Old 09-19-2016, 05:05 PM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Anyone corner balance just for street driving, worth it?
I'm bringing my car in for my engine leak fix tomorrow and if all goes well and it's fully sealed this time around, I'm going to keep the BRZ for a while longer. Doing that, I'd want to have the car setup properly as well. I have Tein Flex Z coilovers with them set up with the stock recommended settings from Tein. I've been driving them for a year and tbh, for street driving I didn't notice much from when I had my stock shocks + Eibach Prokit springs. The adjustability of the dampers were noticeable otherwise going from 3 clicks to 10 clicks, but I'm driving at 7 clicks. Anyways, it's been so long since I had that springs setup, I can't compare them anymore.
Before I go out and throw down $250-300 for a corner balance, I'm wondering if I should instead save that money for something else. The car drives fine now, drives straight. No weird noises, handles nicely. Just wondering if it can BE better. My camber is at -1.3 all four corners, and I do want to set it at -1.6 soon.
tracerit is offline   Reply With Quote
Old 09-19-2016, 05:31 PM   #2
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Well, you will need adjustable endlinks to eliminate preload on the swaybars. The corner balance will make the feel the same when turning left to right. If most of your driving is straight I don't think it would be wise use of money. That being said you will notice a difference, but you need to do an alignment and corner balance with you in the car. This way it's balanced while you are driving.
TRAKRAVN is offline   Reply With Quote
Old 09-19-2016, 06:32 PM   #3
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
add more negative camber up front, i also have tein flex z. running -2 front, -1.5 rear
on 255/35/18 tires on a 18x9 rim, 7 clicks all around as well
malubawla is offline   Reply With Quote
Old 09-19-2016, 06:36 PM   #4
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
How much corner balancing helps depends on how close, or far, you are from 50%. If you are way off, it will help a lot.
Twinz is offline   Reply With Quote
Old 09-19-2016, 07:02 PM   #5
ryoma
ryoma's Avatar
tbh, unless you are a track enthusiast driving above 8/10ths on a closed course, I highly doubt you will notice the difference between corner balancing and a normal alignment. on the street, you will rarely get a chance to drive as you would on a track without endangering yourself or others. my advice would be to just get a proper alignment and save that left over $150
The Following 2 Users Say Thank You to ryoma For This Useful Post:
Marat (09-20-2016), strat61caster (09-20-2016)
Old 09-19-2016, 09:46 PM   #6
MarkR171
MarkR171's Avatar
Drives: '05 Elise
50% of what?
Weight balance side to side and back to front.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 09-19-2016, 09:47 PM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
That's not the goal of corner weighting.
As you've described it you are seeking to do this.
Old 09-19-2016, 10:03 PM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
You want 50-50 cross.
FL-RR, and FR-RL
The Following User Says Thank You to x808drifter For This Useful Post:
Captain Snooze (09-19-2016)
Old 09-19-2016, 10:03 PM   #9
Twinz
Twinz's Avatar
^ Yes, more detail:
Corner balancing is more like "leveling" a dinner table than "balancing" weight distribution. The weight at each corner of a car, on a level surface, is more of an indicator of the suspension's length/height at each corner than an "end" unto itself.
A car with poor corner balancing is similar to 4-legged dinner table that can rock back and forth when two opposing corners' legs are longer than one or both of the other two. But, whereas a table will rock back and forth over the long-legged axis, and alternately lift the two shorter leggs off the ground, making the issue obvious, the springs on a car will keep all four tires in contact with the ground and mask the issue.
The 4 individual scales, and the resulting weights, show how much force each tire is putting on the ground while at rest.
Less force (weight) on a cross-weight (DF+PR vs PF+DR) means one or both of the "table legs" are too short relative to the heavier cross weight. Or, conversely, the heavier cross-weight has a "leg" or "legs" that are to long.
The Following 2 Users Say Thank You to Twinz For This Useful Post:
RJasonKlein (09-20-2016), x808drifter (09-19-2016)
Old 09-19-2016, 10:06 PM   #10
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Attachment 143264
That's fair, but I meant them as two different things. 50/50 left:right (mainly) and/or 50/50 f:r
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 09-19-2016, 10:29 PM   #11
Captain Snooze
Drives: Red Herring
That's still not the goal. See @x808drifter's post above.
Static 50% front/rear distribution is a marketing ploy.
why? (09-20-2016)
Old 09-19-2016, 11:00 PM   #12
Ashikabi
Ashikabi's Avatar
Didn't read thread just replying to title... gonna say you won't notice any difference whatsoever
Old 09-20-2016, 07:35 AM   #13
mrk1
Drives: Sterling BRZ Ltd
Not worth it.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 09-20-2016, 07:52 AM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
What is the factory setting for each corner?
Corner Balance Adeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-29-2016 08:39 PM
GTA Corner balance Jrdad CANADA 10 06-10-2015 07:14 PM
Parts required to maintain corner balance? Ludacrits Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 04-14-2015 07:30 PM
Alignment / Corner Balance mystic Southern California 8 04-17-2014 06:57 PM
corner balance in bay area garfull Northern California 10 06-24-2013 10:16 AM
