Old 09-18-2016, 06:13 AM   #1
makinen
makinen's Avatar
Drives: Toyota 86
Are the rusted springs OK?
Hi,
I've used RCE Tarmac springs through two winter seasons.
Some days before, I found that those springs are rusted.
How can I cure these springs?
Will the rust remove work?
Thanks.
makinen is offline   Reply With Quote
Old 09-18-2016, 08:53 AM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
It's just surface rust and won't hurt anything.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
Calum (09-18-2016), makinen (09-18-2016)
Old 09-18-2016, 11:30 AM   #3
That rust will become an issue if you leave it for 40 or 50 years but otherwise not a problem. If you want them to look nicer just clean them up with a scrubby or steel wool and brush on some rust paint.
Calum (09-18-2016), Cole (09-18-2016), makinen (09-18-2016)
Old 09-18-2016, 01:25 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
#totalled
Calum (09-18-2016)
Old 09-18-2016, 03:55 PM   #5
HachiRo
Drives: 2013 White-Out FRS
Originally Posted by Norville Rogers View Post
They are aftermarket. The springs (and the paint protecting them from rusting) are likely to be of a lower quality than OEM.
A "cure" might be to put the originals back on.
Will removing the rust (rust remove) be effective (work)? Who knows? What did you have in mind?
Idk man, RCE and "lower quality" only work in a sentence when the word "aren't" is between those two.
Surface rust. Had it on my RSR Superdowns springs comes off quite easily.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
The Following 4 Users Say Thank You to HachiRo For This Useful Post:
gramicci101 (09-18-2016), makinen (09-18-2016), Racecomp Engineering (09-18-2016), wparsons (09-19-2016)
Old 09-18-2016, 06:11 PM   #6
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Like the others said, just surface rust. I've seen much worse. If it were my car, I'd clean off whatever rust I can reach without removing them from the car, and hit them with a good thick rust preventative spray oil 3-4 times a year.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
Old 09-18-2016, 10:45 PM   #7
makinen
makinen's Avatar
Drives: Toyota 86
I missed "r" for the "rust remover" which changes rusts into stable compound.
I'd like to make rusting process as slow as possible without hurting springs.
Old 09-18-2016, 11:20 PM   #8
Glok24
Drives: 2014 FR-s Whiteout
It seems like the general consensus is that its not a problem, but if you do want to remove it with a wire brush or some steel wool, and want to delay other rust from building up, you could get some cold galv spray https://www.amazon.com/Rust-Oleum-75.../dp/B00106H68W and galvanize the springs. not 100% sure how well it works on moving parts, but it should help
Glok24 is offline   Reply With Quote
Old 09-18-2016, 11:31 PM   #9
Teseo
Drives: frs
I would considere a sandblast and paint, just for "looks"
Old 09-19-2016, 10:58 AM   #10
wparsons
wparsons's Avatar
My stock springs were rusted when I took them out too... springs are steel, they'll rust.
flickr
Tcoat (09-19-2016)
Old 09-19-2016, 11:09 AM   #11
DO NOT SANDBLAST SPRINGS!
Part of the manufacturing process of (most) springs is a shot peen after heat treat. This gives the springs strength yet flexibility. Sandblasting can mess with the metallurgy.
brandonblt2 (09-19-2016), Shark_Bait88 (09-19-2016), Teseo (09-19-2016)
Old 09-19-2016, 11:25 AM   #12
Teseo
Drives: frs
My bad, then sandpaper? Light pressure
The Following User Says Thank You to Teseo For This Useful Post:
Tcoat (09-19-2016)
Old 09-19-2016, 11:36 AM   #13
Oh you can hit it with anything you want by hand. They aren't glass. Just stay away from sandblasting.
Teseo (09-19-2016), wparsons (09-19-2016)
Old 09-19-2016, 11:53 AM   #14
Might have meant beadblasting. Sometimes people use the term sandblasting for anything from shotblasting through.
True. Best to stay way from any type of blasting on heat treated and peened materials though. Not that beads would have any huge effect but why mess with it. Slap some anti rust paint on them and call it a day.
makinen (09-19-2016), Norville Rogers (09-19-2016)
How do you get rusted hubs/bearings off? ZionsWrath Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 07-01-2016 10:51 AM
Rusted chipped paint ARTBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 01-31-2016 11:08 PM
Rusted shipped paint ARTBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 01-30-2016 04:46 PM
Rusted exhaust pipe '13 FR-S cheesesteak Issues | Warranty | Recalls / TSB 14 04-15-2014 03:51 PM
Does exhaust will be rusted at some point? Lverasky Engine, Exhaust, Transmission 10 04-12-2013 03:53 PM
