Old 10-07-2016, 07:34 PM   #15
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Worth noting, it looks like you have the bar flipped from how I've mounted it and seen others mounted:
http://www.ft86club.com/forums/showp...&postcount=319
That may actually be the solution based on pictures but those can be deceiving...
Edit: to hopefully ping you if you haven't gone to bed yet, good luck.
Crap. You may be right. I could've sworn I matched the old bar's orientation.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 10-07-2016, 07:37 PM   #16
MarkR171
MarkR171's Avatar
Drives: '05 Elise
That post actually shows something else I may have done wrong. I put the washer on the nut side, but apparently it goes on the link side? Whiteline's instructions were terrible with a washed out photo you couldn't see anything on.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
The Following User Says Thank You to MarkR171 For This Useful Post:
strat61caster (10-09-2016)
Old 10-07-2016, 07:42 PM   #17
whataboutbob
AutoX-10/10ths every run
A vice is helpful, but maybe just a C clamp would suffice if you had a fixed object to clamp it onto.
Build thread:Here
Old 10-07-2016, 10:19 PM   #18
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Just spent the past two hours doing the entire install again. Bar was not oriented incorrectly. I tried to flip it and there was no way it was going to go in. I did change the washer position though. I had the washer on the nut side of the endlink instead of the link side. Hopefully that helps something... I leave for the test and tune in 8 hours so I'm not going to bother test driving tonight...
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 10-08-2016, 05:42 AM   #19
scirocco78
Drives: Scion FRS
That bar looks upside down to me too. I have the exact same setup as you and my bar is flipped. No problems or noises.
scirocco78 is offline   Reply With Quote
Old 10-08-2016, 12:35 PM   #20
Hostile_Kittens
Hostile_Kittens's Avatar
Drives: 2015 Subaru BRZ
I've got the whiteline endlinks and they were doing the same thing, but I managed to fix it.
I took the endlinks off, completely removed one of the nuts and tightened the body down right on the rod end, then used the remaining nut to line up the top end.
The noise stopped. The LCA damage stopped. Ive got use of both settings on the bar. I've run half a dozen autocross events with no issues popping up.
It's cheap, easy, and you don't have to permanently modify anything. Try removing one of the nuts and let us know how it works for you.
Hostile_Kittens is offline   Reply With Quote
The Following User Says Thank You to Hostile_Kittens For This Useful Post:
MarkR171 (10-08-2016)
Old 10-08-2016, 12:48 PM   #21
MarkR171
MarkR171's Avatar
Drives: '05 Elise
I tried flipping it last night and there was no way it was going to fit the other way. I couldnt even mount it. Fairly sure its just the angle.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 10-08-2016, 12:50 PM   #22
MarkR171
MarkR171's Avatar
Drives: '05 Elise
@Hostile_Kittens Now that sounds like a good solution. I put about 15 or so runs on the car with the light clunking today and have a points event tomorrow so I'll try removing a nut tonight.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 10-08-2016, 07:09 PM   #23
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Update: My sway bar is NOT hitting the LCA. It's hitting at the top of the bar on both sides. After some autocross runs today, you can see where the paint was chipped off the bar from contact.
Can anyone confirm that the bar is oriented incorrectly? Or have a source for a picture of how the bends in the bar should look? I have the car on jackstands but I'm not going to start taking it apart again unless I'm sure, because I tried to flip it last night and it didn't seem like it would fit. No idea how I could avoid this contact based on where it is hitting.
@strat61caster @scirocco78
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
whataboutbob (10-09-2016)
Old 10-08-2016, 07:47 PM   #24
scirocco78
Drives: Scion FRS
I retract my previous statement about the bar being flipped. I had this same problem. You can tell by the touch up paint on my sway bar lol.
Your endlinks are too short allowing the bar to move up too much.
http://i.imgur.com/ou2eJnu.jpg
Old 10-08-2016, 07:50 PM   #25
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Excellent. I'm in the garage right now and just got done readjusting them to be about half an inch longer after staring at it. Torquing everything down now.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 10-08-2016, 07:52 PM   #26
scirocco78
Drives: Scion FRS
I ended up lengthening my end links so that the end of the sway bar was about 1/4" from hitting the control arm at full droop.
Old 10-08-2016, 07:55 PM   #27
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Mine is right about there as well. I saw scratches on my LCA so I thought it was hitting there, now I think it's just my lazy wrenching that hit the lca while tightening the end links
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 10-09-2016, 12:29 AM   #28
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Interdasting, sorry for the late response but I snapped a pic of mine through the wheel yesterday, and I think it may have been a perspective thing, I bet with the links a little lengthened yours looks a lot like mine now with the end 'angled down'
I like Hostile Kittens suggestion about removing the nut, that seems viable if I never find replacement links.
Worth noting but I have a different set of bends than OP's, but mine looks a bit like scirocco's
Edit: Pic isn't too helpful, sorry
ineedyourdiddly
FS: NY - Whiteline 22mm front sway bar w/ endlinks TallTerror13 Brakes, Suspension, Chassis 2 02-20-2016 07:28 PM
*BRZ Part Out* 22mm front bar w/endlinks xDanger_208x Brakes, Suspension, Chassis 6 04-12-2015 11:17 PM
Clunk when going into reverse! Just installed Cusco and Whiteline bsamps4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 10-04-2014 07:07 PM
FS: Whiteline 22mm Front Bar w/ Endlinks trippinbillies40 Brakes, Suspension, Chassis 3 06-19-2014 11:47 AM
Whiteline Clunk fix trippinbillies40 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-26-2013 05:44 PM
