Old 09-07-2016, 11:49 PM   #1
notout86
Drives: GTS 86 auto
grinding marbles sound
A couple of times recently, when starting off across a non-level surface, at a slight right-turn angle, I have had a grinding sound like marbles rolling around in the diff or left rear wheel area. It only lasts a couple of seconds. On one occasion I started off very slowly (not wanting to scrape the nose), the other time a bit faster. The car was cold one time (travelled 300metres) and hot the other (travelled 30Km.)
The diff is the original equipment torsen one. Its oil was changed about 10,000Km back. The car has done 38,000Km of only normal driving. There are no leaks.
It's an auto and the sound does not seem to come from the transmission. Brake pads are about 30% worn.
Any ideas please people?
GTS86 Auto (Australia)
Old 09-08-2016, 12:00 AM   #2
Well, notout86, first I'd suggest you check the axle nut on each side to make sure they are tight.
If that doesn't fix it, I'd suggest carefully checking the rear axle universals to see if they are binding.
Also, you might check to make sure the brake calipers are tight.
notout86 (09-08-2016)
Old 09-08-2016, 12:03 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It could be a wheel bearing starting to go bad. But it would make the sound all the time and get louder the faster you went (ie rotational issue)
Old 09-08-2016, 02:11 AM   #4
notout86
Drives: GTS 86 auto
Thx humfrz. The universals binding sounds likely as the car had one rear wheel higher than the other at the time. Forgive me, I'm no expert but before I get my hands dirty, wouldn't I be hearing the noise often if the reason was because of those suggestions?
Old 09-08-2016, 02:25 AM   #5
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
The Torsen LSD in these cars frequently chatters when making turns at low speed. My guess is that's what you're experiencing - if so, it's totally normal and nothing to be worried about.
Last edited by RJasonKlein; 09-08-2016 at 02:27 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
The Following 2 Users Say Thank You to RJasonKlein For This Useful Post:
notout86 (09-08-2016), Ultramaroon (09-08-2016)
Old 09-08-2016, 02:35 AM   #6
notout86
Drives: GTS 86 auto
Thx RJasonKlein. I am hoping that turns out to be the case but I'm wondering why I have only heard it twice and recently. Maybe it shows up when the diff has worn a little but my car is low mileage and fairly gently driven. As for wear I changed my diff oil twice at 20,000Km.. the first time to flush after seeing the stuff on the magnetic drain plug.
Old 09-08-2016, 02:53 AM   #7
Well, like @RJasonKlein mentioned, it could be that the differential is chattering at you.
However, if the noise persists, especially if it gets worse, I would recommend that you have the axle nuts checked and the axles inspected.
Old 09-08-2016, 03:17 AM   #8
If you had to judge your driving history up to now, is it possible that you have gained a new level of comfort in gassing it through a tight turn?
Old 09-08-2016, 03:22 AM   #9
notout86
Drives: GTS 86 auto
Sorry. I don't understand the relevance to the thread or maybe you are too subtle for me.
The Following User Says Thank You to notout86 For This Useful Post:
Old 09-08-2016, 03:29 AM   #10
notout86
Drives: GTS 86 auto
Thanks everyone. Be assured that if a definitive answer is discovered I will post it.
I'll keep driving and see what happens and follow up on your suggestions if the problem persists.
Old 09-08-2016, 03:59 AM   #11
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
I think he means that you've probably taken corners at normal speeds up till now, and now that you're more comfortable with the car, you're taking the corners at speeds approaching "spirited" and since the diff's limited-slip capabilities only kicks in at higher loads, you might actually be hearing it in action now.
I think. One too many
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
Old 09-08-2016, 04:37 AM   #12
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
I have this sound issue at the rear of the car right now, I had someone bounce on the open trunk and found out its my LCA join xD might want to have someone sit on your trunk incase 😅😅😄😄
Sent from my SM-P600 using Tapatalk
turtlefeeder is offline   Reply With Quote
The Following User Says Thank You to turtlefeeder For This Useful Post:
Old 09-08-2016, 06:54 AM   #13
notout86
Drives: GTS 86 auto
I hope he doesn't think that. As I said, it has only happened when moving slowly, actually around walking pace.
Old 09-08-2016, 01:53 PM   #14
Exactly.
jar of marbles sound like in engine tintumz22 Issues | Warranty | Recalls / TSB 25 03-21-2014 12:18 PM
Grinding sound under acceleration Therightmike BRZ First-Gen (2012+) — General Topics 9 08-20-2013 03:00 AM
AUTO FRS, GRINDING SOUND COMING FROM UNDERNEATH? Charleswinky Scion FR-S / Toyota 86 GT86 General Forum 12 05-21-2013 09:51 PM
Cold morning and horrible grinding/screeching sound Books Issues | Warranty | Recalls / TSB 1 11-14-2012 03:18 PM
Manual grinding sound deedz Engine, Exhaust, Transmission 22 07-20-2012 11:05 PM
