Old 11-23-2014, 05:39 PM   #1
KoolBRZ
KoolBRZ's Avatar
Final Drive Gearing, Auto vs Manual
Here are some comparisons I've made with commonly available differential gear ratios. I hope it will help some of you. This also helps to explain why I believe automatic's need more torque, and manual's, more horsepower.
Manual transmissions
I=3.626, II=2.188, III=1.541, IV=1.213, V=1.000, VI=0.767
6th gear ratio, Differential ratio, and engine RPM's at 60MPH.
0.767 @ 4.10 = 2575 RPM's @ 60MPH
0.767 @ 4.30 = 2701 RPM's @ 60MPH
0.767 @ 4.55 = 2858 RPM's @ 60MPH
0.767 @ 4.77 = 2996 RPM's @ 60MPH
0.767 @ 4.88 = 3065 RPM's @ 60MPH
Automatic transmissions
I=3.538, II=2.060, III=1.104, IV=1.00, V=0.713, VI=0.582
0.582 @ 4.10 = 1954 RPM's @ 60MPH
0.582 @ 4.30 = 2049 RPM's @ 60MPH
0.582 @ 4.55 = 2168 RPM's @ 60MPH
0.582 @ 4.77 = 2273 RPM's @ 60MPH
0.582 @ 4.88 = 2326 RPM's @ 60MPH
0.582 @ 5.404 = 2575 RPM's @ 60MPH
As you can see, it would take changing to a mythical 5.404 to 1 gear and pinion for an automatic to equal the gearing of the manual transmission. That's why automatic's are rated to get such better mileage than the manual's, despite the torque converter losses. I think a 4.88 to 1 ratio would be ideal for an automatic. I could still do 28MPH in 1st @ 7000RPM's, versus 35MPH in 1st @ 7100RPM's for the manual@4.10. This would give me the holeshot from a dead stop, and still better economy at 60 MPH with a 4.88 automatic's 2326 RPM's versus the 4.10 manual's 2575 RPM's.
Old 11-23-2014, 05:58 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Whats a hole shot?
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 11-23-2014, 06:32 PM   #3
KoolBRZ
KoolBRZ's Avatar
Originally Posted by Apoc View Post
Whats a hole shot?
The term is used in motorcycle racing, off-road racing (but also motorsport racing in general) for the rider who is the first one through the first turn.
Old 11-23-2014, 11:45 PM   #4
Poodles
Drives: 2015 Series.Blue
Again, you need to learn what a torque converter does...
Old 11-23-2014, 11:49 PM   #5
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I regard my auto to 4.88s and love it. Better acceleration and I still get over 30 mpg at freeway speeds. Best mod I have made.
Lunatic is offline   Reply With Quote
Old 11-24-2014, 01:01 AM   #6
toyotaAlex
toyotaAlex's Avatar
Drives: 2013 Scion FR-S Auto- OFT Stage 2EL
im buying 4.88s this winter and swapping them in. thats probably gonna be the last thing till the warranty is up for me lol
2013 Scion FR-S Auto, OFT Stage 2 Equal length 94oct, Hollowed out Factory Manifold, Stock Overpipe, Hollowed Front Pipe, Stock Midpipe with Resonator Removed, Custom Axleback with Single Exit and a Flowmaster 50series Muffler. Stock Airbox with all resonators removed, Snorkel shortened, TRD Panel Filter.
toyotaAlex is offline   Reply With Quote
Old 11-24-2014, 01:12 AM   #7
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Does changing the gearing void warranty?
904FRSlow is offline   Reply With Quote
Old 11-24-2014, 02:13 AM   #8
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Probably the rear drive train assembly, but would they really notice?
Old 11-24-2014, 03:19 AM   #9
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The only thing you need a FD for is motorsport, and if you're doing anything on track you won't ever need to be comparing an AT 6th gear at 60mph, so once again you've demonstrated extremely well what you know - SFA. Automatics need lower 4th and 5th with the same 6th. Then change the FD exactly the same as you would with MT for corner exists.
Old 09-11-2017, 09:50 PM   #10
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
So the 4.88 seems best for an auto, but what seems best for the manual. The 4.88 or 4.67. I'm NA e85 and pushing 205whp. This is my next mod but I'm deciding which final gear drive is best. 4.56, 4.67, and 4.88. I usually street race from 0 to 100, which gear would be best for that. I also autox every once in a while but not too important.
Dr. BRZ is offline   Reply With Quote
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
4.875 final drive review drift86 Engine, Exhaust, Transmission 98 02-12-2018 06:13 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
Any interest in 4.5 final drive from Auto Factory? mike_ekim1024 Engine, Exhaust, Transmission 12 09-12-2013 08:41 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
