Old 03-06-2016, 07:18 PM   #1
Worstenemy453
Drives: 2013 Argento FR-S
NAV Retrofit
I have a 2013 frs with the pioneer head unit. Has the maps button. Found a guy with a 2013 BRZ he is parting out. Want to make sure I get all the parts. I'll need the Navi module itself, the nav SD card and then the in dash antenna. Is there anything else I need ?
Sent from my SM-N900V using Tapatalk
Worstenemy453 is offline   Reply With Quote
Old 03-06-2016, 08:23 PM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
bra radio navi is built in. u just need the SD card and the in dash antenna (the one from the 14-15 FRS works). that is actually my setup in my 13 FRS. or u can pick up the BRZ antenna on eBay for under $40
http://www.ebay.com/itm/2013-2015-SU...9Wl0Ir&vxp=mtr
only issue I'm having is radio reception is crap rt now (still working on that)
lbroskee is offline   Reply With Quote
Old 03-06-2016, 08:48 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
From @SVXdc in this post:
http://www.ft86club.com/forums/showthread.php?t=94981
The FR-S HU sends power to the car's antenna booster amplifier via the separate single-conductor wire on the AM/FM antenna connector.
The BRZ HU sends the 12V power antenna signal out via pin #8 on the 10-pin power/speaker harness.
You'll need to rig up an adapter harness (or at least, add a jumper wire from the vacant slot on your car's 10-pin plug to the factory pin/wire on your car's AM/FM antenna plug.
You're better off doing what I did if you have an FR-S and getting a 2012-2014 prius V navigation module and hooking it up to the FR-S head unit, much less work and it's plug and play
Old 03-06-2016, 08:50 PM   #4
Worstenemy453
Do you have part numbers for the prius items. This guy was selling me the Indash antenna. The navigation module that sits in the dash next to the radio and the SD card for $100.
Old 03-06-2016, 10:37 PM   #5
FRSBRZGT86FAN
It's not worth it for shoddy radio reception, my entire navigation upgrade with entune was under $300:
http://www.ft86club.com/forums/showthread.php?t=39071
Old 03-06-2016, 10:39 PM   #6
Worstenemy453
I always use Bluetooth with my phone so I have no issues with the stock radio.
Old 03-07-2016, 12:47 AM   #7
FRSBRZGT86FAN
Exactly, you're upgrading the stock radio with this module to get navigation, that doesn't have bad radio reception and require a rewire to get the antenna amplifier to work
Old 03-07-2016, 12:56 AM   #8
lbroskee
lbroskee's Avatar
I agree. I only did it bc my scion one's touchscreen touch sensor went bad, so figured why not try something new
Old 03-07-2016, 07:26 AM   #9
Worstenemy453
But I'm saying I'm completely ok with the frs stuff so if I can buy what I need from this brz for $100 then I'll be happy with navigation. Just want to make sure I get all the parts.
Old 03-07-2016, 10:10 AM   #10
lbroskee
lbroskee's Avatar
Brz uses an ad card and I dash antenna for nav
Frs uses an addon module with harness to the radio and an in dash antenna for nav
Only interchangeable piece is the antenna dude
Old 03-07-2016, 10:15 AM   #11
Worstenemy453
So I would either need to buy the whole radio and everything or find an frs with nav to take the parts.
Old 03-07-2016, 10:27 AM   #12
lbroskee
lbroskee's Avatar
Correct. I have the nav bc my radio part stopped responding to touch but module still works and I can include the C brackets and harness. Ud just need the antenna
But wudnt b for $100
Here's install
[ame]https://m.youtube.com/watch?v=A1vH6DmfhZ0[/ame]
Old 03-07-2016, 10:37 AM   #13
Worstenemy453
Here's install
How much ?
Old 03-07-2016, 10:39 AM   #14
lbroskee
lbroskee's Avatar
How much ?
I'd let it go for 200. And that video has a link to an antenna for $15 or u can pickup an OEM one from the Brz for $30 lik I posted earlier
BRZ Retrofit itos808 Hawaii 8 03-30-2015 07:07 PM
FS: FRS HID Retrofit Kid (Morimoto) Khyron686 Canada Classifieds 2 05-09-2014 03:41 PM
FS: FRS HID Retrofit Kid (Morimoto) Khyron686 Exterior Parts (Aero, Lighting, Etc.) 2 04-21-2014 10:08 PM
G37 Headlight Retrofit retrosmiths Cosmetic Modification (Interior/Exterior/Lighting) 8 06-30-2013 09:15 PM
Blackhoused + HID Retrofit eddieEndo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 04-17-2013 07:21 PM
