#15 |
Drives: Full race 4cyl boxer
I have a hard time understanding how a complete rebuild at the dealer (with repeat failure being a real possibility) could ever be cheaper than a new long block from the factory.
But what do I know, I work in an industry where labor is the highest cost. |
#16 | |
Drives: 2014 BRZ Limited 6MT
#17 | |||
Honestly he should've gotten a new long block.....
| The Following 4 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: |
#18 | |
Drives: Moped
| The Following 2 Users Say Thank You to Lonewolf For This Useful Post: | dinoniel (07-17-2016), FRSBRZGT86FAN (07-17-2016) |
#19 | ||
I argued for this. I got nowhere. In the end everyone kept saying "it's not up to the dealer it's up to the area manager and Subaru Rep." I asked for their numbers to speak directly and supposedly no one had it or even knew what days they worked. It was all a big mystery. Quote:
I'm just pretty exhausted of dealing with it all. It's a gigantic time toilet. And I will always be worried with the reliability of my only car. The worst part...a salesman from the dealer called last week asking if I want a new 2016 BRZ given my issues with the current one. I told him I would really prefer if my 2yr old car was just given back to me in reliable condition rather than entering a brand new deal. That call just furthers the idea that they really don't get it. Verdict is still out if I will keep this car after it is fixed. It's hard for me to daily drive a car that has failed me twice without me even driving hard during these events or modding the engine. Anyway appreciate the support as always
#20 |
They sure are doing a lot of "patching" on that old engine.
Back in the day, I would have thought ...... fine, now it should be like new. However, engines were simpler and/or mechanics were more competent. I'll betcha the kid they have rebuild that engine never rebuilt a FA20 engine before. I would recommend, after it is fixed, trade it into that dealership for a new car. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Cole (07-17-2016) |
#21 | |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | humfrz (07-17-2016) |
#22 | |
* take the carburetor apart and clean it with Gunk and rebuild with a new kit. * pull the spark plugs, clean them and squirt some kerosene into the cylinders * install a used battery * pop the top off the distributor and clean the contacts with a finger nail file * disconnect the fuel filter, clean and blow out the lines * rap on the starter a few times * mount a couple of used tires/patch a couple of tubes * add water to the radiator (and oatmeal if it leaks); tape up any leaking hoses * pour in 5 gallons of new gas * fire that puppy up ...... you got yourself a running machine ![]() humfrz |
#23 | |
There loss, literally, if the motor spins another bearing it's all there fault for not getting a brand new block and it will cost them more time and money
#24 |
UPDATE:
Well I left the car at the dealer to have all the work done that I had previously posted. The car was there for over 6 weeks, I told them to take as long as they needed to make it right. Picked up the car on 09/01/16. Since leaving the dealership I've kept it under 3k rpm. More like 2.5k rpm im so nervous about driving this thing. It's also MUCH louder exhaust such that 3 people over the phone while I was driving asked me if I got a new exhaust or a UEL header. It's not pleasant. Yesterday (6 days after picking up) the CEL and TCS light turned on. Code P0017. I had the code reset, hoping maybe it was some fluke idle code. This morning same warning light and same code P0017. Called the dealer twice today no answer. They probably screen my number at this point but I'm so done with this. At what point will subaru admit this car is a lemon? They've poured so much money into fixing the damn thing and it's still not fixed. Anyway anyone have experience with this code? I read a bit on the forums abt it but it was mostly about the random idling issues which didn't cause repeated warning lights like my case. Last edited by dinoniel; 09-08-2016 at 05:35 PM. Reason: grammar |
#25 | |
Drives: Whiteout FRS
#26 |
dinoniel - Here in NY you should be able to claim lemon at this point and get out of the car.
#27 | |
The car was bought in Colorado and I'm currently residing in FL so I also need to check which state applies. Appreciate the comments as always, I will update here when something progresses. |
| Stock Motor is Toast (Spun Rod Bearing) | DFW-FRS | Issues | Warranty | Recalls / TSB | 78 | 02-13-2018 11:56 AM |
| rod bearing failure. New long block question. | USMCgetsome | Engine, Exhaust, Transmission | 13 | 06-12-2016 04:35 PM |
| Likely hood of a spun bearing | aquaman | Engine, Exhaust, Transmission | 14 | 02-24-2016 01:37 PM |
| Engine Failure (#4 Rod Bearing + Short Block) | eriktherod | Issues | Warranty | Recalls / TSB | 215 | 10-30-2015 12:24 AM |
| Engine Failure (Bearing Rod 2) | Incursion | Issues | Warranty | Recalls / TSB | 59 | 11-27-2014 02:17 PM |
