| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Silver Scion FR-S
Wheel Spacer Help.
So I have Enkei T6S 17x8 +45 on my car and they already have a hubcentric ring on them. I am wanting to get bolt on wheel spacers (20mm) so they can have a little more flush look. My question is that since the wheels have a hubcenteric ring already, do I or do I not need to get hubcentric wheel spacers or not.
#2 |
Country Boy 4 Life
Want Flush? I'd put 245/40/17 tires on them and call it a day. Having said that, Fewer parts to perfectly line up is better. Good luck! |
#3 |
Drives: FRS
the hubcentric ring is just to help the wheel be mounted dead center easily. if you get hubcentric spacers, you'll just re-use the hubcentric ring since the spacer's hub will be the same as the stock hub. if you get spacers that have a larger hub, then the hubcentric ring you have right now wont even fit on the wheel/spacer combo.
| The Following User Says Thank You to 8R6 For This Useful Post: | Leonardo (09-27-2016) |
| Wheel Spacer Size?? | tonytduc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 11-03-2018 04:36 AM |
| Wheel Spacer Lug Nut Replacement? | Wyattkb | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-12-2016 04:06 AM |
| 3mm wheel spacer | vroom4 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-16-2014 01:36 AM |
| Wheel Spacer | tonytduc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-06-2013 02:44 AM |
