Drives: Supra, 2014 BRZ
MKIII Supra clutch type LSD?
Anyone think of doing this? The 87-89 Supra came with a clutch-type 1.5 way LSD. This can be more desirable to some than the torsen LSD.
I've read that a FRS LSD has been swapped into a Lexus is250. Then i found that the is250 and is300 share the same pumpkin. The supra LSD works in the is300 pumpkin. So the MKIII Supra LSD should fit, right? |
Drives: Sterling BRZ Ltd
Why not purchase an clutch type LSD meant for our cars, any part from a Supra is going to be pretty old by now.
^^ That would be my opinion too. By the time you buy a used (and old) supra LSD, then rebuild it it'll probably just be cheaper to buy a brand new cusco or kaaz diff meant for our cars.
Seems like rebuilding a $100-$200 used lsd would be way cheaper than buying a $900+ new lsd.
I was just throwing the idea out there. |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Sorry for the off-topic: but the thing I would love to know...which exact Lexus IS pumpkin, that can directly swap with an FRS, comes with an 4.56 FD, and how to identify it (car model or serial number, etc.).... short FD upgrade on the cheap(junkyard), if it exists.
#6 | ||||
Drives: 2015 Series.Blue
Don't do it unless you're drifting. Torsen diff is much more advanced and actually handles better (it's also more expensive than a clutch type to make, hence why they were upgrades for the Supra) Quote:
Rebuild kit is cheap. Quote:
Yes, and those same cusco or kaaz diffs were originally made for the Supra They're also not really much better than a factory one that's been rebuilt with better clutches and springs.Quote:
Yep, definitely cheaper and just as effective. Still, wouldn't do it, the torsen is a far better diff unless you're dedicated to drifting. |
^^ That's not entirely true. Clutch diffs work better in a lot of other situations too. Most track junkies prefer clutch LSD's over Torsen LSD's as well.
If you get a wheel in the air with a Torsen diff it behaves like an open diff, which gives you no power to accelerate out of a turn (or into a driveway). The big benefit to a Torsen is that they have a much longer lifespan before needing major service.
Drives: 2003 Subaru Outback
Helical LSD that can handle 1000hp for these cars are 700$
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Hey Poodles! How's it goin.
I'm sure there's some member that might find this info useful for a cheap drifting LSD. If you're not one please don't argue that a new one is better. Different strokes for different folks. |
#10 | |
So then you get one of the Torsens with clutches in them to offset Or have a nice complicated traction control system that uses the brakes to achieve the same goal ![]() The main advantage of the Torsen is in it's name: Torsen = torque sensing. It actually helps you turn instead of fighting you like a clutch based LSD will. It's funny, the MKIII Supra guys were looking at getting the better Torsens out of the IS because the MKIII specific one (JDM Twin Turbo R with a 1JZ) is a first generation and known to be weak. |
#11 |
Kuruma Otaku
@Jeff Lange
Has numerous, informative posts on this. Including part numbers. Maybe do a search with his user name and lsd related keywords.
Because titanium. |
#12 |
Yes, Jeff is well known by me
![]() *waves at Jeff and Kotu100* |
#13 |
Kuruma Otaku
Supramania?
He's already posted up some really detailed information here on diff interchange between Supras, IS and 86s.
Because titanium. |
#14 |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| MKIII is @ Pebble Beach | RRnold | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 08-25-2011 10:08 AM |
| Scion FR-S (MKIII) Coupe/Hatchback/Convertible in color! | Allch Chcar | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 76 | 07-01-2011 12:43 PM |
| Color Swap Request MkII and MkIII | xantonin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-20-2011 10:55 PM |
