Old 09-28-2015, 11:46 AM   #1
mrk1
Drives: Sterling BRZ Ltd
Clutch Type LSD, who has made the switch?
I have been doing lots of research about clutch type LSD's and I'm wondering if people here have made the switch and to what brands?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 09-28-2015, 11:53 AM   #2
fika84
fika84's Avatar
It's not in yet... but it will be an MFactory 1.5/2 way. Getting the plates WPC treated, dropping initial torque in half and putting lock capacity to 83%
EDIT: Did you get the Supra diff in yet?
fika84 is offline   Reply With Quote
Old 09-28-2015, 11:56 AM   #3
mrk1
My Supra LSD should be in this week, just need to find some marking compound to set the ring back in, seem to have misplaced mine.
The Build Thread
Old 09-28-2015, 11:57 AM   #4
fika84
fika84's Avatar
I bought the GM stuff (it's yellow) from Amazon ([ame="http://www.amazon.com/Genuine-Fluid-1052351-Marking-Compound/dp/B00BK7MFC8/ref=sr_1_1?ie=UTF8&qid=1443455911&sr=8-1&keywords=gm+marking+compound"]THIS[/ame]) and a dial in-lb torque wrench to measure pre-load.
Old 09-28-2015, 02:02 PM   #5
Check out the suspension subforum. Many have, but a lot of them don't post on this board. I can probably answer any questions you have.
Old 09-28-2015, 04:51 PM   #6
mrk1
Just looking for people experiences and opinions.
Im not a track junkie or anything but feel upgrading from the Torsen would benefit me. With my current suspension I find the inside wheel will get light enough to trigger the traction control a little to easily. I could adjust this in the suspension but I really really like it right now so I want to cure this with a clutch type LSD.
Also spinning a wheel when trying to get in a driveway gets old.
The Build Thread
Old 09-28-2015, 04:57 PM   #7
mrk1
I'm going to use traction control activation as something of a test with my new Supra LSD, I find this point can be reached on the street a little more responsibly.
The Build Thread
Old 09-28-2015, 05:24 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Have OS Giken on my car now.
If you do not like noise, you will not want to go to a true mechanical LSD.
Also, keep in mind that you will need to change the diff oil often. The intervals will be dictated by the driving but expect to change it every 5-10k miles.
-alex
Old 09-28-2015, 05:30 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You must have the volume turned up on your Giken because I can't hear mine.
After all the reading of this thread I convinced myself that I needed a diff (or allowed myself to be convinced). I had an OSGiken diff fitted. Here are my road impressions; track day coming up not soon enough.
The feel at the rear end has improved when turning/slipping. This is not to say the Torsen is bad (I don't know what I don't know) but the feel at the rear is much more....mmm... organic.
Analogy. I have (atm) big anti roll bars front and rear. When one side at the front hits a bump I can feel the other wheel being affected. The new diff is like uncoupling the heavy sway bar. That is, both rear wheels feel like they have been uncoupled. I do not mean that literally, it is an lsd after all, but the operation of the lsd has made the slipping inside wheel more natural?,normal? more unbiased? free to operate unsullied by the other side? Mmmm... Hard to explain.
Let me try another way.
There is a large round-a-bout near home I know quite well. When exiting there is a small bump on the inside of the curve. There used to be a weird sway oscillation which I'm guessing is the rear inside wheel tightening and loosening but now when I hit that bump the car feel more stable. That is, there isn't the same "swaying of the hips" at the rear.
I was a little enthusiastic and the rear went a bit sideways. I was doing 110 km/h when I started to apply corrective lock. OMG!! The creaminess of the slip was just freakin' awesome and most impressive there was no vicious snap back. That is , previously I would find the break away nice but then the rear would tend to snap back. No more. Previously a slip of this magnitude at that sort of speed would result in a bit of heart rate increase. Today it was like meh. Loved it. I also seemed to be getting on the power sooner (I haven't looked over prevoius data as yet) with less drama. I'm not really sure what is going under trail braking (my trail braking is not great) but there were certainly no adverse reactions there.
Old 09-28-2015, 05:33 PM   #10
e1_griego
e1_griego's Avatar
Drives: Many
Yeah Gikens (esp in Spec S trim) should be silent. The two that I have owned (only one currently owned) have driven/sounded like open diffs. At least if you're using the OS fluid.
e1_griego is offline   Reply With Quote
Old 09-28-2015, 05:36 PM   #11
mav1178
mav1178's Avatar
Even the stock Torsen makes noise in certain tight turns, especially in parking lots. Aftermarket clutch-type diffs do the same but with much louder clunks.
That's what I am mostly referring to. Normal driving has no impact unless I dump the clutch or accelerate while turning aggressively.
-alex
Old 09-28-2015, 05:38 PM   #12
e1_griego
e1_griego's Avatar
Drives: Many
Yeah the OSG is silent. It's not like a drifty diff kaaz or whatever.
Old 09-28-2015, 05:38 PM   #13
Are you sure it's actually functioning?
Old 09-28-2015, 05:39 PM   #14
e1_griego
e1_griego's Avatar
Drives: Many
Yes, quite.
I am a huge OSG cheerleader.
They work when you want them to and aren't obtrusive otherwise.
Anybody running Exedy stage 2 clutch? 14BRZ Engine, Exhaust, Transmission 65 05-26-2020 12:21 AM
SPECIAL PRICE TOMEI TITANIUM MUFFLER TYPE -80,60S,60R/FRONT STRAIGHT PIPE TYPE-80,60 myjdmparts Groupbuys 15 10-08-2015 10:41 PM
MKIII Supra clutch type LSD? Kotu100 Engine, Exhaust, Transmission 17 09-17-2015 09:55 PM
Who is running APEXi Coilovers - N1 Damper ExV (Expert Type V) zeal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-21-2014 05:19 AM
