Old 09-07-2016, 01:34 AM   #1
golemslord
Drives: 2014 White FRS
Balance newly installed tires/rims
So I bought a set of TRD rims with tires (one month old tires) from a guy on craigslist, mounted them on by myself and the question is do I need a balance or alignment? or both? The rims were also previously mounted on an frs. Thanks
golemslord is offline   Reply With Quote
Old 09-07-2016, 02:24 AM   #2
gramicci101
Off Topic
Alignment, no. Changing wheels doesn't affect the alignment; changing suspension parts does. Were the tires already on the wheel? If so, the balance is probably fine. If it feels shaky while you drive that would be the first thing I checked though.
The Following User Says Thank You to gramicci101 For This Useful Post:
golemslord (09-07-2016)
Old 09-07-2016, 02:30 AM   #3
golemslord
The tires were already mounted on the wheels. But owner said some wheel weights fell off (and i see that it did) so I guess I should get only a balance. There's no shaky feeling however. Thanks for clarifying what alignment is
Old 09-07-2016, 02:33 AM   #4
gramicci101
Off Topic
If you think some wheel weights fell off, definitely get them rebalanced.
Old 09-07-2016, 08:59 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Yeah, alignment, like camber/caster/toe is suspension parts related. Hence it should be done: 1) on new car (factory alignment has broad range of "pass"), 2) when you change suspension parts, 3) when you want some different settings (eg. more negative camber for track), 4) after crash or big hard shocks to suspension when you suspect alignment might get out of whack.
Balancing is for wheels+tires, so that wheel doesn't act as excentric crankcase producing vibrations when rotating, by large extent lessening comfort, adding roadnoise, reducing grip, reducing high speed stability, adding wear to dampers/bushings (but mostly of course due comfort). Should be done in most cases when you remount tires on wheels (not when you mount to different wheels+tires, as they are balanced as unit). That is 1) when you buy and install new tires on wheel, 2) when you change due season summer <> winter rubber, 3) and - your case - if you are informed, that some balancing wheights fallen of / if you feel something happened wrong with balancing (eg. unusual vibration/roadnoise) / or you tracked car that hard, that pieces of thread had been ripped off unevenly, and still want to use those tires
golemslord (09-07-2016), ModBargains.com (09-15-2016)
Old 09-15-2016, 06:44 PM   #6
ModBargains.com
ModBargains.com's Avatar
^^ Pretty much that unless its a big change in the wheel and tire set up. If you are sticking with same or close to same specs, alignment won't be needed
ModBargains.com is offline   Reply With Quote
Mount/balance used tires cheap? EAGLE5 Northern California 4 08-05-2016 02:31 AM
Newly installed problems JG Engine, Exhaust, Transmission 16 06-27-2015 12:33 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 03:33 PM
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 09:11 AM
Feedback through newly installed tweeters mit_peid Electronics | Audio | NAV | Infotainment 24 04-07-2013 11:05 AM
