Old 10-05-2016, 02:50 PM   #1
Tysoncrosby21
Drives: 2017 Asphalt 86
86 parts compatibility
Does anyone know the compatibility of exhaust/intake parts between the current era FRS/BRZ and the 2017 86. I just picked up an 86 and I'm curious.
Thanks!
Tysoncrosby21 is offline   Reply With Quote
Old 10-05-2016, 03:42 PM   #2
Crazy Asylum
Crazy Asylum's Avatar
Drives: 2016 FR-S Raven
As far as I know everything should bolt up the same but i could be wrong.
Crazy Asylum is offline   Reply With Quote
Old 10-05-2016, 05:58 PM   #3
Marcbrz86
Drives: 2015 Subaru BRZ Series Blue
I'm interested in that gauge cluster with all the power curve and temperatures etc.
I wonder if you can swap that
Marcbrz86 is offline   Reply With Quote
Old 10-05-2016, 06:08 PM   #4
funwheeldrive
Thanks!
I think I heard there are slight changes in the exhaust manifold. I would think everything behind the cats is the same though.
I'm pretty sure @Zaku already has looked into this and determined that it would not be an easy job.
The Following User Says Thank You to funwheeldrive For This Useful Post:
Zaku (10-05-2016)
Old 10-05-2016, 07:49 PM   #5
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Intake box, filter, tube, and manifold have been revised. Exhaust manifold also revised. I would assume you could swap the intake system and exhaust manifold between the two, but someone needs to test it to confirm.
Old 10-05-2016, 09:41 PM   #6
wparsons
wparsons's Avatar
I read somewhere the flange on the header to the overpipe is slightly different. Intake and exhaust manifolds are definitely revised.
flickr
Old 10-06-2016, 04:28 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Going from the MY17 BRZ document that was posted up here somewhere, the engine changes are:
Increased cylinder block rigidity
Greater piston durability
Changed valve stem finish
Improved roughness of camshaft journals
Optimized fuel pump drive cam
Optimized internal shape of rocker arm pivots
Changed shape of fuel system components
Changed fuel pressure sensor
Upgraded to next-generation fuel pump
Changed shape and material of intake manifold
Optimized flow channels of air intake system
Changed specifications of air cleaner element
Changed shape of EPF (Exhaust Manifold)
Changed material of EPC-R (Front Pipe)
Changed material and shape of exhaust pipe system
Changed specifications of cam angle sensor plate
Changed ECU hardware
Changed engine harness
Changed material of oil spacer
Changed specifications of alternator
Installed new battery condition sensor
Changed specifications of crank angle sensor
Changed shape of crank angle sensor plate
Changed diagnostic specifications of O2 sensor
So no, not many changes. My interested to see the intake system and exhaust manifold changes, both will probably end up being cheap to buy from those that replace them and might see some benefit. Also would like to see what change in O2 sensor, have they gone for a true WBO2 like many others do these days, or just changed the logic in the ECU?
.: Stealth 86 :.
Kodename 47 DJ:
Celica00 (10-06-2016)
Old 10-06-2016, 05:23 AM   #8
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
Also the power curve is just a stationary image and not a real time 'dyno'
Vin is offline   Reply With Quote
Old 10-06-2016, 10:47 AM   #9
invaliduser
Drives: 2017 86
Have any of the tune companies gotten their hands on the 2017 ecu? OF etc...
Sent from my Nexus 6P using Tapatalk
invaliduser is offline   Reply With Quote
Old 10-06-2016, 11:15 AM   #10
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Fuel pump? Crickets?
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 10-06-2016, 12:47 PM   #11
Celica00
Celica00's Avatar
Drives: 86
No more crickets?
Edit: looks like the post above me, beat me to the punch.
Celica00 is offline   Reply With Quote
Old 10-06-2016, 01:15 PM   #12
radroach
Drives: car
@Celica00 you act like you're new here
Old 10-06-2016, 03:32 PM   #13
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
blimey they did all that work and its only 5 bhp up......
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
ajc209 (10-06-2016)
Old 10-06-2016, 03:47 PM   #14
ajc209
Drives: GT86 Cosworth
Perhaps they are up 15hp but now actually make the hp they claim! Shame they didn't strengthen the rods
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
why? (10-08-2016)
'17 Parts Compatibility With Older Models ztrevs Cosmetic Modification (Interior/Exterior/Lighting) 23 12-30-2016 01:31 PM
Compatibility question fr-S-14 Forced Induction 4 06-02-2015 12:15 AM
Sizing compatibility? mikkeluo Engine, Exhaust, Transmission 1 05-10-2015 09:12 PM
P&L Turbo Kit Oil Cooler Compatibility enjoyminutemaid Forced Induction 4 05-15-2014 04:41 PM
Sparco Compatibility Mellish50 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-12-2013 09:20 PM
