hang tight. Does OFT code out the CEL btw?
gskv is offline   Reply With Quote
Old 10-11-2016, 12:40 PM   #16
Teseo
Drives: frs
Originally Posted by gskv View Post
6MT.
You mean if flash disable cel? If so yes
Old 10-11-2016, 02:31 PM   #17
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
OP - Thanks for doing this. Hopefully, OFT gets on this soon as ECUtek is only a couple weeks away from having reflashes available for 2017 MT cars....
Working on 2017 tune support right now. Just go the def file a few days ago so it won't be too much longer.
Shiv@Openflash is offline   Reply With Quote
Old 10-11-2016, 02:46 PM   #18
Teseo
Drives: frs
We would see a dyno chart comparation between early vs new model? Same bolts on like header and tune
Old 10-11-2016, 07:04 PM   #19
steve99
Drives: FT86
ok guys here is some ZA1JK00C stock roms but with P0420 cat efficiency cel disabled and a second with cat efficiency and quiet start mods done. For guys who have fitted header to stop cel trip and not wake neighbors
get you through till OFT guys release full tune for headers for MY2017 K00C rom
Just unzip and load into oft
@gskv @justinco
@Lonewolf
File Type: zip ZA1JK00C-P0420 cat efficiency disabled.zip (577.2 KB, 271 views)
Old 10-11-2016, 08:50 PM   #20
gskv
Drives: 2017 BRZ
@gskv @justinco
Can you confirm this is for a 2017 6MT?
Shiv just emailed me a test file for checksum verification. But noted to not load onto my car yet!
Old 10-11-2016, 09:04 PM   #21
steve99
Drives: FT86
yes it is 2017 K00C rom, oft wont load anything but same calid rom.
thier is no tuning changes just cel code disabled
the second rom with cold start mods is just ancillary changes tune is stock.
Old 10-11-2016, 09:28 PM   #22
thambu19
Drives: Scion FRS
Does anyone know how the new 2017 model gets around the torque dip? There has to be a change to the Headers or intake runner length. Tune alone cannot replace lack of airflow from experience.
thambu19 is offline   Reply With Quote
Old 10-11-2016, 09:42 PM   #23
steve99
Drives: FT86
AFAIK the hardware mods to 2017 Manuals only
intake manifold design change and its aluminium
larger bend radius intake tube (similar to aftermarket offerings)
air filter now paper based not cotton based, ie similar to aftermarket performance air filters
new larger diameter primary tube header (still with integrated cat)
Old 10-11-2016, 09:48 PM   #24
thambu19
Drives: Scion FRS
Great thanks. With most people moving from Aluminum to Composite manifold it is strange to see Subaru go the opposite way even if they were planning on boosting.
The bend and filter change appear just for top end air flow improvement. The trick can be in the larger diameter header that will now scavenge at a higher engine speed. The old headers hit peak scavenging at ~2800rpm I believe and from there on it died off slowly. Perhaps this one peaks at a later engine speed so by the time the scavenging dies off the power band picks up reducing the dip. This could sacrifice the really low end but who cares.
Old 10-11-2016, 11:23 PM   #25
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
As long as the FA20 is in the car, there will always be a torque dip. I did 400 miles on 101 today, and spent the majority of the trip under 4k and above the speed limit. What it needs now, though, is a seventh gear.
PetrolioBenzina is offline   Reply With Quote
Old 10-11-2016, 11:26 PM   #26
PetrolioBenzina
Drives: 17 86
@gskv @justinco
Somebody do this ASAP and report back. I'm going to wait for others success before I try again. Hope there is not something wonky with my particular car that caused a failure, but Shiv said all should have been well. Anyway, y'all hurry up and flash!
Old 10-11-2016, 11:39 PM   #27
justinco
justinco's Avatar
Drives: 2022 GR86
I got the same test file and it loaded to the OFT ok. Not flashing the car until he gives the go ahead. Plus, I want to get more miles on it.
justinco is offline   Reply With Quote
Old 10-12-2016, 12:05 AM   #28
gskv
Drives: 2017 BRZ
I'm coming from a e92 m3 and that car has one of the best torque curves ever.
Changing the headers out makes it quite nice to not have the dip, but honestly the car is so good stock, it doesn't bother me that much. More power, drivability and slightly corrected curves are just nice bonuses.
I've flashed my car with the test as per Shiv's instruction, he informed that he'll need a day or 2 to work out the tune!
I did notice after flashing the test file, my car idled differently. Perhaps maybe I am on a Canadian car? :S
openflash tablet vs ecutek tune brz23 Software Tuning 104 07-28-2020 04:36 PM
Openflash tune problem with brz sgoldberg01 BRZ First-Gen (2012+) — General Topics 6 02-09-2016 01:13 PM
fi and openflash tune Hachi6 Forced Induction 59 11-20-2015 01:28 PM
OpenFlash-- header tune mtimney Forced Induction 3 08-07-2014 03:51 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
