Old 09-08-2016, 05:36 PM   #1
warmwetness
warmwetness's Avatar
Drives: 2016 halo fr-s
Max camber on OE crash bolts?!
I've been searching, but can't find an answer. What's the achievable maximum negative camber on the OE crash bolts in comparison to the white line camber bolts?! Any input appreciated.
Sent from my 5054N using Tapatalk
warmwetness is offline   Reply With Quote
Old 09-08-2016, 06:42 PM   #2
sugoi
Drives: 2015 BRZ Limited CWP
http://www.ft86club.com/forums/showthread.php?t=35855
Originally Posted by Kido1986 View Post
Modifications
This class has limited modifications. You can modify/add:
*Any exhaust behind the last Catalytic converter (Aka you can add an Catback or Axleback exhaust). It must be full length, reach the rear bumper
*Any drop-in filter (you cannot change the intake or modify the airbox or intake tube)
*Any shocks/struts that mount up as stock replacements (though you can currently have external reservoirs).
Change, replace or remove ONE sway bar. One of the two bars must remain *OEM and attached though it is your choice of which one to modify (though a front bar is the only one that makes sense for this car)
*OEM Crash/Camber Bolts. These allow you to add a small amount of front camber. Some cars vary in the amount of camber you can gain. I reached -1.4 while some people could not pass -0.8 and others saw -1.5. Get an alignment after install!. This is likely to throw the Toe off in your front end. Large tire wear, pulling to one side or poor handling can occur from this. OEM part numbers are as follows:
Toyota: SU003-02818
Subaru: 901000394
*Any brake pad you want
*Any fluids you want (brake, oil, coolant, transmission, differential)
*Stock sized wheels within 6mm offset. This means 17x7 with an offset between +42 and +54. Spacers to count for offset reduction. Example, with a +48 offset wheel (such as stock), you can throw on a 5mm spacer (never use bigger than 5mm on our stock studs!) and have an effective offset of +43 and be legal but you cannot use a +42 wheel and use a 3mm spacer. That would equal +39 which is too low of an offset.
*Tires. This is the biggie. You can use a 140 treadwear or higher tire in this class. This only rules out RCompound tires.
It will vary car to car for OEM crash bolts, but ~1.4-1.5 is max. My car was only able to achieve -1.1.
I'm not too sure about the Whiteline bolts but perhaps someone else can chime in.
sugoi is offline   Reply With Quote
The Following User Says Thank You to sugoi For This Useful Post:
warmwetness (09-08-2016)
Old 09-08-2016, 06:50 PM   #3
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Been a little while, but if i recall correctly, you can take the spl/whiteline lobed camber bolts and install in the top strut mount, and then take the 14 mm OEM bolt from the top and switch with the 16 mm OEM bolt in the bottom for additional wiggle room, you can get somewhere between 1.5 to 1.9* ish camber.
Dont remember which one individually will net you more or less though sry
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
Old 09-08-2016, 07:12 PM   #4
warmwetness
Anybody encounter any problems running the white line bolts for a while? My goal is a mostly DD with a couple autox events a year. If anybody can recommend whether to use white line or the OEM bolts and why, I would be super greatful. I recently installed TRD springs and want a little more camber up front for a little more response.
Old 09-09-2016, 03:36 AM   #5
sugoi
If you live in an area where you have to worry about rust, the Whiteline/SPC bolt may rust faster than the OEM.
Whiteline bolts might not be allowed in the C-street autocross class, if that matters.
Old 09-09-2016, 03:43 AM   #6
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
Nope, the bottom bolt is 14mm to begin with.
Top crash bolts yielded L0.8 / 1.4R on my car.
-JvV-
jarnojvv is offline   Reply With Quote
Old 09-09-2016, 12:08 PM   #7
Toyarzee
Shibby!
Toyarzee's Avatar
Meh, maybe its the other way around. West end alignment helped with the setup... either way, one set of SPL and on trd lowering springs netted me -1.9 front and -2.0 rear. Tracking regularly with nt01s on 17x9s with no issues. But if autox is your thing and they arent allowed in your class, then maybe best to get crash bolts anyway...
Old 09-09-2016, 12:20 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Aftermarket 14mm camber bolt in the bottom hole.
14mm bolt from bottom hole goes into the oversized top hole.
Top hole is a bolt that goes from 16mm on one side to 14mm on the other so it's the more appropriate for a camber bolt (don't need special washers to fill the gap in an oversized hole. But doesn't get you as much camber as the above.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
jarnojvv (09-09-2016), Toyarzee (09-09-2016)
Old 09-09-2016, 02:07 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder what would be better choice to max out camber & for more reliability with crash bolts only - aftermarket camber bolts in both, or aftermarket in lower + moved to upper hole OE crashbolt?
Old 09-09-2016, 04:34 PM   #10
warmwetness
I'd like to achieve more (negative) camber in the front wheels, than the rear. Is this feasible with either OEM or white line bolts up front? Or do I have to modify the rear? After my spring install my rear camber is noticeably more negative than the front. But if either bolts yield me more (negative) camber in the front than rear, I will consider the OEM bolts. I'm sure this setup should be common too, on this forum.
Old 09-09-2016, 04:34 PM   #11
warmwetness
Than the front*****
Old 09-09-2016, 04:41 PM   #12
warmwetness
Thank you everybody for the answers. I apologize for my lack of forum etiquette. I can't seem to be able to delete a mistyped post.
Old 09-09-2016, 08:49 PM   #13
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Get the SPC camber bolt, which goes in the bottom hole, and move the bottom bolt to the top hole, it gave me -2.4 degrees of camber.
Cartman is offline   Reply With Quote
Old 09-11-2016, 10:08 PM   #14
86league
Drives: '13 BRZ Limited
Are you at stock ride height?
I put the OEM camber bolts today in the top hole and got about -1.5 up from about about -0.6 with the stock config. Left the lower bolt untouched. (these were self measured - not on an alignment machine, so there is probably some question about accuracy).
If I could do something simple/cheap like the SPC bolts and get to -2.4 that would be great.
86league is offline   Reply With Quote
DIY | Video Installing Camber Crash Bolts Dezoris DIY (Do-It-Yourself) Guides 24 09-06-2016 11:07 AM
Do crash bolts provide enough camber for autoX? barabia Tracking / Autocross / HPDE / Drifting 12 07-09-2014 05:38 AM
Part Number for OEM crash (camber) bolts for FR-S? Rampage Tracking / Autocross / HPDE / Drifting 4 07-10-2013 11:14 PM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
