Old 08-29-2016, 04:05 PM   #15
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
There was no visible difference between the high beam lever on (flash to pass) and DRL level. The threshold is presumably too high to allow the advertised function.
It's too bad, the product seems to be of high quality, shipping snd service were excellent. Just not a good fit for this specific application.
Shinigami301 is offline   Reply With Quote
Old 08-29-2016, 04:53 PM   #16
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Originally Posted by FX86 View Post
every led i dealt with for the drls was always in full power mode and looked exactly the same brightness when i switched to high beams
There's the issue. From our testing, the 2Strokes come on at full brightness at anything above 9V which is right around where the FR-S DRLs would be running at (according to our lighting guy, the FR-S seems to run DRLs at a higher voltage than most other makes). Granted it's extra work, but wiring in a resistor could help you there. Anything below 9V and you get the appropriate dimming action.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 08-29-2016, 07:25 PM   #17
Shinigami301
Seems reasonable, but I imagine doing this right (no consequences to the high beam function) might be a little more complicated than simply wiring in a resistor.
Then again, it's been quite a while since I found myself falling asleep in EE101, and I couldn't diagram a Norton/Thevenin equivalent diagram anymore if you put a gun to my head.
And even if solved, it doesn't make up for the donut hole in the pattern.
Old 09-06-2016, 02:47 PM   #18
SlammedSilly
Drives: 2015 Ultramarine FR-S
Originally Posted by SlammedSilly View Post
so quick question, to the people running these... hows the light output when its raining/snowing (if you get snow) bc i dont want to get these if the output is bad in the rain/snow
no update on my original post?
SlammedSilly is offline   Reply With Quote
Old 09-06-2016, 03:48 PM   #19
Manic
Is not fast.
Manic's Avatar
Unfortunately, we haven't seen rain in Southern California in many moons. We're almost to the point of making live sacrifices.
The Following User Says Thank You to Manic For This Useful Post:
SlammedSilly (09-07-2016)
Old 09-06-2016, 04:34 PM   #20
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
also, I will have review of high beams with 2strokes at night soon...just got the driveshaft installed in the car lol, so I'll be able to test soon.
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 09-21-2016, 08:50 AM   #21
SlammedSilly
any update on that review?
Old 09-21-2016, 11:24 AM   #22
continuecrushing
not yet-I did drive the car at night, and the high beams are epic-but I also have a retrofit so I get a "high beam" from my low beams.
One thing for certain-the instant on from the high beams is absolutely noticeable. I had the stock halogens in there before, and although they turn on quickly, the leds now are RIGHT NOW on haha.
SlammedSilly (09-21-2016)
Old 09-21-2016, 11:40 AM   #23
SlammedSilly
gotcha! well your also running them in your low beams correct?
Old 09-21-2016, 12:59 PM   #24
continuecrushing
no, right now I have HID in the low beam with a retrofit kit...bulb size is H1, and the 2strokes don't come in H1 size yet.
When I get the chance, i'll probably just pull the low beam wire, and do a comparison of stock halogen vs led (but high beams only)
Morimoto LED Fogs Struckbylitenin Cosmetic Modification (Interior/Exterior/Lighting) 9 08-08-2014 11:53 AM
6K H11 Morimoto HID Kit Zero90 Exterior Parts (Aero, Lighting, Etc.) 2 05-20-2014 12:49 PM
Stroke saving, room giving front camber plates please. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 01-31-2014 04:34 PM
Possible crickets fix? Adding a capfull of synthetic 2 stroke oil per tank full? mike the snake Issues | Warranty | Recalls / TSB 29 09-29-2013 04:29 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 02:03 AM
