Old 09-01-2016, 06:10 AM   #169
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Originally Posted by DustinS View Post
More info on that shock mounting
That shock mount is a piece of nylon turned to locate the shock body central to the tower, the remains of my modified cv joint used to clamp the sti bearing and a black nylon ring.
It is there to hold the shock up to get the wheel in the right spot. I have machined towers to raise the top mounts.
Nigelr32 is offline   Reply With Quote
The Following 2 Users Say Thank You to Nigelr32 For This Useful Post:
DustinS (09-01-2016), solidONE (09-01-2016)
Old 09-01-2016, 04:40 PM   #170
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
This is really cool stuff. Its gunna look so niiiiccce !
fizzymike is offline   Reply With Quote
Old 09-01-2016, 07:29 PM   #171
Kiwis
Kiwis's Avatar
Drives: 2016 Blackout BR86
Are you planning to mold out the rivet spots in the widebody or are you going to put rivets in them? The build is beautiful so far, just a tad confused with where you're going.
Kiwis is offline   Reply With Quote
Old 09-01-2016, 09:15 PM   #172
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by Nigelr32 View Post
Here we go fellas.
Moulds are destroyed now so no more will be made, these are for my Buck.
Any you hand laying parts and molds or vaccuum bagging?
Old 09-03-2016, 07:20 AM   #173
Nigelr32
I hand lay everything, it's all FRP. I haven't tried CF yet, but will do one day.
Old 09-03-2016, 07:23 AM   #174
Nigelr32
Originally Posted by Kiwis View Post
Are you planning to mold out the rivet spots in the widebody or are you going to put rivets in them? .
I don't know what you mean Kiwis ? I will be leaving the slots in place but not using any rivets. The complete front and rear fenders will be FRP one piece items.
Check out Ryan Tuercks Gumout car, you'll see what I mean
Old 09-20-2016, 05:40 PM   #175
-Phil
Drives: Rb25 neo brz
Any updates on this?
-Phil is offline   Reply With Quote
Old 09-23-2016, 06:18 AM   #176
Nigelr32
Real soon, there should be more up. I am currently spending hours building a rear bumper buck..
The Following 3 Users Say Thank You to Nigelr32 For This Useful Post:
-Phil (09-23-2016), DustinS (09-23-2016), kch (09-23-2016)
Old 09-24-2016, 10:45 AM   #177
Nigelr32
As promised, here's an update with a pretty pic to show you all.
The rear end is all cut away to allow a nice big diffuser to fit under the custom subframe. The arches are boxed in to wrap around the tyres and the insides of the cut out are parallel to the inner tyre wall.
I need help deciding what to do with the bottom edge.
The plank is just a building block.
Old 09-29-2016, 10:17 AM   #178
86 is goals
Drives: 07' tc
This really is incredible work you're doing. I've been lurking these forums for months but I finally made an account just to be able to subscribe to and follow your amazing build. Keep up the good work man.
86 is goals is offline   Reply With Quote
Old 09-29-2016, 10:27 AM   #179
monstrum
Drives: 2015 Subaru BRZ 6MT
Hey there, been following this build for some time now, and I just wanted to mentioned how great it is to see this coming along!
As for what to do with the bottom edge, have you considered having the diffuser running across the full width of the car? The Speedhunter's Scion FRS that was built for SEMA seems to run a very similar rear end to your 86, and this was all they did:
monstrum is offline   Reply With Quote
Old 09-30-2016, 06:07 AM   #180
Nigelr32
Thanks for the advice my friend.
The car will run a full width diffuser, but I was asking what people thought I should do with the bottom edge either side of the diffuser cut out. I have now decided it will be squared off and featureless.
Hopefully I will have pics up tomorrow of the finished buck awaiting paint.
Old 09-30-2016, 10:35 AM   #181
brz11b
Drives: United States
awesome!
brz11b is offline   Reply With Quote
Old 09-30-2016, 12:22 PM   #182
monstrum
Ah right, i get you. I think however you do it will look good, given the quality of the rest of your work! Thanks for the updates
AJR Project BRZ ! AJ PwR Member's Car Journals 8 10-25-2014 01:13 PM
86 Project 86Project AUSTRALIA 0 04-24-2013 07:49 AM
TWM Project trish07 Scion FR-S / Toyota 86 GT86 General Forum 26 03-11-2013 12:27 PM
86-X project phenom86 Scion FR-S / Toyota 86 GT86 General Forum 1 07-11-2012 03:57 PM
