Drives: GTS 86 auto
grinding marbles sound
A couple of times recently, when starting off across a non-level surface, at a slight right-turn angle, I have had a grinding sound like marbles rolling around in the diff or left rear wheel area. It only lasts a couple of seconds. On one occasion I started off very slowly (not wanting to scrape the nose), the other time a bit faster. The car was cold one time (travelled 300metres) and hot the other (travelled 30Km.)
The diff is the original equipment torsen one. Its oil was changed about 10,000Km back. The car has done 38,000Km of only normal driving. There are no leaks. It's an auto and the sound does not seem to come from the transmission. Brake pads are about 30% worn. Any ideas please people?
GTS86 Auto (Australia)
#2 |
Well, notout86, first I'd suggest you check the axle nut on each side to make sure they are tight.
If that doesn't fix it, I'd suggest carefully checking the rear axle universals to see if they are binding. Also, you might check to make sure the brake calipers are tight. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | notout86 (09-08-2016) |
#3 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
It could be a wheel bearing starting to go bad. But it would make the sound all the time and get louder the faster you went (ie rotational issue)
#4 | |
Drives: GTS 86 auto
#5 |
Drives: 2013 Scion FR-S 10 Series
The Torsen LSD in these cars frequently chatters when making turns at low speed. My guess is that's what you're experiencing - if so, it's totally normal and nothing to be worried about.
Last edited by RJasonKlein; 09-08-2016 at 01:27 AM. Reason: Corrected a typographical error. |
| The Following 2 Users Say Thank You to RJasonKlein For This Useful Post: | notout86 (09-08-2016), Ultramaroon (09-08-2016) |
#6 |
Drives: GTS 86 auto
Thx RJasonKlein. I am hoping that turns out to be the case but I'm wondering why I have only heard it twice and recently. Maybe it shows up when the diff has worn a little but my car is low mileage and fairly gently driven. As for wear I changed my diff oil twice at 20,000Km.. the first time to flush after seeing the stuff on the magnetic drain plug.
#7 | |
However, if the noise persists, especially if it gets worse, I would recommend that you have the axle nuts checked and the axles inspected. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (09-08-2016) |
#8 |
If you had to judge your driving history up to now, is it possible that you have gained a new level of comfort in gassing it through a tight turn?
#9 |
Drives: GTS 86 auto
Sorry. I don't understand the relevance to the thread or maybe you are too subtle for me.
| The Following User Says Thank You to notout86 For This Useful Post: | Ultramaroon (09-08-2016) |
#10 |
Drives: GTS 86 auto
Thanks everyone. Be assured that if a definitive answer is discovered I will post it.
I'll keep driving and see what happens and follow up on your suggestions if the problem persists.
#11 | |
Drives: Scion FR-S 10 Series #2263
I think. One too many
| The Following User Says Thank You to aegisdrgn For This Useful Post: | Ultramaroon (09-08-2016) |
#12 |
Drives: UltraMFrS
I have this sound issue at the rear of the car right now, I had someone bounce on the open trunk and found out its my LCA join xD might want to have someone sit on your trunk incase 😅😅😄😄
Sent from my SM-P600 using Tapatalk |
| The Following User Says Thank You to turtlefeeder For This Useful Post: | notout86 (09-08-2016) |
#13 | |
Drives: GTS 86 auto
#14 | |
| jar of marbles sound like in engine | tintumz22 | Issues | Warranty | Recalls / TSB | 25 | 03-21-2014 11:18 AM |
| Grinding sound under acceleration | Therightmike | BRZ First-Gen (2012+) — General Topics | 9 | 08-20-2013 02:00 AM |
| AUTO FRS, GRINDING SOUND COMING FROM UNDERNEATH? | Charleswinky | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 05-21-2013 08:51 PM |
| Cold morning and horrible grinding/screeching sound | Books | Issues | Warranty | Recalls / TSB | 1 | 11-14-2012 02:18 PM |
| Manual grinding sound | deedz | Engine, Exhaust, Transmission | 22 | 07-20-2012 10:05 PM |
