Old 05-20-2016, 01:35 AM   #1
USMCgetsome
Drives: stock 2013 fr-s
rod bearing failure. New long block question.
Picking up a long block that is from an 2015 manual trans. I have a 2013 auto and my question is....... I want to convert that manual block to auto to bolt up to my auto trans. I see that there is a small difference in the two setups. Is there any problem other then swappin over my flexplate and tc to the other block? Anything else i have to worry about?
USMCgetsome is offline   Reply With Quote
Old 05-20-2016, 08:01 AM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
You better find a tuner and/or shop to assist you.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-20-2016, 11:06 AM   #3
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
the upper oil pan on the auto should have one extra hose next to the lower radiator hose, if its the same as the last one we did. just swap upper oil pans, unless the used motor doesn't come with it then you need to use yours anyway.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 05-20-2016, 12:54 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Question: How did you get a spun bearing? Are you running boost or anything?
Old 05-20-2016, 06:16 PM   #5
USMCgetsome
Fully stock. It had a leak that I found on the bottom right cam sensor area of the timing cover/oil pump plate. It was dripping on the rear 02 sensor and exhaust manifold and never got to the floor for me to see it was leaking oil. To see it finally I removed the under plate of the car and you could tell it was leaking for awhile. The wife drives the car during the week and I drive it ocassionally on the weekend. By the time it started to tap it was too late. I'm assuming it's the rod bearings because of all the metal shavings in the pan. Rotated by hand and it still has compression and you can hear it pump up and bleed. But when running the tapping is full blown now and sounds like rod knock.
Old 05-20-2016, 06:20 PM   #6
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I just had the same problem...
Just had the exact same issue.
spun a rod bearing is most likely culprit...
looking at new engines for installing this weekend now...
Jaden
Jaden is offline   Reply With Quote
Old 05-20-2016, 06:32 PM   #7
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Remember to check your oil at every fill up with the new motor.
TRAKRAVN is offline   Reply With Quote
Old 05-20-2016, 07:55 PM   #8
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
What was your mileage and any other relevant details? Oil brand? Dealer Service? Driving Style?
This is the third instance of 2013 rod knock I've heard of this month.
Decay107 is offline   Reply With Quote
Old 05-21-2016, 01:10 AM   #9
USMCgetsome
36,800 mi. We are the 3rd owner and wife drives it. We have never gone above 85 in the car. non dealer oil changes. I've always done them 4k-5k with 0w20 and just recently i bumped it to 5w20 this last change. Usually K&N oil filter and whatever full synthetic was on sale. I was waiting on that damn TSB for the reflash to come around but the only one that popped up was the Ignition key tsb.
Plans is hoping that the 2015 ecu and 2015 block will be a better solution than the 2013.
Anyone know if the ecu pin out or wiring or any sensor are different from 2013-15?
Old 05-24-2016, 01:13 PM   #10
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
am I missing something here? that should fall under the powertrain warranty which is 5yr/60k. you would have to prove your oil changes though. curious if that's worth a shot for you instead of forking over all that cash.
cdq85 is offline   Reply With Quote
Old 05-24-2016, 01:44 PM   #11
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Typically when putting in a motor of questionable origin we'll warm the car up and then dump that oil just to clear out anything that may have made it's way in there as well.
Gear_One_Performance is offline   Reply With Quote
Old 05-24-2016, 09:57 PM   #12
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Take off the plate on the back of the RH head and swap over your vacuum pump.
MT engines just have a plate and sealant. AT motors have a vacuum pump running off the camshaft.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 05-26-2016, 08:32 PM   #13
USMCgetsome
Yes ty you for that info I did notice that about the vacuum pump.
Old 06-12-2016, 04:35 PM   #14
USMCgetsome
Vacuum pump, upper oil pan/lower sub oil pan, aluminum coolant tube with small thermostat, flex plate and torque converter, 2013 coolant temp sensor (instrument cluster). Those were all the items needed to swap over. Also replaced fuel injector computer with the new 2015 block.
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 12:24 AM
Engine Failure (Bearing Rod 2) Incursion Issues | Warranty | Recalls / TSB 59 11-27-2014 02:17 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
