Old 09-28-2016, 05:09 AM   #1
kgc
Drives: 2013 Subaru BRZ Limited AT
2017 BRZ suspension retrofit
The goal would be to improve ride quality without sacrificing control.
I'm thinking of retrofitting the springs and shocks from the 2017 setup to a 2013. Any idea how to do this / what parts to get?
Any alternative/better ideas?
kgc is offline   Reply With Quote
Old 09-28-2016, 05:21 AM   #2
swarb
Parts? springs and shocks like you mentioned.
You don't mention what ride quality and control means to you, what you're trying to achieve or what you like/dislike about your current setup. I'd suggest you wait until people start selling the used parts, or just get quality dampers(bilstein) and/or springs(rce yellows).
The Following 7 Users Say Thank You to swarb For This Useful Post:
bhmax (09-29-2016), Cole (09-29-2016), PandaSPUR (09-29-2016), RJasonKlein (09-29-2016), shellslinger (09-28-2016), strat61caster (09-28-2016), Tcoat (09-29-2016)
Old 09-28-2016, 06:12 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I am suggesting the "improvement" of the '17 model is insignificant. If you were willing to go to the trouble and expense of going oem I would be more inclined to get some proper aftermarket dampers.
A budget would be helpful.
The Following 7 Users Say Thank You to Captain Snooze For This Useful Post:
8R6 (09-28-2016), Cole (09-29-2016), Hostile_Kittens (09-29-2016), kch (09-28-2016), Qadthane (09-29-2016), strat61caster (09-28-2016), Tcoat (09-29-2016)
Old 09-28-2016, 08:56 AM   #4
CBR600RR
Drives: Raven Black
Parts: 2017 springs and dampers
Alternatives: Aftermarket suspension - coilovers, or dampers and springs
easy peasy titty squeezy - close thread
Old 09-28-2016, 08:58 AM   #5
tobin
tobin's Avatar
Drives: '13 BRZ
I'm curious how they compare. If I recall, Subaru has softened (a.k.a. "refined") the suspension a little bit every year. 2013 should have the stiffest/harshest ride.
tobin is offline   Reply With Quote
Old 09-28-2016, 09:49 AM   #6
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
17 suspension should, in theory, just bolt right up... look thru this.
http://parts.subaru.com/Subaru_2017_...nd-Brakes.html
you should be able to find any part number you need there
from what i've seen... 13/14 is the same. 15/16 got the "refined" setups on the FR-S. I havent seen anything about the brz having a damper/spring change. i know they all got some uprated bolts in 15 but i believe those are on a lot of 14's as well.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following User Says Thank You to Roadcone For This Useful Post:
funwheeldrive (09-29-2016)
Old 09-28-2016, 09:56 AM   #7
wparsons
wparsons's Avatar
2017 BRZ's get a stiffer rear sway bar from what some articles are reporting, to tune out some of the understeer they have from the front biased spring rates.
flickr
Old 09-28-2016, 12:39 PM   #8
norcalpb
norcalpb's Avatar
And has anyone figured how what size the new rear sway bar is?
I know they reinforced the subframe (with bracing, bushings, who knows???) and also the differential.
Old 09-29-2016, 03:43 AM   #9
kgc
To clarify - the ride is rougher and bouncier over rough pavement compared to the 2017, especially at speed. I'm trying to smooth out the ride quality while introducing no more body roll than I have to when starting / stopping / cornering.
I would prefer OEM while my warranty is in place, but it is not a super strong preference. Are there any specific aftermarket combos that you'd suggest?
Old 09-29-2016, 03:55 AM   #10
Captain Snooze
Drives: Red Herring
tCsonfrs (10-17-2016)
Old 09-29-2016, 06:24 AM   #11
kgc
Budget $1000-2000
Old 09-29-2016, 06:49 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Some flex Z at $1K imho will outperform even supposedly improved MY2017 suspension. Between 1K & 2K there are even better options, like tarmac zeros, billsteins, KW V1, etc
The Following 3 Users Say Thank You to churchx For This Useful Post:
solidONE (09-29-2016), Summerwolf (09-29-2016), Teseo (09-29-2016)
Old 09-29-2016, 09:35 AM   #13
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
You can even get KW v3's at that price range..
Soloside is offline   Reply With Quote
Old 09-29-2016, 12:25 PM   #14
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Maybe Koni dampers set to soft + stock springs.
They are an OE replacement spec so should not change warranty coverage in any way.
Edit: Waiting a year to pickup someone tossing out the '17+ OE suspension for cheap seems like a lot of effort for only minor improvements, Koni's will be adjustable and retain their value on the used market as people look for used examples to have rebuilt for autox purposes for many many years to come.
ineedyourdiddly
Pat (10-01-2016)
NAV Retrofit Worstenemy453 Electronics | Audio | NAV | Infotainment 13 03-07-2016 10:39 AM
2015 key retrofit brzsubarusti13 BRZ First-Gen (2012+) — General Topics 0 04-16-2015 10:07 PM
BRZ Retrofit itos808 Hawaii 8 03-30-2015 07:07 PM
FS: FRS HID Retrofit Kid (Morimoto) Khyron686 Exterior Parts (Aero, Lighting, Etc.) 2 04-21-2014 10:08 PM
Need Expert on Retrofit !! Ericfrs Cosmetic Modification (Interior/Exterior/Lighting) 3 07-22-2012 12:22 PM
