Old 09-08-2016, 01:18 AM   #1
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Manual Trans gearing for 2017 model ?
I've read the differential gearing has been changed from 4.1 to 4.3
I've read that 6th gear has been strengthened.
I've read that overall mileage figures are lower than older models.
I cannot find anything about gear ratio changes within the manual six speed transmission.
Certainly sixth gear must have been changed to allow for not too high revs at freeway speeds and above.
Anyone have info on actual gear ratio changes ?
ToySub1946 is offline   Reply With Quote
Old 09-08-2016, 07:56 PM   #2
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
Googled this just now:
http://www.cars.com/toyota/86/2017/specifications/
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
Old 09-08-2016, 08:07 PM   #3
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
I don't remember reading about a ratio change in the official Toyota documentation. I believe it's still 0.767.
- The Ancient BRZ Sacrament
by Zaku
Old 09-08-2016, 08:51 PM   #4
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
Gear ratios are the same. You just run a bit more rpm at highway speeds, its not a huge jump.
goldenfri is offline   Reply With Quote
Old 09-08-2016, 10:18 PM   #5
stevo585
Drives: White 2014 BRZ
So two shifts to 60mph now. You can just barely hit 60 slightly past redline with the 4.10s
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 09-08-2016, 10:28 PM   #6
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Originally Posted by wireman957 View Post
How did cars.com get the gearing specs but they're not on Toyota or Subaru's website?
I tried searching for the gearing
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 09-09-2016, 12:05 AM   #7
ToySub1946
ToySub1946's Avatar
goldenfri:
"Gear ratios are the same. You just run a bit more rpm at highway speeds, its not a huge jump."
Well I guess my real concern was not for tracking, but how high my engine might rev at very high freeway speeds (causing poorer mpg). In the northwestern inland states and portions of west Texas speed limit can be 80mph...and of course, that means running 90mph or so in reality. Possibly Toyota and Subaru did not consider this. So I'm ready for a 7 speed as in Porsche and Corvette...if 6th gear ratio has not changed since 2016 models/combined with the now (for 2017) 4.3 diff.
Old 09-09-2016, 02:38 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Or just do unexpected mod .. of installing 4.1 diff if you prefer older year ratios and mpg / rpms @ high speed are more important then acceleration.
Old 09-09-2016, 02:43 AM   #9
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Just swap with someone with a older MY or an AT, there won't be a shortage of takers. You should even be able to get the other party to do all the work. The gearing on the MT is fairly short anyway so you won't be losing much either way. Take pity on the MY17 AT owners who got exactly nothing as an upgrade.
Old 09-09-2016, 04:47 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
.. hmm, on second thought, this is first time i heard of different MY2017 gearing .. and starting to think, if THIS might be the reason why bigger performance numbers are cited for new MT & not for AT, with no actual performance affecting changes to engine/ecu tune/etc? Otherwise why else AT would have no gains/improvements, it sounds illogical :/
Old 09-09-2016, 06:24 AM   #11
Wayno
Wayno's Avatar
No, it's because of new engine parts including both manifolds
Old 09-09-2016, 10:27 AM   #12
goldenfri
goldenfri's Avatar
goldenfri:
I am sure they thought of this... it will be fine, you are worrying too much. Gas mileage is more about throttle position than revs, as long as you stay light on the throttle it won't be a big issue. They also made a bunch of engine changes remember, maybe some were to handle the slightly higher highway revs.
As someone that used to have an S2000 with 4.56 gears that thing would be at 5k+ cruising on the highway, it wasn't a problem and still got decent gas mileage.
Old 09-09-2016, 10:29 AM   #13
goldenfri
goldenfri's Avatar
Gears don't provide more horsepower, just increased mechanical acceleration. Dyno pulls are generally done at the closest ratio to 1:1
Old 04-03-2017, 03:41 PM   #14
Scourge
Agent 86
Drives: 2017 Toyota 86
I don't know if you've found the information but in case you need something from Toyota, this PDF link is active currently... And it is 4.30 for the manual only.
http://toyotanews.pressroom.toyota.c...tions.download
Scourge is offline   Reply With Quote
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Final Drive Gearing, Auto vs Manual KoolBRZ Engine, Exhaust, Transmission 9 09-11-2017 09:50 PM
2017 Model Year Improvements FiReStorm2013 Scion FR-S / Toyota 86 GT86 General Forum 353 03-11-2016 03:07 PM
Manual Trans 12k miles $750 OBO Amir Ghadiri Transmission and Driveline 4 05-23-2015 02:35 PM
Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) boomslang CANADA 1 09-07-2014 11:24 PM
