#15 | |
Drives: '05 Elise
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
#16 | |
Drives: '05 Elise
'05 Lotus Elise
| The Following User Says Thank You to MarkR171 For This Useful Post: | strat61caster (10-09-2016) |
#17 |
AutoX-10/10ths every run
A vice is helpful, but maybe just a C clamp would suffice if you had a fixed object to clamp it onto.
#18 |
Drives: '05 Elise
Just spent the past two hours doing the entire install again. Bar was not oriented incorrectly. I tried to flip it and there was no way it was going to go in. I did change the washer position though. I had the washer on the nut side of the endlink instead of the link side. Hopefully that helps something... I leave for the test and tune in 8 hours so I'm not going to bother test driving tonight...
'05 Lotus Elise
#19 |
Drives: Scion FRS
That bar looks upside down to me too. I have the exact same setup as you and my bar is flipped. No problems or noises.
#20 |
Drives: 2015 Subaru BRZ
I've got the whiteline endlinks and they were doing the same thing, but I managed to fix it.
I took the endlinks off, completely removed one of the nuts and tightened the body down right on the rod end, then used the remaining nut to line up the top end. The noise stopped. The LCA damage stopped. Ive got use of both settings on the bar. I've run half a dozen autocross events with no issues popping up. It's cheap, easy, and you don't have to permanently modify anything. Try removing one of the nuts and let us know how it works for you. Last edited by Hostile_Kittens; 10-08-2016 at 05:36 PM. |
| The Following User Says Thank You to Hostile_Kittens For This Useful Post: | MarkR171 (10-08-2016) |
#21 |
Drives: '05 Elise
I tried flipping it last night and there was no way it was going to fit the other way. I couldnt even mount it. Fairly sure its just the angle.
'05 Lotus Elise
#22 |
Drives: '05 Elise
@Hostile_Kittens Now that sounds like a good solution. I put about 15 or so runs on the car with the light clunking today and have a points event tomorrow so I'll try removing a nut tonight.
'05 Lotus Elise
#23 |
Drives: '05 Elise
Update: My sway bar is NOT hitting the LCA. It's hitting at the top of the bar on both sides. After some autocross runs today, you can see where the paint was chipped off the bar from contact.
Can anyone confirm that the bar is oriented incorrectly? Or have a source for a picture of how the bends in the bar should look? I have the car on jackstands but I'm not going to start taking it apart again unless I'm sure, because I tried to flip it last night and it didn't seem like it would fit. No idea how I could avoid this contact based on where it is hitting. ![]() ![]() ![]() @strat61caster @scirocco78
'05 Lotus Elise
| The Following User Says Thank You to MarkR171 For This Useful Post: | whataboutbob (10-09-2016) |
#24 |
Drives: Scion FRS
I retract my previous statement about the bar being flipped. I had this same problem. You can tell by the touch up paint on my sway bar lol.
Your endlinks are too short allowing the bar to move up too much. http://i.imgur.com/ou2eJnu.jpg |
#25 | |
Drives: '05 Elise
'05 Lotus Elise
#26 |
Drives: Scion FRS
I ended up lengthening my end links so that the end of the sway bar was about 1/4" from hitting the control arm at full droop.
#27 | |
Drives: '05 Elise
'05 Lotus Elise
#28 |
Drives: '13 FRS - STX
Interdasting, sorry for the late response but I snapped a pic of mine through the wheel yesterday, and I think it may have been a perspective thing, I bet with the links a little lengthened yours looks a lot like mine now with the end 'angled down'
I like Hostile Kittens suggestion about removing the nut, that seems viable if I never find replacement links. Worth noting but I have a different set of bends than OP's, but mine looks a bit like scirocco's Edit: Pic isn't too helpful, sorry |
| FS: NY - Whiteline 22mm front sway bar w/ endlinks | TallTerror13 | Brakes, Suspension, Chassis | 2 | 02-20-2016 07:28 PM |
| *BRZ Part Out* 22mm front bar w/endlinks | xDanger_208x | Brakes, Suspension, Chassis | 6 | 04-12-2015 11:17 PM |
| Clunk when going into reverse! Just installed Cusco and Whiteline | bsamps4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 10-04-2014 07:07 PM |
| FS: Whiteline 22mm Front Bar w/ Endlinks | trippinbillies40 | Brakes, Suspension, Chassis | 3 | 06-19-2014 11:47 AM |
| Whiteline Clunk fix | trippinbillies40 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-26-2013 05:44 PM |
