Old 06-24-2012, 03:11 PM   #141
Zadkiel
Drives: CBS BRZ Limited 6MT
Originally Posted by MRZ415 View Post
I think for sure a Turbo and AWD will be on the BRZ platform,
but to make it happen the internals will have to be moved
and the car have to be a bit higher... it'll be the 2015 WRX Coupe
kinda like how the 2.5RS was back in the day.
......So then why not just make a WRX Coupe based on the WRX?
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 06-24-2012, 03:24 PM   #142
MRZ415
Drives: 2015 Subaru WRX
I think subaru wanted to seperate the WRX/STI away from the Impreza
so the WRX/STI will be more performance based rather than an
upgraded impreza.
MRZ415 is offline   Reply With Quote
Old 06-24-2012, 07:46 PM   #143
SnapOv3st3r
Drives: 400whp Scion tC
Isn't that what I've been trying to say? That it wouldn't be used in this car? Now you're confusing me....
LoL...just forget it man..
SnapOv3st3r is offline   Reply With Quote
Old 06-24-2012, 08:49 PM   #144
fatoni
what does that mean?
upgraded impreza.
what does that have to do with anything?
Old 06-24-2012, 08:55 PM   #145
m0nty
m0nty's Avatar
Drives: 86 GT
I just can't see the point of a turbo. Shed some 100-200lbs in weight, remove the rear seats if need be, more aggressive suspension tuning, bigger brakes, better exhaust and intake, and a better ECU tune. You'd have a 2500lb car with 250-275hp. This car doesn't need a turbo.
Everyone is obsessed with FI to the point where if it isn't turbo then it needs to be somewhere along the line. I had a 240SX with an SR swap that weighed about 2300lbs, had 300hp, and made every attempt to kill me. 250-275hp in a 2500lb car is plenty fast enough.
AWD is not even an option on this. Every single part of the front suspension and chassis would need modifying to even get close to accepting the required AWD components. Adding almost 300lbs worth of weight to the front end and only bumping hp to 300 would result in almost exactly the same 0-60 times but with worse handling characteristics.
There in lies the reason why I don't understand all this talk for a more hipo BRZ/86. All those things can be done by owners which was 100% the point if this car. We could've ended this thread at your post.
m0nty is offline   Reply With Quote
Old 06-24-2012, 09:36 PM   #146
Dimman
Kuruma Otaku
Dimman's Avatar
Well it depends on what chassis Subaru will use for the WRX. They've said they don't want to use the Impreza anymore. So are they working on another chassis? Or will they make some mods to the BRZ's? For that matter will the WRX change from a trim to a model? Will we see a BRZ WRX, with turbo and AWD? This was Subaru's initial desire for this car after all. They could do it with a different front end much like how the Supra started. Celica from the firewall back, modified front section.
On that note when is the new WRX even due? Are there spy shots testing yet?
Because titanium.
Old 06-24-2012, 09:43 PM   #147
fatoni
what i find to be an issue is that the celica/supra was very much one chassis. the differenced to accomodate for a subaru style awd and a turbo would bring a lot of changes. the miata is just a tiny rx8 but i dont think its fair to call the miata an rx8.
Old 06-24-2012, 09:51 PM   #148
Dimman
Kuruma Otaku
Dimman's Avatar
Supras had stretched wheelbase over their little brothers.
I'm just getting at platform-sharing. G35 sedan, 350Z, FX45. All the same platform. But obviously modified. BRZ could be the base platform for the new WRX. Would explain a lot of the 'change' rumours too (TGVs and Hitachi injectors...)
FHI: 'We were taken out of context. We didn't mean the BRZ would be turbo and AWD with TGVs and Hitachi DI. We meant the BRZ's platform. Sorry for the confusion.'
Because titanium.
Old 06-24-2012, 10:08 PM   #149
fatoni
i guess i can see that. what gen supra are you talking about?
Old 06-24-2012, 10:10 PM   #150
Dimman
Kuruma Otaku
Dimman's Avatar
Mk2 for sure. Mk1 I'm not 100% on. The Celica-Supras.
Because titanium.
Old 06-24-2012, 10:20 PM   #151
fatoni
mk2 supra or mk2 celica? i could swear the supra was the same size as the regular celica
Old 06-24-2012, 10:37 PM   #152
Dimman
Kuruma Otaku
Dimman's Avatar
MA60 Celica-Supra and RA60 Celica GT-S. Same number on the code but the Supra has a slightly longer wheelbase in addition to the different front lights. Basically firewall back they are the same (at least the GT-S version of the Celica with the semi-trailing arms). But in the front they pushed the wheelbase forward to balance the 6 cylinder a bit.
I would really like something similar to this to happen to the Zx6.
If they can push the motor forward for an AWD WRX on a modified chassis, they could also maybe stuff in an H6 or V6 for the Toyota upgrade and stretch the front wheels to keep a decent weight split.
I can dream...
Because titanium.
Old 06-24-2012, 10:55 PM   #153
OrbitalEllipses
Drives: Attitude
upgraded impreza.
Actually; basing the WRX/STI trims on the Impreza chassis necessitated beefing up the Impreza chassis, including the basic trim 2.5i. Not exactly cost effective, hence the departure from the Impreza.
I can dream...
I wouldn't say no to AWD H6 coupe, turbo or otherwise.
Old 06-24-2012, 11:11 PM   #154
Dimman
Kuruma Otaku
Dimman's Avatar
Going back to old official interviews they seemed to hint that after the initial twin they might diverge considerably. And Subaru had at first wanted to do a turbo AWD coupe...
I'm thinking we will see some neat things in the future.
BRZ/FR-S/GT86: stays as is.
WRX: Turbo AWD H4, based on modified Zx6 platform.
Supra successor: H6 or V6 RWD, based on modified Zx6 platform.
Sti versions of the Subies will be enhanced versions of their base models. BRZ stays NA RWD, WRX stays turbo AWD. Possible displacement increases for both.
Unless Subaru does something surprising with the 1.6DIT they showed beside the FA20.
Is there any news on what they are doing with that motor???
Because titanium.
[Norcal] *Works is looking for an R&D car Lonewolf Southern California 8 06-09-2012 04:38 AM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Who here works for Toyota and/or Scion? PAImportTuner Off-Topic Lounge [WARNING: NO POLITICS] 11 12-28-2011 12:38 AM
Who works on your vehicle? Midship Runabout Other Vehicles & General Automotive Discussions 23 09-25-2011 02:57 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
