Drives: 2013 Scion FR-S Toyota 86
jar of marbles sound like in engine
Hello guys. Just want to ask other MT owners here. Do you guys hear jar of marbles in the engine area during deceleration 1st-4th gear under 2200rpm? it's not continuous but after you put gas and let it decelerate(foot off pedal).
Drives: Subaru BRZ Limited
During deceleration. it starts from 2200rpm going down. it got a sound clip but don't know how to post it.
The Mechanic
Drives: Civic Turbo,FR-S
liiiikkkee knock? lol i have no noises. what fuel do your run?
Thupercharged
Loose heatshield?
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
Drives: 2013 SWP BRZ
Yes, that's normal.
http://www.ft86club.com/forums/showthread.php?t=8344 http://www.ft86club.com/forums/showthread.php?t=60451
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
Drives: BRZ Sport-tech
Jar of marbles noises from our car might as well be listed in the brochure as a feature. Well documented noise. Please search next time.
Thanks
It's not the engine I think, its shudder from "lugging"
I bet if you depress the clutch while it is making that sound it stops eh? |
Don't care
Drives: 2013 Whiteout FRS
you mean when you put the car in neutral at about 40 and coast? clutch chatter is what you are hearing.
#10 |
1570/2500
Drives: 2013 FR-S 10 Series
If you ever drive a car with a solid hub clutch you'll really hear the noise.
The likely cause is rapid loading and unloading of the clutch on the input shaft caused by power variations during the Otto cycle. |
#11 |
Don't care
My advice, turn the radio on and don't pay attention to noises this car will drive you crazy
#12 | ||||||
Nope. Checked it. all tight screws. Quote:
![]() Quote:
#13 |
Don't care
Are you hearing it at idle shortly after starting the engine. Thats also clutch chatter
#14 |
The Mechanic
bad timing chain tensioner? they normally are looser off throttle. im not sure if these run on oil pressue like s2k
| Clicking sound at idle from engine bay? | l0aded | Issues | Warranty | Recalls / TSB | 2 | 08-13-2013 02:26 PM |
| engine sound | cantaloupe | DIY (Do-It-Yourself) Guides | 12 | 05-21-2013 09:52 AM |
| obd2 engine sound app | brichard0625 | Engine, Exhaust, Transmission | 4 | 09-25-2012 04:36 PM |
| Engine sound trying too hard? | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 8 | 09-06-2012 07:04 AM |
| Engine sound being piped into the cabin... | Mango22 | BRZ First-Gen (2012+) — General Topics | 15 | 09-05-2012 04:50 PM |
