Old 05-14-2014, 09:22 AM   #1
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
P&L Turbo Kit Oil Cooler Compatibility
I'm interested in confirmed oil cooler fitment with the P&L turbo kit. Please post if you have the P&L kit and have installed an oil cooler. It will help if you provide the manufacturer and any modification you had to make to either the turbo or oil cooler kits to make them compatible. Thanks.
enjoyminutemaid is offline   Reply With Quote
Old 05-14-2014, 05:09 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@Hawaiian
@Supermassive
@ebielat
@P&L Motorsports
Old 05-14-2014, 06:10 PM   #3
P&L Motorsports
P&L Motorsports's Avatar
Drives: '13 Turbo BRZ (AT) & '13 FRS
We can make one in the style of our shop BRZ oil cooler which is behind the fog light area. It has an electric fan on it and shroud for better air flow as it is not in the direct path of the front grille.
I'm not sure there will be any off-the-shelf oil coolers that are designed to work in conjunction with a FMIC unfortunately. You may have to build a custom solution if you don't want to remove the fog light.
-Ty
P&L Motorsports is offline   Reply With Quote
Old 05-15-2014, 02:12 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
-Ty
Does the standard Mocal thermostatic oil cooler/filter mount that most of the oil cooler kits utilize fit with your turbo location?
Old 05-15-2014, 03:41 PM   #5
P&L Motorsports
It will require a spacer to clear the lip that surrounds the filter but yes, any sandwich adapter should work.
-Ty
closed Supra2k Engine, Exhaust, Bolt-Ons 16 03-21-2014 12:27 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Sparco Compatibility Mellish50 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-12-2013 08:20 PM
Ferodo Brake Pad Compatibility Hags86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-28-2013 11:37 AM
Intake/Oil Cooler compatibility test D1cker Engine, Exhaust, Transmission 3 03-30-2013 08:16 PM
