Old 09-28-2015, 09:01 PM   #15
mrk1
Drives: Sterling BRZ Ltd
I took my Supra LSD for the first ride tonight and holy braking stability! I'm a fan of late and trail braking but the car was not, now it's planted as can be. It reminds me of my M3 with the big rear tires.
As for noise I got a click or two pulling out of my garage but never again, even doing tight slow turns. I look forward to getting more time on it.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 09-28-2015, 09:06 PM   #16
juliog
juliog's Avatar
Drives: 86
I love my Cusco LSD. Much more predictable (and faster) than the Torsen once you trust it
juliog is offline   Reply With Quote
Old 09-11-2016, 01:47 PM   #17
fika84
fika84's Avatar
MFactory Mechanical LSD and 4.88 FD installed
Finally got the MFactory 1.5/2 way installed with a 4.88 Weir Performance final drive. It's amazeballs. Only have about 1300 miles on it so far and my tires suck, so the chattering is a bit high when it's cold. But after a short drive when it warms up there is no chattering at all and overall very little gear noise (I have solid mounts everywhere, so gear whine and tranny noise is expected).
This is my first ever mechanical LSD and jebus this thing make the car STICK! I'm running 1/2 the amount of preload (6 springs, instead of 12) and have the lock capacity % at about 40%. These values might change a bit when I actually get some track wheels/tires next season, but for now it feels wonderful. Locks when I'm harder on the gas, and if I'm feathering the gas it'll slip, then off the gas while in gear going into corner the back end just hugs the inside.
This winter will be my first full winter with it installed, but I'm looking forward to the predictability of the ass end on snow tires.
Now for the pictures! I'm not very good at pics, but I did take it apart a few times since installing it to check the gear contact patch and clutch pad wear.
I haven't been getting on here that much anymore, but thought I'd share my experiences since that's what the community is all about!
fika84 is offline   Reply With Quote
Old 09-11-2016, 08:27 PM   #18
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I appreciate the update. I just ordered an OS Giken 1.5-way LSD from CounterSpace Garage, and it's being drop shipped to Weir Performance so that Spence Weir can install the LSD and 4.56:1 ring and pinion gear. Why did you choose the 4.88:1 over the 4.56:1 gear set? Can you live with the ratio on a dialy driver or are the revs just crazy high, especially on the highway? I assume you're normally aspirated (nobody that's blown would want such a short ratio) and acceleration is much improved, but our gearboxes are a little clunky and shifting quickly and more frequently might be a pain - has this been an issue for you? I'm asking because I'm second guessing the ratio of my choice and I'd like to hear more about your experience with the ratio you chose to go with.
I know that this resurrected thread is about clutch-type LSDs, but I think people will be interested in hearing more about your super-short final drive, too.
RJasonKlein is offline   Reply With Quote
Old 09-12-2016, 10:49 PM   #19
fika84
fika84's Avatar
OS Giken will be sweet! Far quieter than any other on the market.
I was a bit hesitant about the 4.88 when I ordered it, but I couldn't be happier. I do daily drive the car and it's not bad IMO. Highway driving I'm at about 3900 at 75mph and 4100 at 80mph. That'll get more annoying when I drive to the track, but the highways in the city are 65 so it's just fine, it's also nice to have a little oomph in 6th on the freeway. The gearing wasn't as short as I had envisioned in my head and with the LSD the grip is fantastic. Overall I'm glad that I went with the 4.88 and once the exhaust gets finished and the torque dip dies down, it's going to be even more fun and torquey. Even as it is, you go through the RPM's so quick in the low RPM that the torque dip isn't as noticeable. I also have a 13lb flywheel though too.
The car has close to 30,000 at this point and the gear box is great. It has just gotten smoother over time. When it was low on miles it liked being shifted quickly and with assertion, now it's a little more lax. I tend to shift quicker anyway though with the lighter flywheel because the RPM's drop so quickly with the clutch engaged. With the 4.88 and the flywheel it feels a bit more evened out, RPM's rev quick high and low. I will put a short shifter on it eventually though, it's on the list, just low priority.
Need grippier tires on rpf1's and new pads/rotors for track/mountain days! Let me know if you have any other questions.
Couldn't find a good video on youtube (I can record a quick one if you want), but I can tell that the revs aren't as crazy fast as you might think.
Old 09-13-2016, 12:06 AM   #20
RJasonKlein
Thanks @fika84 for answering all my questions - your car sounds like it's a blast!
Anybody running Exedy stage 2 clutch? 14BRZ Engine, Exhaust, Transmission 65 05-26-2020 12:21 AM
SPECIAL PRICE TOMEI TITANIUM MUFFLER TYPE -80,60S,60R/FRONT STRAIGHT PIPE TYPE-80,60 myjdmparts Groupbuys 15 10-08-2015 10:41 PM
MKIII Supra clutch type LSD? Kotu100 Engine, Exhaust, Transmission 17 09-17-2015 09:55 PM
Who is running APEXi Coilovers - N1 Damper ExV (Expert Type V) zeal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-21-2014 05:19 AM
