Old 09-07-2016, 05:49 PM   #1
Jarred55
Drives: 2013 Asphalt MT
New wheels screwed my fenders
Hello everyone! I've had my FRS for almost half a near now and have been following these forums since I was looking to buy one but this is my first post.
Ok so long story short I bought new wheels (17x8.25 +25offset) on 225/45 tires. I also lowered my car on eibach sport line and the fitment looks great but the problem is that after driving a few days I found that my tires hit my fender and have seem to bend it a little, causing it to look dented or like it has a dimple on both sides. My friend and I tried to get it out and got some but was curious as if it could be fixed to look like it never happened by a PDR guy. Some say it's hardly noticeable but to me it hurts everytime I look at it lol. Any input is appreciated, thank you!
Can't upload photos right now and will as soon as possible
Jarred55 is offline   Reply With Quote
Old 09-07-2016, 06:11 PM   #2
swarb
Ok so long story short I bought new wheels (17x8.25 -25offset) on 225/45 tires. I also lowered my car on eibach sport line and the fitment looks great but the problem is that after driving a few days I found that my tires hit my fender and have seem to bend it a little, causing it to look dented or like it has a dimple on both sides. My friend and I tried to get it out and got some but was curious as if it could be fixed to look like it never happened by a PDR guy. Some say it's hardly noticeable but to me it hurts everytime I look at it lol. Any input is appreciated, thank you!
I think you have your offsets wrong.
Old 09-07-2016, 06:19 PM   #3
Jarred55
Oops meant +25 lol used to my trucks wheels
Old 09-07-2016, 07:25 PM   #4
If on a seam or crease then PDR can not fix it. If that slight just give it a month and you will not even notice it anymore. And in the future check your fit better before driving around since the results could have been much worse.
Cole (09-07-2016)
Old 09-07-2016, 09:23 PM   #5
Even if a PDR guy could "fix" it ...... it will likely just happen again, unless you make some adjustments to your wheels or suspension.
I suggest you check with a PDR guy and see what he has to say.
Then, either make the adjustments or live with the results.....
Bubba says to take a sawzall and make the wheel wells larger ......
shellslinger (09-07-2016)
Old 09-07-2016, 11:19 PM   #6
shellslinger
Drives: Whiteout FRS
Yup what Humfrz said. It will just happen again if its fixed. You may want to look into getting different lowering springs or coilovers to raise up the vehicle.
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
humfrz (09-07-2016)
Old 09-08-2016, 12:30 AM   #7
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Dont think different springs or coilovers will fix the issue. Raise the car and you're just hoping you dont hit a bump bad enough to make the wheel travel that high.
Your wheel offsets might be off, check the "Flush wheel offset chart" here: http://www.ft86club.com/forums/showthread.php?t=7535
For 8.25" and lowered 1" you want +39 and +29 in front and rear respectively. A lower offset number pushes the wheel out. So right now you're poking out 14mm past flush in the front and 4mm in the rear.
(Note: I'm not a pro with wheel fitment, I'm just saying stuff based on the chart i referenced above)
The Following User Says Thank You to PandaSPUR For This Useful Post:
shellslinger (09-08-2016)
Old 09-08-2016, 12:46 AM   #8
ryoma
ryoma's Avatar
I have never seen a wheel width at 8.25 though... wow.
Old 09-08-2016, 10:52 AM   #9
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
NLMotoring XXR 530 17x8.25 et25
XXR does weird sizing(and offset) mine are 18x8.75 et33. Really wish they would of done normal sizes.
Old 09-08-2016, 11:13 AM   #10
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You'd be surprised. I just had a great PDR guy get some damage fixed, one spot was pretty bad and on a body crease, and it looks perfect now! PDR results vary greatly depending on how good the guy is.
-Josh
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tcoat (09-08-2016)
Old 09-08-2016, 12:49 PM   #11
-Josh
Ya, I should have been more specific. 'Most' can/will not fix it if on a seam or crease.
Yoshoobaroo (09-08-2016)
Old 09-08-2016, 01:09 PM   #12
8R6
8R6's Avatar
Drives: FRS
get the fender rolled and pulled by a qualified fender roller guy. that should minimize even more the minimal dent you probably have. then also get camber bolts and add a little more negative camber up front and that should help get enough clearance.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Shinchu (09-08-2016)
Old 09-08-2016, 02:56 PM   #13
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Meet with PDR guy, see if he things you should have your fenders rolled BEFORE or AFTER he tries to work his magic. Get fenders rolled and PDR done accordingly.
Additionally, next time get wheels that fit.
JazzleSAURUS is offline   Reply With Quote
Old 09-08-2016, 03:04 PM   #14
CBR600RR
Drives: Raven Black
deleted
feeler CA: trade seibon CF fenders for stock red fenders Alliedforces86 Exterior Parts (Aero, Lighting, Etc.) 11 08-08-2013 01:03 PM
WERE SCREWED!! 17 YEARS ALREADY!? Marcoscrdo Mid-Atlantic 23 05-10-2013 01:29 PM
well im screwed marine321 Scion FR-S / Toyota 86 GT86 General Forum 59 12-17-2012 10:00 PM
Screwed. Helix Southeast 39 07-22-2012 07:22 PM
I think i screwed myself!!!! WhatOhS*itBar? Scion FR-S / Toyota 86 GT86 General Forum 14 07-04-2012 12:06 AM
