#519 |
Drives: 10 Series Scion FR-S
Have them resurfaced
#520 |
Drives: 13' BRZ
Anyone have squealing issues with their brakes? I'm about to go mad.
I originally had Porterfield R4-S street pads front and rear and they made noise (which Ive had on multiple cars and they've never made noise). I decided to buy a dedicated set of rotors for street pads since I also have race pads. The new rotors with the R4-S pads made noise. I then went ahead and bought a set of BP-10 pads front and rear in hopes they would be quiet but they also make noise. Its a high pitched squeal as the car comes down to a stop. Its from the both fronts. It drives me crazy and makes me want to take the stupid things off. Tips? |
#521 |
Drives: '22 BRZ
Try the Carbotech 1521s (pad fitment was posted earlier in this thread) as they're pretty quiet for me on the street. When I get them hot they "sing" down to a stop, but they don't squeal. If that's too noisy (I understand, it is annoying sometimes with the weird noises) then try Stoptech's street pads, they have fitments that should work on the RR kit, but you may need to do some research.
#522 | |
Drives: FRS
#523 |
Drives: 13' BRZ
Im just hesitant to buy yet another set of pads. The 2 full sets i have should be quiet as well.. i just wonder if its something with the caliper design. Possibly not having a spring to hold the pads tight. Just thinking out loud.
Sent from my SM-G930V using Tapatalk |
#524 | |
Drives: FRS
try doing a couple of hard stops and the brakes will stop squealing... until they cool off again and then will squeal again after. lol
#525 |
Drives: 13' BRZ
ugh. alright. ill mess around with them. I figured these being their weakest pad would be fairly quiet. thx for the input.
#526 |
Drives: 2013 WRB BRZ 6MT
I have the BP10s in front and they sometimes make a bit of noise when rolling to a stop slowly with light pressure but increase or decrease the pressure and the noise goes away. I've just learned to brake a bit more aggressively on the street as a habit now but even when I do hear it, it's never loud or terrible, especially compared to my Hawks which sounded like a bus. Maybe consider getting some shims for the pads, it might help. Don't need to be good ones either, just some cheap ones should be fine.
Separate from this, I've been getting a bit of a ... clicking feeling in my brake pedal sometimes recently. Wondering if anyone has any ideas before I go chasing it down. Currently, I'm just planning to do a partial fluid bleed and pad swap and hope it goes away. About the clicking, I only feel it in the brake pedal, not the wheel or anywhere else. It can happen when braking to come to a stop or even when fully stopped and just holding the car in place. Honestly, it feels like ABS but it's not nearly rapid enough, I'll feel maybe 1 click per second. I haven't experienced any issues with braking performance as a result so I'm not too concerned so I'm just wondering if anyone has any ideas what it might be or has experienced anything like it. No CEL or anything on the car right now. |
#527 |
Drives: GT86-ACE-JRZ-RPF1-Essex
More RR braking power
![]() [ame="https://www.youtube.com/watch?v=iEk4T-mG3Eg"]GT86 NA Circuit de Clastres in 1.25.4 with road tires. - YouTube[/ame]
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
#528 |
FYI I've parted out my car to trade in in, I've got my Stage II kit with Sport Performance rears (painted yellow) up for sale:
http://www.ft86club.com/forums/showthread.php?t=111343 |
#529 |
Drives: GT86 Cosworth
I'm still getting terrible brake noise when the rears get hot. Last trackday melted the teflon shims so back to square one.
#530 |
Drives: '15 BRZ
Does anyone know if the Stg4 kit will clear Enkei RPF1 17x8 +45 (planned track wheels)? Also XXR 527 18x8.75 +35 (planned street wheels)?
Don't have the wheels yet, so can't test =/ Thank you! Last edited by brzest; 10-21-2016 at 07:19 AM. |
#531 | |
the stage 1 template had no problems. the circled corner in red was the portion that touched the spoke of the rim. the edge of the rim curves back inwards towards the barrel of the wheel causing the edge of the template to hit the inside of the spoke while the actual caliper drawing SHOULD be clear of the spoke. however, it is extremely close and I couldn't tell for sure. running a 2mm spacer as a crutch shouldn't be a problem, though I am not sure if it is "safe" under hard track conditions. someone will have to chime in on that part
| The Following User Says Thank You to ryoma For This Useful Post: | brzest (10-21-2016) |
#532 |
Drives: Whiteout track car; lava donor
2mm is not enough clearance on the track. The caliper can flex and expand when hot.
I've run a H&R 5mm spacer on the stock wheel studs on the track with R comps without issues. Also, be very picky about where the tire balancer guy puts the stick on weights. Should never be an issue, but on other cars with BBKs, I've had Brembos take the weights right off the wheels. |
| Tags |
| big brake kit, competition, track |
| AP Racing brake systems in development | track_warrior | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 872 | 09-17-2017 07:43 PM |
| Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 05:53 PM |
| AP Racing Factory Big Brake Kit, NOT Competition | Lonergt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-25-2013 04:51 PM |
| Official street racing thread. All street racing goes here! | bkblitzed | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 07-19-2013 11:31 AM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 01:32 PM |
