#29 |
Drives: Non-BRZ
I've reached out to my dealer regarding my Bluetooth issues, I'll report back if we are able to sort it out at all.
| The Following User Says Thank You to Chauntalei For This Useful Post: | Dadhawk (06-24-2012) |
#30 |
Drives: SSM 6-MT limited
#31 |
I read it in the Nav Owner's Manual (pg. 244 under About USB Devices). It describes the supported USB memory standards and says "Supported Capacities: 16 MB to 8 GB"
#32 |
#33 |
Walkin' on sunshine
Drives: Ford BA MKII XR6 ute
For the Samsung guys running gingerbread try updating to ice cream sandwich (4.0.3)
> settings > about phone > software update should also do it through Kies as well.
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
#34 | |
The more I've looked into it, the more it seems to be a Samsung problem. I am going to try my Motorola Atrix and see if I have any problems, as well. But, I am going to take your advice and update, ASAP. Coincidentally, I had just tried to update a few moments ago, but the installation failed. I will report back with my results in both cases. |
#35 |
Mind guiding me through the update process via Kies? I'm hardly familiar with it, and it's making me wait 24hrs to try and download the update again.
#36 |
Walkin' on sunshine
Download Kies onto your computer, search for updates and then plug in your phone via usb. It should prompt you to update the software.
#37 | |
Unfortunately, my phone is the GSII Skyrocket on AT&T and they have yet to release the update. Fortunately, however, that hasn't stopped the people with the knowledge from proceeding accordingly. I figured out a way to get ICS, and my bluetooth now seems to be working well, as it should. I made a quick thread on how I did it, here: http://http://www.ft86club.com/forum...230#post277230 |
#38 |
Drives: BRZ Limited
Solved Random bluetooth disconnects on BRZ NAV
I just picked up my BRZ Limited over the weekend and I have been having a blast. I have a Samsung Galaxy S3 and noticed that I would get random Bluetooth disconnects and then 20-30 seconds later a reconnect notice. It would happen every 5 to 15 minutes and was very irritating. After extensive online searches I ran across a thread that explained the problem was due to the Android going into a deep sleep mode which caused the disconnect. There is an application in the Market called "Bluetooth Keepalive", it is a $1.35 and prevents the phone from going into this deep sleep when connected via Bluetooth. I tried it and no more disconnect/reconnects. Now if I can get the dealer update the firmware and move the GPS antenna to a better position to fix the GPS lock loss, I will be a happy camper.
#39 | |
Pat |
#40 | |
Drives: 2013 Whiteout MT Scion FR-S
1) Adjusting volume on phone (duh) 2) While BT is connected, turn off head unit for about 5 seconds, turn back on and immediately adjust the volume on the head unit. I think you around 5 seconds before volume adjustment is disabled. (Using Droid Razr Maxx) |
#41 |
Hmmm, have to give that a try. Thanks for the heads-up on that one.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| Bluetooth audio from android phone | cgrey | Electronics | Audio | NAV | Infotainment | 10 | 07-11-2013 07:56 AM |
| Bluetooth built into head unit? | finch1750 | Electronics | Audio | NAV | Infotainment | 8 | 06-16-2012 02:59 PM |
| BRZ Bluetooth issues? | Shizuma | Electronics | Audio | NAV | Infotainment | 3 | 06-13-2012 12:06 AM |
| Bluetooth Mic Placement in 86? | Aventador87 | AUSTRALIA | 13 | 06-11-2012 01:36 AM |
| Sound quality of Bluetooth streaming music | robo_robb | Electronics | Audio | NAV | Infotainment | 20 | 06-08-2012 11:37 PM |
